Transfer case oil - 80W-90 okay?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by littlefish, Sep 17, 2018.
  1. Sep 23, 2018 at 7:38 PM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    Royal Purple syncromax is LF type. The reason why the transfer case fluid is specific is because this transfer case as well as some GM transfer cases use soft metal (copper, brass) bushings in the syncros. LF type fluid is designed with low phosphate levels that will not deteriorate the bushings, unlike regular gear oil.
    tonered and NAAC3TACO like this.
  2. Sep 23, 2018 at 7:54 PM
    perryp
    perryp Well-Known Member
    Perry
    Great White North
    2013 TRD Off Road
    I changed the oil in the 2 diffs and transfer case about 2 weeks ago.
    Used royal purple 75w90 in all 3.
    After roughly 500 miles or so of driving I've notice a 1 mile per gallon economy.
    Never changed my driving habits either.
    So the $100 worth of oil will or just did pay for itself.
    Plus the added benefits long term.
    Front diff oil was dark, but not milky,...t case and rear diff were clear...
    Truck has 30k miles.
  3. Sep 23, 2018 at 8:19 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Yellow metal sync rings have been in transfer cases for decades. The erosion of bronz sync rings only occurs in situations where you are shifting constantly, and even then it’s rarely a problem. Unless you are constantly shifting from 2wd to 4wd and back all day long, you will never experience this. It’s a problem specific to MTs.
    The issue centres around the sulphur lubricant in GL5 oils combining with the bronze and making a harder surface coating, that may rub away slightly quicker during impact shifting. This isn’t going to be an issue in a transfer case, but hey.....what do I know? The 2nd Gen tacos had bronze components and used normal old GL5 80W90.
  4. Sep 23, 2018 at 8:33 PM
    Jh8473
    Jh8473 Well-Known Member
    Bowling Green
    2025 Tundra SR5
    None
    Maybe a GL 4 oil would be appropriate.
    specter208 likes this.
  5. Sep 23, 2018 at 9:20 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Redline MT85 is a GL4 75w85 oil that is safe for brass synchros . They claim on there website that it is a direct substitute for 75w and has two Toyota part#s listed.
  6. Sep 23, 2018 at 11:07 PM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    I'm about to do the diffs, trans, and transfer case... Missing my ranger that used ATF in the gearbox and xcase
