Transfer Case stuck in Neutral?
Discussion in '4 Cylinder' started by JimmyIvine, Sep 2, 2009.
  1. Sep 2, 2009 at 7:09 PM
    JimmyIvine
    JimmyIvine [OP] Active Member
    Alberta
    2.7 Liter
    3 inch lift
    do i just take my drain my transfer case an take it right off to see if its stuck in neutral or is there another way.
    Thanks fellas
  2. Sep 2, 2009 at 7:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What do you mean its stuck?
  3. Sep 9, 2009 at 4:13 PM
    JimmyIvine
    Alberta
    2.7 Liter
    3 inch lift
    is it possible that if my truck is somehow stuck in 4x4 neutral and that could be the reasoning that im not getting any movement in 2x4 and 4x4 low. Would that lock out 2wd if it was somehow stuck in 4x4 neutral
  4. Sep 13, 2009 at 6:29 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    Just something to try. Last winter my transfer case got stuck and I couldn't get it to go back into 2WD. I orbited a parking lot about 20 times playing with it until I realized that there is an electronic switch which is activated when the clutch is fully depressed, allowing the TC to be shifted. I removed my floormat, depressed the clutch to the floor and all was good in the world once more. Good luck.
  5. Sep 17, 2009 at 9:40 AM
    tacoma-king
    tacoma-king Well-Known Member
    sault ste. marie Michigan
    1997 Tacoma
    hitch
    that electronic switch is nothing more then a safety switch that does not let you start the truck unless the clutch is all the way to the floor
  6. Sep 17, 2009 at 9:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    He has a first gen which is manually operated.
    To the OP, yes if the transfer case is in neutral you will not have any movement. Shift it into 2HI and leave it there for 2wd.
