transfercase leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by higherlux, Jun 18, 2009.
  1. Jun 18, 2009 at 5:19 PM
    higherlux
    higherlux [OP] Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    was looking under my truck about 10 days ago and seen my t-case leaking and about 4-5 days after i noticed it i took the top oil filler plug out to put some more oil in it and oil came poring out so its a slow leak
    is there some kinda treatment i can put in the case to help stop the leak?
    i plan to change the oil in it anyway
  2. Jun 18, 2009 at 5:31 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Why not find out what's causing the leak rather than using some kind of "stop leak" to temporarily solve the problem?
  3. Jun 18, 2009 at 5:35 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    because i dont have a lot of money to go towards fixing it right now and i know whats leaking its the front output seal (going towatds the front axle)
  4. Jun 18, 2009 at 7:55 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    amyone know of anything i can use??
  5. Jun 18, 2009 at 7:59 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    where exactly is the leak coming from?
  6. Jun 18, 2009 at 8:00 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
  7. Jun 18, 2009 at 8:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ah...i was skimming.;)
    i seriously doubt a "stop leak" additive would work. you can try, but you'd prolly be better off ponying up and getting a new seal and replacing it.
  8. Jun 18, 2009 at 8:06 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    its kinda a slow leak so i thought a stop leak additive would work
    i know the answer is most likely yes but do u have to tear appart the t-case to replace the seal?
  9. Jun 18, 2009 at 8:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if its an inner seal, then yes, but you may be able to take the front drive shaft off and pull the seal from there. i hjavent looked at mine lately, but it may be an outer seal.
  10. Jun 18, 2009 at 8:12 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    according to the haynes repair manual its a outter seal
    now where to find one and how much???
    off to google!!!!!!!!!!!!!
  11. Jun 18, 2009 at 8:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try autozone and advanced....then the dealer.
  12. Jun 18, 2009 at 8:56 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    gotta get the thing running right before i do that :(
  13. Jun 18, 2009 at 8:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    whats wrong with it besides the leak?
  14. Jun 18, 2009 at 8:59 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    it starts slugishly
    like it dosnt want to start
    im thinkin starter
    or starter silinoid
  15. Jun 18, 2009 at 9:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    get a test meter and test them. if they are good.....maybe needs a good seafoaming and new plugs. just off the top of my head anyway.
    im heading to bed......we'll get more into it tomorrow bro.
  16. Jun 18, 2009 at 9:04 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    mabey
    i was gonna take it off tomarro and take it to autozone tomarro and have them test it
    later bro
