Transfer Case Seal Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bshammer0, Jan 18, 2023.
  1. Jan 18, 2023 at 1:52 PM
    bshammer0
    bshammer0 [OP] Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Hi Folks - Having not returned a clear write-up / video from my search, hoping there's some expertise to help! I have a leak in my transfer case due to an issue with the seal as it appears has happened to many forum members. My shop has quoted an (to me) astronomical $700 to replace the seals with most of that being labor.
    I know there are several write-ups on fluid exchange / gasket replacement, but how involved is the seal replacement? I'd prefer to do it myself but will also recognize my limits :)
    Service Quote:
    Transfer Case Seal Leaking Fluid. 01/18/2023
    Remove and Replace components as required to access and install materials, and/or perform needed service, adjustments as
    required. Additional fluids may be required to complete this service. Retest and verify repair as required. Perform final road test where
    applicable.
    Labor $655.31 *S
    SEAL, TYPE T OIL $20.40 *S
    SEAL, TYPE T OIL $24.75 *S
    Parts Cleaner - Non Chlorinated $14.24 *S
    Gasket, Diff/ T Case 18mm Aluminum -A0003 - OE $3.48 *S
    ATF - World Standard WS TLS-LV Toyota/LexusFactory Fill $20.50 *S
    Sub $738.68
  2. Jan 19, 2023 at 5:21 AM
    bshammer0
    Brandon
    Nashville, TN
  3. Jan 19, 2023 at 5:33 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Depends where it is leaking from. Output shaft seals or the marriage to the trans. Quote calls out WS which is transmission fluid. T-Case uses 75W LF. I would assume it is leaking between the trans and case which would involve removing the case, cleaning both mating surfaces, installing new gasket, reinstalling case, then servicing trans. Labor isn't too bad for a shop.
    na8rboy and bshammer0[OP] like this.
