Transfer case output shaft bearing is dead...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Metallikatz3, Mar 10, 2010.
  1. Mar 10, 2010 at 4:49 PM
    Metallikatz3
    Metallikatz3 [OP] Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    So i've been trying to diagnose a vibration for a few weeks. I went to a 4x4 shop today for an alignment and to see if they had any thoughts.
    Turns out that output shaft bearing on my transfer case needs to be replaced. It is also leaking a little bit of fluid too. So I'm going to the dealer on Monday and hopefully they will cover it under my extended warrenty. I'm. Only at 90k miles and I've got another 20k or so before my warranty is up
    Anyone else had to have this replaced? and was it warrenty
  2. Mar 10, 2010 at 5:52 PM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    So this truck is lifted and you were running a driveshaft other than stock? Was that driveshaft balanced? What was the change in drive angle for the shaft? No pictures. No mileage. What are you after? Ammunition?
    You know, I am all for modding trucks and having fun, but...............If you want to be the engineer, you gotta write the warranty too.
    I know this post will not win me a popularity contest, but I just do not get it. Sorry. Perhaps more information will change my mind.
  3. Mar 10, 2010 at 5:54 PM
    ywen
    ywen Well-Known Member
    Tru dat.. this is shady as hell..
