Transfer Case stuck in Neutral?
Discussion in 'Technical Chat' started by JimmyIvine, May 14, 2009.
  1. May 14, 2009 at 1:36 PM
    JimmyIvine
    JimmyIvine [OP] Active Member
    Alberta
    2.7 Liter
    3 inch lift
    How do I figure out weather my transfercase is stuck in neutral. and how do I find it...Bare with me here im still learning lots
  2. May 14, 2009 at 9:52 PM
    dubber
    dubber Member
    '04 Taco 4x4 TRD
    If your transfer case is in neutral would you not be going no where if you gave it gas while in gear (i.e. first gear or drive if it is an auto)? I don't know, I have never tried it. I just switch from 4L to 4H when need be.
    What seems to be the problem?
  3. May 14, 2009 at 9:59 PM
    dubber
    dubber Member
    '04 Taco 4x4 TRD
    As for finding the transfer case it is under the truck. You can follow your drive shaft from the front end. The drive shaft heading to the front diff comes off the transfer case. This is the way it is on mine.
    What year/model is your truck?
  4. May 14, 2009 at 10:36 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Does your truck move under it's own power?
    If so than no
