Transfer Case went out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by toddulu, Mar 1, 2022.
  1. Mar 1, 2022 at 12:24 PM
    toddulu
    toddulu [OP] Active Member
    Todd
    Fresno, CA
    2019 Cavalry Blue TRD OR DCSB
    2016 DCSB SR5 2WD 3.5L 74,XXX miles
    I recently started feeling a shimmer/shake in my truck when accelerating between 20-40MPH at low RPMs & the truck felt a bit sluggish. I initially thought I maybe had some bad winter blend gas, so I bought some chevron fuel system cleaner which didn't fix the issue. I did a little research on here and thought maybe it needed a transmission fluid exchange so I decided I'd bite the bullet & dropped it off at the dealership this morning. I just got a call back from the service adviser & their diagnosis was that the transfer case needs to be replaced, a $2K+ repair.
    The silver lining for this is I bought the truck certified preowned from a Toyota dealer, so there is a 100K mile powertrain warranty through that program, so all I have to pay is $50.
    I asked the service advisor if he's seen this before or what may have caused this to happen, he had no idea and had never seen this on a 3rd gen Tacoma. Anyone heard of this before?
    Tocamo and Mark77 like this.
  2. Mar 1, 2022 at 12:28 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Need more information. What went wrong with the transfer case?
    Chew likes this.
  3. Mar 1, 2022 at 12:28 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Did they say what was actually wrong with the transfer case or just that you needed a new one?
    Chew likes this.
  4. Mar 1, 2022 at 12:30 PM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    It's not Friday
    It's not April 1st
    So, when did 2WD trucks start getting Transfer Cases?????
    Chew, manwithtools, MOC221_ and 16 others like this.
  5. Mar 1, 2022 at 12:31 PM
    gudujarlson
    Minnesota
    Lol. I didn’t notice he has a 2wd until you pointed it out. Nothing is adding up here.
  6. Mar 1, 2022 at 12:34 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    the transfer case is only used in 4wd. you got scammed. you sure they didn't replace the torque converter?
    Chew likes this.
  7. Mar 1, 2022 at 12:35 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I mean he's definitely got a transfer case problem...... it's missing one.
    Chew, philth, Yota X and 4 others like this.
  8. Mar 1, 2022 at 12:36 PM
    tstack22
    tstack22 Well-Known Member
    Arizona
    '22 TRD-OR 6MT
    Maybe he means the differential?
  9. Mar 1, 2022 at 1:13 PM
    ShimStack
    Ben
    NC
    Yea, the front differential. :bananadead:
    Junkhead and gman2431 like this.
  10. Mar 1, 2022 at 1:14 PM
    toddulu
    Todd
    Fresno, CA
    my bad, torque converter
    tstack22 likes this.
  11. Mar 1, 2022 at 1:55 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    i wonder if the ATF was ever changed. probably not.
  12. Mar 1, 2022 at 2:04 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Why do they think it’s the torque converter?
    Chew and Junkhead like this.
  13. Mar 1, 2022 at 2:07 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Because they can make easy money off the warranty claim and the customer won't complain since it will only cost him $50.
  14. Mar 1, 2022 at 2:14 PM
    0xDEADBEEF
    Kinda suspicious. It could easy be an engine issue.
  15. Mar 1, 2022 at 2:16 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    They ruled out the transfer case.
  16. Mar 1, 2022 at 2:58 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Something smells wrong with this whole scenario
    Chew likes this.
  17. Mar 1, 2022 at 3:23 PM
    toddulu
    Todd
    Fresno, CA
    The shudder/shaking at low speed/low RPM is a symptom of the torque converter going out no? After they gave me the diagnosis I did a little poking around and the symptoms I was experiencing & the diagnosis seemed to line up. What else could these symptoms be pointing to? No check engine light, i changed the spark plugs @ 60K per OEM recommendation - engine doesn't seem to be misfiring
  18. Mar 1, 2022 at 3:24 PM
    toddulu
    Todd
    Fresno, CA
    I guess I'll find out when i pick it up if it's still shuddering
  19. Mar 1, 2022 at 3:24 PM
    toddulu
    Todd
    Fresno, CA
    What's the recommended service interval? Can't find one in the owners manual.
  20. Mar 1, 2022 at 3:25 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    new fluid every 30k. so drain and fill every 10k miles i what's recommended by most people. manual says it's a "lifetime" fluid but thats BS
