Transfer case leak.. easy fix?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacodown, May 26, 2017.
  1. May 26, 2017 at 7:14 PM
    tacodown
    tacodown [OP] Well-Known Member
    brant
    holtwood, Pa
    96 tacoma 2.7
    Looks to be leaking fluid behind my front drive shaft going to the front diff. Im guessimg a seal has gone bad and my main question is how anybody dealt with this before and can it be fixed from the outside of do i have to open the nack of the case out?? Doesnt seem to me like its comming out of the bottom of the t case. Looks like i caught it early
  2. May 26, 2017 at 10:09 PM
    tacodown
    brant
    holtwood, Pa
    96 tacoma 2.7
  3. May 26, 2017 at 11:09 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I've got the same thing happening I think. :spy:
  4. May 26, 2017 at 11:52 PM
    Animus313
    Animus313 Well-Known Member
    Post Falls/CDA, ID
    2000 Tacom xtra cab
    I recently moved and now my driveway has a slight slant to it and I noticed a small drip from the transfer case. I had always had oil similar to your picture. I believe this is the how too you are looking for, its on the list of things to do for me. For a 4 runner but should be generally the same. I have the part numbers here somewhere for the seals. I'll see if I can find them.
    Dalandser likes this.
  5. May 26, 2017 at 11:55 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Nice. Thank you. Thought I was going to have to separate the transfer case from the trans or open up the transfer case. My driveshaft is already off too :)
  6. May 26, 2017 at 11:59 PM
    Animus313
    Post Falls/CDA, ID
    2000 Tacom xtra cab
    I missed that the OP said front drive shaft when reading it. The link was to the rear but the front should be similar. I think there's a how-to floating around somewhere.
