transfer case leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by bamayota, Mar 9, 2011.
  1. Mar 9, 2011 at 7:29 PM
    bamayota
    bamayota [OP] Member
    Jayson
    Alabama
    '97 Tacoma 4x4
    wondering how to check the fluid in transfer case, it is pretty wet on bottom, its a '97 tacoma 4x4
  2. Mar 9, 2011 at 9:14 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Mine seems to 'sweat' a little but no actuall drip or leak that I've seen. Same thing is happening on my buddies '00 so not sure what it means.
    There is a fill plug about half way up the case. It looks like the head of a large bolt. Fits a 24mm socket IIRC. Remove it. You should feel gear oil by putting a finger in the opening. Its full if oil just barely come out when you remove the plug.
