Transfer case stuck in neutral
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JAGCanada, Nov 11, 2022.
  1. Jul 29, 2023 at 1:27 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Great write-up & diagnostic work, thanks for sharing. 19 out of 20 dealers or mechanics woudl've probably just said, "Needs a new transfer case. Have a nice day."
    Surprised that the Tacoma's electronic 4WD shifting system even attempts to execute a 4LO shift while the vehicle is still in motion. You'd think that the ECU could use the ABS wheel-speed sensors to see that the wheels are still moving & delay that 4LO actuation attempt until they are completely at rest? Truck locks out shifting into 4HI above 62 mph -- why not lock out 4LO until 0 mph is registered for at least a full second?
  2. Jul 29, 2023 at 1:38 PM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    So will you continue to run the used transfer case or swap this "fixed" one back in. Great workup and pictures really help..
  3. Jul 29, 2023 at 1:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Thanks for the update.
    Good work on figuring it out:thumbsup:
    JAGCanada[OP] likes this.
  4. Jul 29, 2023 at 2:10 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Hell yeah dude! Getting at the bottom of the barrel. This sounds like it’s the issue. Keep us posted.
  5. Jul 29, 2023 at 3:41 PM
    JAGCanada
    JAGCanada [OP] Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    The dealer did say "needs a new transfer case"....in the dealer's defense it would be more economical just to replace this unit than to pay a dealer to try and figure out what went wrong. I bought a used tcase from a wrecker for about CAD$400 and put that in. Dealer quoted me CAD$1,000 for a used case plus labour. Given I have owned this truck since new, I didn't want to just toss the tcase out - opening it up also presented a learning opportunity.
    I am pretty sure there is a speed limitation set up in the software to shift from 4H to 4L...something like 3 km/hr. I was going very slow when I shifted to 4L, but I wasn't stopped. I won't make that mistake again.
  6. Jul 29, 2023 at 3:44 PM
    JAGCanada
    Canada
    No sure yet....fingers crossed just replacing the cracked hub fixes the issues. I most likely will leave the one in the truck in the truck and keep the repaired one as a spare. I also have a used FJ case that I picked up....just need to get up the courage to cut a hole in the floor and cut the shift console up.
    Williston likes this.
  7. Jul 29, 2023 at 8:26 PM
    babylon5
    David
    You mentioned you changed the TCASE lube every 2 years? What did it look like? I changed mine at less than a year when I did all the drivetrain and it looked so clean I wondered if it was even worth it. I did add a magnetic drain as added protection but I didnt see any evidence of metal particles in the lube.
  8. Jul 30, 2023 at 5:54 AM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    You won't be sorry when you swap in the FJ Case... I PROMISE!
  9. Jul 30, 2023 at 6:00 AM
    JAGCanada
    Canada
    At 2 years the oil still looked good. I think the suggested change interval is 30k miles for the tcase oil and I drive less than 30k miles in 2 years, so I suspect I could leave it longer.
    EDIT. I drive ~25K miles in 2 years, so I am a bit on the early side of the recommended change interval.
  10. Jul 30, 2023 at 6:44 AM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Wow. Certainly never seen this before. Kudos to you for the patience troubleshooting and tearing down the tcase to find the problem, and thanks for sharing.
  11. Jul 30, 2023 at 4:04 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    Awesome to see you back on the road and a great post with follow up. Thank you! My truck beeps and will refuse to shift to 4L unless the transmission is in "N" as per normal. I have never tried it (in either direction to/from 4L at anything other than a dead-stop.) Interested to know if the hidden fatal flaw is the movement when attempting this shift, no matter how slow the speed or it's direction. It's good thing to know considering the possible expensive damages or "strandedgees". ;)
    I experienced one of these "glitches" when I screwed up and shut the truck off (far from home) while it was in the process making a shift back from 4L to 4H. This is a big "No-No" as I have since learned. It makes the ECU in charge of this to get into a little snit. When I started it up again, I initially got the beeps, but no effort into shift back into 4H. After a shift to Park and another attempt from Neutral, it returned to 4H with a good "warning clunk". Tip: Don't turn the key to "off" during a 4H to 2H shift either (or vice versa). It gives the 4x4 ecu fits: as documented here elsewhere, worst case scenario is you're taking stuff apart to fix it... or paying those guys in: "National Lampoon's Vacation" to fix it for you. :eek:
    Lesson learned here: Don't ever turn off the truck when the ECU is in the process of making a mode-change.
    I have never again "exercised/tested" a shift into or out of 4L anywhere: running, shut off, or anything else other than in my driveway.
    JAGCanada[OP] and dborrer like this.
  12. Jul 30, 2023 at 4:26 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Great work OP!
  13. Dec 28, 2023 at 1:25 PM
    JAGCanada
    Canada
    I purchased a new hub and had to press it on with the hydraulic press. Bench tested the actuator worked fine moving in and out of 4L. Put the tcase back together and now sitting in the garage as a spare.
    What I found interesting was that new hub (top part in image below) had more of a radius in the corner than the old one that cracked (bottom one in picture below with white paint). Radius in corners like this help reduce stress concentrations, that lead to cracking....
    Littles, Dm93, TnShooter and 2 others like this.
  14. Dec 28, 2023 at 1:58 PM
    Williston
    Thanks for posting this story and circling back to give us the RFO.
    Just to document: Per owners manual for my 2014: Manual transmission: Less than 2mph for a shift into or out of 4L: >>Less than 2 mph<<. Margin-of-error there: Lets face it: pretty much/close to essentially: "0". Considering the risk of the damage in the scenario outlined here, I would never to it. (specs for an automatic are: Neutral/foot on brake and hold/shift.)
  15. Dec 28, 2023 at 2:35 PM
    #35
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Awesome thread. Thanks for coming back and updating us with pics along the way :thumbsup:
    Interesting note about the radius. My money would be on that as the root of the failure. I have always 'rolled' into and out of 4Lo, anything under 2 mph has been fair game. Ive found being at a dead stop doesn't always let the gears mesh. At which point have to drop it into gear to move everything, leading to a loud bang as it finally meshes.
    Definitely will have to remember to slow it down a little in future 4Hi <-> 4Lo shifts though just out of caution
  16. Dec 28, 2023 at 3:21 PM
    #36
    Williston
    Wanted to also add an extra thank you for providing those great, clear pictures of the transfer-case internals: something us "shade-tree" guys rarely get to see. They really shout: "Old School" which is a positive to me. The chain is especially impressive. A real treat. The pics of the cracked hub-sleeve made my eyes hurt. ;)
    Dm93, SR-71A, dborrer and 2 others like this.
  17. Dec 28, 2023 at 4:13 PM
    #37
    TnShooter
    Deogee
    STOCK
    Thanks for the update (again).
    Always good to know and see what parts have been updated.
    Thanks again!
    Dm93 and LooneytuneSR5 like this.
  18. Dec 29, 2023 at 6:47 PM
    #38
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Very interesting issue, thanks for sharing.
    I linked this thread in my 4wd help thread.
    The 4wd ECU will not allow a shift into or out of 4L above 2 MPH with the trans in neutral (A/T) or clutch depressed (M/T) so I doubt it was caused by shifting over the recommended speed, looks more like a defective casting.
