Transfer Case Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pugga, Jun 30, 2010.
  1. Jun 30, 2010 at 9:56 AM
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I recently passed 30,000 mi and changed out the x-fer case, front end and rear end oils and came across something a little strange. I bought all the fluids in advance based on the owner's manual, which states gear oil is to be used in the transfer case. When I drained the case though, it had regular oil in it, not the familiar thick, smelly gear oil I expected to see. I called the dealership to make sure I was putting the right stuff back into the case but I wanted to see if anyone else ran across this or noticed? I'm guessing a lot of you still do your own maintenance.
  2. Jun 30, 2010 at 10:13 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    I used the same stuff I put in the rear. 75-90 synthetic
  3. Jun 30, 2010 at 10:46 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Do you mean your's had motor oil in it?
  4. Jun 30, 2010 at 10:54 AM
    TACOMA TRD
    Tom
    PA
    no....the transfer case oil was clear, my rear diff was black coming out. The rear is used hard compare to transfer case. The oil was still pristine. If you just put the 75-90 you should be fine. There are several threads on this.
