Transfer case removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Metallikatz3, Mar 15, 2010.
  1. Mar 15, 2010 at 9:10 PM
    Metallikatz3
    Metallikatz3 [OP] Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Has anyone removed a transfer case from an automatic transmission truck?
    The FSM says that you have to take off the trans too, but it doesn't look like that is necessary and I am hoping to aviod doing that.
  2. Mar 15, 2010 at 9:13 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    why do you wanna/need to remove t case? you can drop the t case/tranny as a whole. but if you just wanna drop the t case you haved to seperate. un less you have a swapped in divorced t case
  3. Mar 15, 2010 at 9:19 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Long story short I'm a dumb ass and need a new transfer case lol. I'm planning on getting a new one out of a wrecked truck and swapping it in.
  4. Mar 15, 2010 at 9:21 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    :popcorn: and why are you a dumbass :D
  5. Mar 15, 2010 at 9:24 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    I got a used Tom Wood's drive shaft, that it turns out was too long. It only only had about 1/4" of play in the slip yoke. So everytime I hit a bump or loaded my truck it compressed, pushing into the transfer case and wrecking the output bearing and who knows what else internally.
    Toyota obviously won't warranty it, getting it rebuilt is gonna cost a lot. So I found some used for around $500 which sucks, but its gonna be the cheapest route
  6. Mar 15, 2010 at 9:24 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2, we'll go easy on you.:D
    edit, thats not too bad, at least you didnt try to put it in 4lo going 80 mph lol
  7. Mar 15, 2010 at 9:26 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    lol thanks. Modifying anything can have a pretty steep learning curve and sometimes it hurts in your wallet to find stuff out the hard way
  8. Mar 15, 2010 at 9:27 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    i did that on a jeep. hit a big hole and pushed the front d shaft into my aluminum np231 case. split it in half.
  9. Mar 15, 2010 at 9:30 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    hey...thats pretty badass if you take out the 4wd fuse....dont ask how i know...but youll be fast as hell between 0-45....
  10. Mar 15, 2010 at 9:30 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    damn, at least I can still drive my truck.
  11. Mar 16, 2010 at 7:05 AM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Bump... anyone know?
  12. Mar 16, 2010 at 6:38 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Please help me lol...anyone know?
  13. Mar 16, 2010 at 8:41 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    I was crawling underneath my truck on Saturday replacing the ATF. I don't see why you'd have to pull the trans to get the transfer case out. I wasn't specifically looking at the t-case wondering if it could be done though so maybe I missed something obvious. The FSM tends to overdo it a bit. When I took out the headliner to do some work I read that section and it basically said take the entire interior out of the truck. With the wheel bearing it says take the whole upright out. I wouldn't be surprised to see them tell you to take the whole engine out to get the t-case out, honestly.
    Go crawl under there and see what you're dealing with.
  14. Mar 17, 2010 at 3:30 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Yeah i've been looking at it too and I think that I can get it out without dropping the trans. I was just wondering if anyone has ever done it
  15. Mar 17, 2010 at 3:38 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    not sure on taco's, but on the jeeps i have dropped t case's on. it helps get at the top t case bolt to loosen the crossmember and maybe a few trans bolts to let the tailshaft of the tranny clock down a bit. i will be droppin my first gen t case this weekend. to do a complete overhaul. i dont know how similar the job is between 1st and 2 nd gens but i will let ya know any problems during the process.
  16. Mar 17, 2010 at 3:45 PM
    djs05tacoma
    djs05tacoma Well-Known Member
    Martinez, CA
    05 Double Cab TRD offroad 4x4
    3" OME Lift, 285's
    Not sure about toyota but a fsm for my old ford said to remove the transmission then remove tcase for work, definately wasnt the case, tcase came ot easily while trans was in the truck. Its definately worth trying to take the tcase off by itself since I'm sure it would take much less time if it works out.
  17. Mar 17, 2010 at 3:49 PM
    Red Razor
    Red Razor Well-Known Member
    Greensburg PA
    06 TRD Sport 4X4
    Just a quick look at my Haynes manual instructs removing the TFC/Trans as an assembly. It says you may be able to remove TFC without the trans, but the trans may need to be lowered for clearance.
