Transfer case output shaft seals
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowhunter13, Mar 27, 2022.
  1. Mar 27, 2022 at 9:54 AM
    bowhunter13
    bowhunter13 [OP] Well-Known Member
    2002 silver Tacoma
    2002- Toytec Lift/Suspension, Total Chaos UCA
    This is probably a dumb question but I have a 2002 with a automatic trans and I guess a manual 4x4 transfer case (not the push button 4 wheel drive). I have looked all over and was wondering is both front and rear output shaft seals the same? The one that is leaking on mine is the front output shaft. I was also wondering how you figure out what transfer case you have? I ordered part # 90311-41012.
  2. Mar 27, 2022 at 12:39 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Was the truck 4wd swapped?
    A 2002 wont have a manual tcase from the factory.
    Toyotapartsdeal.com has a pretty decent database that you can search.
    I believe this is the seal you want. But you'll want to verify for yourself. It's calling it out as the front output seal for a 2002.
    https://www.toyotapartsdeal.com/oem/toyota~seal~oil~for~transfer~case~90311-41010.html
    The one that I linked is calling out that it was replaced by the part number you ordered.
    bowhunter13[OP] likes this.
  3. Mar 27, 2022 at 1:06 PM
    bowhunter13
    2002 silver Tacoma
    Thanks @El Taco Diablo! I typed my Vin in on toyota's website and it says it was a 4x4 from factory but doesn't give me any details on the transfer case
  4. Mar 27, 2022 at 1:10 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    But you don't have a button on the 4wd shifter?
  5. Mar 27, 2022 at 1:14 PM
    bowhunter13
    2002 silver Tacoma
    No it doesn't have a button. It does have the ADD or whatever it's called that engages the front differential but the transfer case itself is manual. When I was doing searches on here before I posted I did find a thread and it sounded like quite a few people has the manual transfer case instead of the electronic push button.
  6. Mar 27, 2022 at 1:21 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Right on. That's wierd though. I thought all post 2000 had a button.
    Regardless... looks to me like you ordered the correct seal.
  7. Mar 27, 2022 at 1:46 PM
    bowhunter13
    2002 silver Tacoma
    Makes things confusing haha . But thanks for the info I appreciate it!
  8. Mar 27, 2022 at 1:50 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    J shift was available through the later years of 1st gen, manual hubs were last used in 2000 though iirc.
    Not sure on the seals question
  9. Mar 27, 2022 at 1:53 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Maybe that was what I was thinking about with 2000.
    At any rate :thumbsup:
    eon_blue[QUOTED] likes this.
