Transfer case magnetic drain Plug
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dbd880, Feb 24, 2025.
  1. Feb 24, 2025 at 9:24 AM
    dbd880
    dbd880 [OP] New Member
    none yet
    Hi Team,
    I am a returning old member, finally getting back to maintenance on my 18 Tacoma 4x4. Recently did my first T-case oil change and noted it did not have a magnetic drain plug. Not finding a reference replacement on Amazon. Can you assist?
    Second question, when replacing front and rear differential oil, at 30k, rear was pretty clean but front was dirty. Any thoughts?
    She is my daily driver, on road, pretty much local grocery getter.
    Thanks Team
    Sorry if I am in the wrong category or is this is old news. This appears to be Encyclopedia Tacoma!
    Ngneer likes this.
  2. Feb 24, 2025 at 9:38 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    The t case as I recall doesn’t have one . Just the differentials do . As far as oil being cleaner than the other. I’m at a lost why the front would be dirtier than the rear …might be from having less gear oil … who knows .
    TacoMamba35 likes this.
  3. Feb 24, 2025 at 9:43 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Don't overthink either, you are good to go. You are already on the right path, change them sooner rather than later.
  4. Feb 24, 2025 at 9:51 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Changed my front diff oil about a month ago, and it was absolutely filthy compared to the rear. The magnet had a great deal more stuck to it as well.
  5. Feb 27, 2025 at 6:51 PM
    Jaragon
    Jaragon Active Member
    22 TRD Sport - Lunar Rock
    Skid plate for oil changes Cat shields for theft Snail Armor and pop lock tailgate LEDs and custom Inferno accents inside
    did this last week too, same.
  6. Feb 27, 2025 at 6:58 PM
    Bishop84
    Bishop84 Well-Known Member
    It's rarely actually used if you think about it, the only real gears are in 4 lo, the rest is just bearings and a union collar. Dont need to over think it.
    Chew likes this.
  7. Feb 27, 2025 at 7:05 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    There's a brass synchro in the T-case, whose wear products aren't magnetic. Not sure how useful a magnetic drain plug will be, but there are choices:
    This uses the same 10mm allen key as the front diff: https://trail-gear.com/magnetic-drain-plug-w-aluminum-washer.html
    This is the rear diff drain plug, which works on the transfer case as well: https://www.toyotapartsdeal.com/oem/toyota~plug~for~transfer~chain~case~90341-18057.html
