Transfer skid with no bump
Discussion in 'Armor' started by Toteco, Jul 23, 2024.
  1. Jul 23, 2024 at 1:06 PM
    Toteco
    Toteco [OP] New Member
    White 2023 TRD OR
    Exhaust rerouted. Sliders.
    Does anyone know a maker of a transfer case skid plate without the little exhaust bump? The first thing I did when I bought the truck was reroute the exhaust so it would not get snagged or crushed. The skid plates just takes even more clearance away as they all dip to make room for the drooping stock exhaust.
    Thanks everyone.
  2. Jul 23, 2024 at 1:17 PM
    545 Well-Known Member
    2015 Access Cab
    Almost all companies offer an exhaust rerouted one
    stonylaroux likes this.
  3. Jul 23, 2024 at 1:21 PM
    Disgruntled Scientist
    Disgruntled Scientist Active Member
    '22 4x4 V6 DCSB TSS Barcelona Red
    6112/5160, 3L AAL, 4.88 F&B E-Lockers, OTT
    RCI makes an exhaust rerouted transfer case skid plate that is flat (https://rcimetalworks.com/product/2016-tacoma-transfer-case-skid-plate/). I initially had the plate with the "bump" and got a flat replacement from RCI after I rerouted my exhaust. If you already have a cross member from RCI for the transfer case skid you can buy just the flat plate so you don't end up with an extra cross-member you don't need.
    bkhlrTaco's likes this.
  4. Jul 23, 2024 at 1:57 PM
    Toteco
    White 2023 TRD OR
    What companies. All the big ones I have searched for nothing. I have also searched up and down. I did find one once but it was an off the wall small maker and I now cannot find it again. Also the link that was sent from a reply sent me to the skid plate with the bump and no mention of a bypass flat one. do I have to contact them directly and ask for one because there are none advertised or mentioned.
  5. Jul 23, 2024 at 2:22 PM
    There should be a drop-down selection on the page I linked you. One of the drop-down options is "Vehicle has exhaust re-route modification" which is for the flat skid plate. The photos on RCI's website unfortunately only show the plate with the bump.
  6. Jul 23, 2024 at 2:50 PM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
  7. Jul 23, 2024 at 4:52 PM
    Toteco
    White 2023 TRD OR
    YES!!! Thanks a ton lit_taco. SOLD SOLD SOLD!!
  8. Jul 23, 2024 at 4:55 PM
    lit_taco4x4
    Louie
    2018 Tacoma TRD Pro
    no worries @JLee got you covered
