transfer case- to repair or replace?
Discussion in '1st Gen. Tacomas (1995-2004)' started by double0taco, Nov 27, 2024.
  1. Nov 27, 2024 at 5:13 PM
    double0taco
    double0taco [OP] Member
    Dianne
    00 black tacoma pre runner 2.7 and 3.4 TRD
    hey yall lol, noticed my transfer case is kind of caked in fluid and seems to be leaking but i don’t know from where. for some background- truck has a brand new driveshaft, and whole new axel with new(er) locking diff in the back, and all new rear suspension, so i’m trying to work my way to the front on this trucks issues since i need to do my clutch soon aswell. Ive done research on a few places in maryland, but was wondering, if something is wrong, replace it completely? (oem/other)? get it fixed? cost estimates? facility recommendation? Anything u know about t case repair and replacement will be beneficial!! thanks so much!!
  2. Nov 27, 2024 at 5:15 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Different truck but when I stripped the threads on my 2nd gens case they said it's not really cost effective to rebuild it but just better to replace it with a low mile used case which is what I went with
    double0taco[OP] likes this.
  3. Nov 27, 2024 at 5:16 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    First thing you always do is to CLEAN it. Let it dry then you can see where the leak is coming from. Get some degreaser or go to the "quarter car wash" and clean up the case.
    tsab916 likes this.
  4. Nov 27, 2024 at 9:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is there oil dripping when parked? Does your t-case work to engage 4WD?
    Check the fluid level. Top in off if it is low. And do as @Kleenax suggested. Clean off the grime and see where it might be leaking from.
    FWIW, there is a breather vent at the top of the t-case. If the breather is clogged and not functioning, it might cause some gear oil from inside the case to seek out of the top seal on the case.
  5. Nov 27, 2024 at 10:14 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Please let me know if you want someone to dispose of such dirty transfer case. Thank you!
  6. Nov 27, 2024 at 11:41 PM
    PaulyFromLA
    PaulyFromLA Well-Known Member
    Pauly
    1st gen tacomas
    Ones a camper, ones oem, ones a flatbed
    spray seal lol
