Transfer cases
Discussion in '1st Gen. Tacomas (1995-2004)' started by vtframer, Dec 26, 2018.
  1. Dec 28, 2018 at 9:12 AM
    panardo
    panardo Well-Known Member
    Taco 2000 4x4 V6 manual w/RDlock
    I have a 2000 V6 manual, next to the stick shift, there is the shorty one for the transfer case with the 2HI-4HI-N-4lo engraved on it, is it the J-shifter? what does J stands for? I do normally shift between 2 and 4 when the gears are in Neutral (stick shift) and between Hi and Lo when the vehicle is not rolling and in neutral is it ok ? the sticker with instructions kind is fade out, not all of it but enough to feel I might be doing something wrong...
  2. Dec 28, 2018 at 9:34 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    All this is almost correct ;). There are two hub systems (manual locking hub and ADD) and two t-case systems. (J-shift and push-button 4WD) Regarding hub system first years were available with manual locking hubs or ADD, in later years manual locking hubs were discontinued in favor of ADD (convenience won). Both T-case systems are used till this day in all generations of Tacoma and 4Runner (I have 5th gen 4Runner with ADD and j-shift t-case). Push-button 4WD (or later: turn the drive selector dial) is used in "luxury" variants (again, convenience costs money).
    All systems allow to switch from 2H to 4H and back if the speed is below 50mph (arbitrary set by Toyota), driving steady and straight, pavement or dirt as long as you don't spin wheels. For manual hub there is a prerequisite condition that you have both hubs locked before using 4x4. With ADD it does not matter if you have j-shift or push-button 4WD. System should engage 4H while driving with no issues (with push-button 4WD the 4WD ECU will take care of sequencing all actuators, with J-shift synchro will allow for smooth shifting). By the way ADD does not disconnect the front differential from the front propeller shaft. It is a simple "clutch" between right front axle and the front diff. So even at 2WD both axles and the front propeller are spinning, so switching to 4H does not create any stress (if there is any it will be taken care of by synchro in t-case).
    As far as reliability goes, I doubt there is a difference. Of course push button system has more components including 4WD ECU, so more things to go wrong. On the other hand 4WD ECU is protecting the driveline from stupid things (like forcing 4WD while driving to fast or spinning wheels), so it is more foolproof, so maybe more reliable? :notsure:. For sure push button is more convenient, but j-shift is more macho.
  3. Dec 28, 2018 at 11:49 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    And you are almost correct;).
    With ADD in 2wd the front drive shaft and diff carrier do not turn. The driver side axle, diff spider gears, both side gears and inner diff stub on the pass side spin, driven by the driver side wheel. The side gears are spinning in opposite directions at axle speed inside the stationary diff carrier. The drive shaft/carrier/ring and pinion may "rotate" a bit now and then in sympathy to sloshing gear oil but they are not physically spun. The pass side axle and outer stub shaft are turned by the pass side wheel.
    With ADD the 4wd "shift" is synchronized (manual or push button). The syncro spins up the front driveline and reverses the direction of the side gear/stub shaft on the pass side. Shifting into 4hi at higher speeds (over 50-60) puts a higher load (wear) on the syncro. When the 4wd shift is complete the t-case 4wd "condition" switch is made, allowing the ADD actuator to connect the pass side inner and outer stub shafts as all the components are now spinning at the right speeds and direction.
    Also in the mix is electric or vacuum ADD actuators.
    All Toyota electric actuators found on e-lockers, t-cases and ADD diffs suffer from reliability issues. The greatest being water intrusion/corrosion. "Sealing" up these actuators was once standard practice, long forgotten now.
    The most reliable/strongest factory set up is the manual shift t-case with the vacuum ADD actuator.
    RysiuM[QUOTED] likes this.
  4. Dec 28, 2018 at 11:54 AM
    RysiuM
    Rysiu
    I stand corrected ;)
  5. Dec 28, 2018 at 3:35 PM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    You guys are good engineers. I mean RysiumM and DirtyPool. I even learn more about Boston Whalers from Tacoma World than I do from the two national Boston Whaler sites. I am going to put my big boy pants on and refrain from negatively talking about the two administrators of Continouse Wave and Whaler Central.
  6. Dec 28, 2018 at 4:20 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    I have a 2004, 4wd with ADD, J Shift.
  7. Feb 18, 2024 at 4:28 PM
    Wingnut85
    Wingnut85 Member
    1st gen 03 Tacoma double cab SR5 4x4
    I've gotta 03 with J shift and electric add
