Transfer Case Rear Output Shaft - Shifting Keys Question MT/AT w/o ADD
Discussion in '1st Gen. Tacomas (1995-2004)' started by Area51Runner, Feb 27, 2022.
  1. Feb 27, 2022 at 3:34 PM
    Area51Runner
    Area51Runner [OP] Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Hoping a couple of you familiar with transfer case tear down can chime in. The case I have here was listed as an AT but I am finding it has shifting keys on the Rear Output Shaft assembly.
    According to the 2002 & 2003 FSM's this only applies to manual transmission cases. Can anyone confirm this is correct?
    Borrowing a graphic from @turbodb -
    As you can see, this tcase has an 'automatic' input shaft
    If it is in fact specific to a Manual Trans case, then I need to start searching again. o_O
    Yota X likes this.
  2. Feb 27, 2022 at 5:50 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    This got me interested, and I did some more digging. Apparently, I didn't do enough digging when I was researching a month ago, it seems. Or, perhaps I just took for granted, something someone else posted, I don't know.
    Anyway, your photo caught my eye because of this:
    ... note the w/o ADD at the top, which I don't have (for some reason - either someone posted the original without it or I cropped it out by accident) on my photo
    Here's another diagram from the FSM. Note that in this diagram - w/ADD - that both the A/T and M/T cases have shifting keys on the Rear Output Shaft assembly (though the M/T has them on both ends, while the AT only has them on one end). Most likely, I didn't really pay too much attention to those keys in the diagram, b/c I was looking for attributes of the transfer case that were identifiable from the exterior - and so I focused on shaft length and the little hole on the A/T input shaft.
    Anyway, hope that helps, and sets you at ease a bit. I think you still have an A/T case. And, I'll be updating my images.
  3. Feb 27, 2022 at 6:11 PM
    Area51Runner
    Thanks, appreciate it Dan. I'm actually going to just take that input shaft completely apart.
    When you look at the FSM image, it shows that there should be only 1 snap ring - at the end of the output shaft. Then we have a high and low clutch sleeve.
    The Manual trans shows a snap ring, then the high/low clutch sleeve with the shifting keys held in place by 2 'shifting key springs' (snap rings, right? lol) followed by the low clutch hub.
    I'll update after I pull that first snap ring and see how the rest is assembled on the shaft.
    I imagine you're right, it is still an AT case and just the FSM is wonky (which has happened before).
    turbodb[QUOTED] likes this.
  4. Feb 27, 2022 at 6:14 PM
    Area51Runner
    As an after thought, you could always take apart your original ;):boink:
  5. Feb 27, 2022 at 6:26 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Oh, I plan to. I just want to wait for a bit warmer weather as I'll be doing it outside (well, in an unheated space). :)
    I will say, I've been following along with you taking yours apart with baited breath. Helps to make it a little less daunting for me.
    (Also, I've updated all my images in my various posts to show both the w/o ADD and w/ ADD variants.)
  6. Feb 27, 2022 at 9:37 PM
    gearcruncher
    Canadain bumper technician
    Area51Runner[OP] likes this.
  7. Feb 27, 2022 at 10:11 PM
    Area51Runner
    Pulled up the 95/96 FSM and essentially shows the same - a difference between AT and Manual. Not suprised since this tcase design has some major mileage. The mystery remains.Note: this case I have here is out of a 95 tacoma.
    Tomorrow will put the thing on the press and remove the clutch hub. Will need to if I want to gain access to those key springs and key retainer... hey, have to put it back together, right? Can't leave those shift keys floating about and expect it to function :eek:
    If anyone with an "automatic" tcase wants to pull it apart and confirm the presence of those keys... :bowdown:
  8. Feb 27, 2022 at 10:13 PM
    Area51Runner
    Here is where they should be (shifting keys) -
    Close up - You can see the 2 snap rings errrrrr... Shift Key Springs (highlighted in yellow).
    gearcruncher likes this.
  9. Feb 27, 2022 at 10:15 PM
    Area51Runner
    Your two threads are full of info unfortunately most of the links I think would really tell the tale are dead. It really is too bad that some of those PDFs weren't preserved on any site, including the wayback archive. I do thank you for the links and your threads, lot of good info there.
    gearcruncher[QUOTED] likes this.
  10. Feb 28, 2022 at 12:46 AM
    gearcruncher
    I know . Both are old threads from back in the day when information was less accountable .
    I do need to spend time and clean the threads up .
    So sad that a lot of the links went dead . I wish there was a way to revive them .
    I think its up to members like us to figure out a way to revive those links .
    I beleive Toyota corporate killed those links for us . Been trying to figure out how to restore them for a long time .
    I have almost every FSM from 1995 -2020 in Pdf format .
    How do we make these work on a website ?
    I beleive all it would take is 1 member from Tacoma world to pay a subscription to the website , from there if he shares his information it would be totally legal .
    I have tried but nobody wants to commit
    https://www.tacomaworld.com/threads/how-do-we-make-these-links-work-again.697429/
    Thoughts ?
    Area51Runner[OP] and Matic like this.
  11. Mar 3, 2022 at 3:34 PM
    Area51Runner
    Something I noticed today...
    Abrasions from the chain? Sure looks like it.
    Two different bearings on the driven shaft. Koyo (is the one making noise) and a Nachi. On the planetary Gear shaft a single Nachi bearing.
    I have to replace the koyo bearing because it is noisy and I want to rule it out. The chain looks fine though. Not sure why the chain would have been impacting the case before. More to follow, just going slow (lack of motivation lol).
  12. Mar 3, 2022 at 3:37 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    I got my j case from an auto trans and it had those stupid things. I had to take it apart several times and they fought me every time. Diagram was identical as well.
  13. Mar 3, 2022 at 4:20 PM
    Area51Runner
    Thanks for confirming you had them too. Going to chalk it up to a typo in the FSM.
    Also fyi to any embarking on dissasembling the planetary gearshaft (w/o ADD), pay special attention to the spacer and ball. The spacer slides right off the shaft and then the ball just sits lives in its spot. its easy to knock it out of place and tiny enough if it rolls off the table, well enjoy the hunt. USE a magnet to grab it right away and secure it.
    turbodb and Yota X[QUOTED] like this.
  14. Mar 3, 2022 at 4:25 PM
    Yota X
    NW New Jersey
    1st gen
    I didn't take the shaft apart. I just cleaned out the case and made sure everything looked good. I don't think it came out or I would have seen in my work pan. I had never taken one apart and I reassembled it in the big part of case instead of the small half like a donkey and it was really hard to get those keys to stay in, while getting forks in holes and keeping chain and output gear all in same place.IMG_3141.HEIC.jpg
  15. Mar 3, 2022 at 6:37 PM
    Area51Runner
    Even though this guy is working with a 2017 tcase, the similarities are enough where its been super helpful. Definitely suggest watching for anyone who takes on this job.
    https://youtu.be/DlOm8_Tt81c
  16. Mar 3, 2022 at 6:57 PM
    Area51Runner
    Another very important note (and I'll edit my first post), I sure wish I had come across @hoverlover's post before pulling the transfer case apart (@turbodb FYI DUDE) -
    and after additional creative TW searching I have a solid lead...
    SHIFTING KEYS live here!
    04Pre_Runner and turbodb like this.
  17. Mar 3, 2022 at 7:12 PM
    gearcruncher
    The pictures show signs of the chain possibly slinging something mettalic up against the inner casing.
    I know you had bad bearings on the output shaft for 4x4 .
    Did you see a bunch of metal lying in the transfer case when you took it apart ?
    If the chain were rubbing on your outer casing , you would certainly be hearing it .
    Maybe on a truck that ran 1,000000 miles in 4x4 .
  18. Mar 3, 2022 at 7:31 PM
    Area51Runner
    Negative. Nothing. No chunks, no slivers. Magnet had just a few small particles on it. I'm thinking that someone went into the case and replaced that one bearing with a koyo (for whatever reason). 2 of 3 Nachi bearings and 1 koyo straight from the line seems odd. Oh well. Just want to button this thing back up and move on with the list.
  19. Mar 3, 2022 at 7:37 PM
    Area51Runner
    FML :facepalm:Haste certainly does make waste... lol
  20. Mar 4, 2022 at 3:37 AM
    gearcruncher
    Button the transfer case back up . Makes sure it shifts through the gears spinning the input shaft by hand and send it .
