Transfer case leak!?! *PICS* Help!
Discussion in 'Technical Chat' started by TacoNL, Jul 18, 2008.
  1. Jul 18, 2008 at 9:23 PM
    TacoNL
    TacoNL [OP] New Member
    Brad
    NL, Canada
    2011 TRD Sport
    Outside: TRD Exhaust, Skid Plate, Smittybilt Light Bar with 2 x Hella 500FF Driving Lamps and 2 x Hella 500FF Fog Lamps. Inside: Blu Logic Bluetooth Module
    I have a '98 Taco V6 4x4 that I've had for less than a week.
    Well today I noticed 2 drops of oil under the truck every time I had it parked for a half hour or more. There was always 2 drops a bit bigger than a quarter. I looked under the truck and noticed that the transfer case was covered in oil. *SEE PICS BELOW*
    It seems to cover the lower section of the transfer case and partially back towards where it joins the transmission. It's a dark oil as you can see. I have the trucked park now so I don't do any damage just in case the oil is low. However, it's shifting into 4WD and driving fine, and also driving in 2wd fine (aside from some sputtering when under load at 3K+ which is a suspected bad O2 sensor).
    Does any one have any opinions as to what my trouble is? Seal, multiple seals? I'm hoping it's not the whole transfer case being screwed! If it's the seals, what kind of labor time is involved in getting them replaced as well as approximate cost of the seals.
    On a another related note, does anyone know where I can download/buy a '98 Taco service manual?
    Thanks in advance for any help/input!
  2. Jul 18, 2008 at 9:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i would say clean all the oil residue off real good where you can see the case real good, then drive it a bit, then crawl under there and see if you can see where its coming from. have you checked the tightness of the drain and fill plugs?? could end up being a bad crush washer. hopefully, the case aint leaking.
    looks like you need to change that fuel filter too.
  3. Jul 18, 2008 at 9:35 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can find the service manual here to download.......enjoy!!! by the way......welcome to tacomaworld!!!
  4. Jul 18, 2008 at 9:36 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    See my post to you over on TN and get that frame looked at ASAP!
  5. Jul 18, 2008 at 9:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah......definitely get that looked at. toyota may buy that back from ya if the frame is rusted thru!!
  6. Jul 21, 2008 at 7:12 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    It looks like the leak is comming from the top side of the transfer case, check your fluid level, it could be over full and discharging it through your breather.
    Worse case would be the the case halfs are leaking which would require splitting and re-sealing.
  7. May 20, 2013 at 9:50 PM
    Scottyrocco16vdub
    Scottyrocco16vdub Well-Known Member
    Scott
    Latham, NY
    REally sorry to bring this back from the dead but my taco is having the same leaks... Never had a leak before, noticed a weird noise on a trip, found the transfer case oil level to be super low. The noise didnt go away after I filled it. I did notice the carrier bearing boot was ripped and had quite a bit of play. On my way back from the trip noticed a puddle under my truck from oil in the same places. Did the vibration of a bad carrier bearing mess something up? I have ordered new U joints and carrier from rock auto and should have it tomorrow to replace those, but is my transfer case/tranny toast???
  8. May 21, 2013 at 2:31 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    ^The t-case usually leaks from 1 of 2 places.
    First is the output flange for either the front or rear driveshaft. Clean up the rig, drive it around and look to see if the oil is coming from the spot where your driveshafts connect.
    The Second place is from the RTV gasket inbetween the two halves of the t-case. Again, clean it up, drive around and look at it.
    If it's coming from where the driveshafts connect, there are inner and outer seals you can buy and replace. You don't need to remove the t-case for this job. Just drain the oil, pull the driveshafts and remove/replace the seals.
    If it's from inbetween the to halves of the t-case, you need to remove it. Then take the bolts that hold the halves together out (6 or 7 I believe) and pry the case apart. It will only pull apart about a half inch or so. Be careful not to displace any of the internals. Clean all the old RTV off and lay down a heavy bead of "The Right Stuff". Close the case and torque. Replace the case and let it rest before refilling with oil.
    After that, you should be good to go!
  9. May 21, 2013 at 3:43 PM
    Scottyrocco16vdub
    Scott
    Latham, NY
    Excellent! Thanks for the help! I am very glad to hear I can change those seals with out removing the t case. I cleaned it up all yesterday and I am about to go check it out now. Does it have a vent? is there a chance I might have over filled it?
  10. May 21, 2013 at 3:51 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    if you have to pull the t-case it really isn't all that bad. like everyone is saying though, clean it, drive it, get under there and follow the trail of gear oil.
  11. May 22, 2013 at 5:17 AM
    nj636
    Kev
    Jersey
    sounds like you speak from experience? :rolleyes:
  12. May 22, 2013 at 5:28 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Looks to me that is been apart before and is leaking at the case half's.
  13. May 22, 2013 at 3:46 PM
    Scottyrocco16vdub
    Scott
    Latham, NY
    Well I have had it for a year and its never dropped a drip. but maybe it had leaked it all out... might have bigger issues... I want an 05+, I wish i wasnt poor and have no credit
  14. May 22, 2013 at 7:27 PM
    nj636
    Kev
    Jersey
    your looking at the OP's pics
  15. May 22, 2013 at 7:30 PM
    nj636
    Kev
    Jersey
    did you ever hop under an see where it's leaking from? post pics
  16. May 22, 2013 at 9:42 PM
    Scottyrocco16vdub
    Scott
    Latham, NY
    My transfer case and transmission looked identical to those pictures. I cleaned it all off on monday but it hasnt leaked since. It seems like a while driving thing. I have the first half of the rear axle out now to change the carrier bearing so I won't be able to drive it for a few days until I get the parts... and an impact wrench
  17. May 25, 2013 at 8:46 AM
    Scottyrocco16vdub
    Scott
    Latham, NY
    Well I got the new carrier bearing in. Drove around for about 15min, no load or hills, had no leaks. I am taking the dirtbikes to a place this morning a bit farther away so we will see if she leaks on that venture
  18. May 25, 2013 at 11:17 AM
    nj636
    Kev
    Jersey
    maybe theres no oil in it to leak out :notsure:
