Transfer Case Vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bushknight, Oct 28, 2009.
  1. Oct 28, 2009 at 2:59 PM
    Bushknight
    Bushknight [OP] Member
    Alberta
    01 4x4 Double cab V6
    I was stupid and let my transfer case run low on oil. Now it has a vibration at highway speed. What should I do?:mad:
  2. Oct 28, 2009 at 3:03 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I don't know what to do sorry but if you have a girlfriend or wife keep it that way she'll enjoy the ride more. Just kidding. Sorry I couldn't resist.
  3. Oct 28, 2009 at 3:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw.
    have you added oil and it still vibrates?
  4. Oct 28, 2009 at 3:09 PM
    Bushknight
    Alberta
    Yes I Did. 75 90
  5. Oct 28, 2009 at 3:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hmmm. could have dried a bearing up too much. have you tried greasing the front drive shaft and see if that helps?
  6. Oct 28, 2009 at 3:18 PM
    Bushknight
    Alberta
    No, but good idea. I will do that. Thanks
  7. Oct 28, 2009 at 3:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    do that and see if it helps out....and let me know.
  8. Oct 28, 2009 at 3:49 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Whatta ya mean by...'vibration'?
    Are you sure its coming from the t-case?
  9. Oct 28, 2009 at 7:32 PM
    Bushknight
    Alberta
    The vibration is coming from below my seat. I believe it is the Transfer case.
  10. Oct 28, 2009 at 7:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Could be a rear tire out of ballance....
  11. Oct 29, 2009 at 10:25 AM
    Jason'sLawnCare
    Couldn't it also be the driveshaft. My driveshaft has what looks like tire weights on it.
  12. Oct 29, 2009 at 6:03 PM
    Bushknight
    Alberta
    I will take a look and see if it may have had some weights before.
  13. Oct 29, 2009 at 6:07 PM
    seareef
    seareef Well-Known Member
    Ron
    Lake Elsinore CA
    Bitch Magnet
    add some lucus to that gear oil
  14. Oct 30, 2009 at 5:03 AM
    Bushknight
    Alberta
    what does Lucus do?
  15. Oct 30, 2009 at 5:45 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    its an additive, but i cant see it really doing much.
  16. Oct 30, 2009 at 6:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    It will aerate the oil pretty good.
  17. Oct 30, 2009 at 7:14 AM
    Janster
    Jandy
    Lancaster, PA
    Crawl under the truck and start looking around. Look for loose bolts, worn bearings, anything and everything that could be going bad or coming apart.
    Check u-joints....
    When was the last time you greased the u-joints or did a diff service?
  18. Oct 30, 2009 at 6:37 PM
    Bushknight
    Alberta
    sad to say, never
  19. Oct 30, 2009 at 8:27 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    well then you know where to start.
  20. Nov 2, 2009 at 11:41 AM
    Bushknight
    Alberta
    Greased it all, oil level is good, installed winter tires that I know are well balanced and the vibration is still there. must be the transfer case. Does any one know if i pull it off the tranny what is involved. I thought i could save some money if i take it off and bring it to tranny shop or Toyota to repair then install it back my self. would i only save a couple of labor hours. the rate hear is $115/hr
