Transfer Case Oil Change ?
Discussion in '4 Cylinder' started by george3, Apr 8, 2024.
  1. Apr 8, 2024 at 6:26 PM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I've been changing the Diff and Transmission every 30K - I've also been changing the Transfer at the same time - I have 4 WD Manual - Wondering since I obviously use the Diff and the Transmission all the time and the 4 WD just once in awhile do you think I should continue to change the Transfer Case oil every time I do the Diff and Transmission ? Thanks for any reply/links/information.
    Williston likes this.
  2. Apr 20, 2024 at 2:30 PM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    I'd do it since you're already under the truck.
  3. Apr 20, 2024 at 3:47 PM
    george3
    New Jersey
    Sounds right - I mean write - never mind - Sounds correct to me - Thanks.
  4. Apr 20, 2024 at 4:01 PM
    Williston
    Williston Unknown Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    I think it's worth it. As you're already under there with all the tools and the fluids at hand, I'd treat them all to fresh fluid. Use the correct spec fluids in your diffs, transfer case and especially the manual transmission (GL4) and they'll last a very long time with a 30k maintenance interval. It's especially money well-spent for the transfer case: it's a critical piece out in the wild and they are very expensive to purchase and/or replace.
  5. Apr 20, 2024 at 5:49 PM
    george3
    New Jersey
    Yes - everything at 30K ! Thanks.
