Transfer case question?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fore, Jul 9, 2009.
  1. Jul 9, 2009 at 5:44 AM
    Fore
    Fore [OP] Well-Known Member
    07 PreRunner
    First time post for me I've got to break the ice sometime. I have a 2007 Toyota Tacoma Prerunner V6, 2WD Automatic 48,000 miles. I've changed the differential fluid already and I would like to change the transfer case. I can see the fill plug but cannot see any drain plug anywhere. Can someone help me with this. I can see it in the pic's here on TW web site but their showing a 4WD transfer case and not a 2WD transfer case. Thanks for your help!
  2. Jul 9, 2009 at 5:53 AM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    A pre-runner doesn't have a transfer case, the driveshaft will be driven straight off the tail of the tranny. A transfer case is only needed to drive more than one shaft off of a common input (ie front drive shaft for 4x4 or a Power Take Off for a utility application).
  3. Jul 9, 2009 at 5:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    There is no transfer case on the Prerunner. :) Welcome to Tacoma World!
  4. Jul 9, 2009 at 6:00 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Welcome to TW. Are you meaning Transmission?
  5. Jul 9, 2009 at 6:03 AM
    Brunes
    Brunes abides.
    Rotorhead
    Welcome to the board- I think your trans is a sealed unit..and like was said...no transfer case.
    Hope we can help you out!!
  6. Jul 9, 2009 at 6:24 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    This has potential disaster written all over it. He found a plug on a non existent part. Later today we will be reading "Help I've drained my Transmission Fluid" j/k
    BTW welcome to TW.
  7. Jul 9, 2009 at 6:28 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Think we have heard that before, but normally with the oil and Transmission.
  8. Jul 9, 2009 at 7:15 AM
    steviestyles
    Colorado Springs
    Bone Stock
    :ohsnap:
  9. Jul 9, 2009 at 7:26 AM
    Fore
    07 PreRunner
    Thanks for your replies and yes I am talking about the transfer case and not the transmission (That's a no brainer) I've already changed the oil to synthetic and the spark plugs using TW mods, just trying to give it a good go around I bought this TACO with 45,000 miles on it already and I have no idea how it was taken care of by the previous owner. The darn Toyota manual states 1qt for the transfer case so I thought maybe it had one. Should I go ahead then and change the transmission fluid and what other do's and don'ts should I change?
  10. Jul 9, 2009 at 7:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    do not touch the tranny
  11. Jul 9, 2009 at 7:49 AM
    Hops
    Hops Well-Known Member
    Gabe
    south mississippi
    08 Silver Streak Mica Access Cab 4X4
    Shock and leaf spring TSB, Neoprene seat covers, weathertech digital fit floor mats, vent visors, bug shield, secondary filter removed, K&N drop-in filter, century camper shell, 265/75R16 ATM's...
    Make sure it has fresh blinker fluid...
  12. Jul 9, 2009 at 9:06 AM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    What do you not understand. 2wd does not have a transfer case, this my friend is a no brainer.
    FAIL.
  13. Jul 9, 2009 at 9:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    The no brainer here is you should be taking your truck to a certified mechanic for servicing...Best of luck finding one your trust to do good work!!:rolleyes:
