transfercase oil change on automatic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HumanityForPresident01, Sep 25, 2016.
  1. Oct 1, 2016 at 3:02 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    I used walmart super tech 75w90 semi synthetic 1 quart works, reuse the old gaskets don't need new ones
  2. Oct 1, 2016 at 3:12 PM
    eon_blue
    Azusa, CA
    dude, the gaskets cost .10 cents each lol. Why not change them out? If you keep reusing them they will eventually wear out and can cause a leak or plug to come lose. Cheap insurance to just swap it out each time. I bought a pack of 20 gaskets off Amazon for a few bucks.
  3. Oct 1, 2016 at 3:29 PM
    Mush Mouse
    mush
    2013 SR5
    I used to change out to new ones but I actually have reused the old gaskets on the transfer case,copper one on front diff.,auto tranny pan gasket, oil pan gasket at least 5 times and haven't had a trickle of oil leaking, I only change out the 3 crush washers 2 rear diff, one is the fill hole front diff that's it. I like to live dangerously:D
    eon_blue[QUOTED] likes this.
  4. Oct 1, 2016 at 3:30 PM
    eon_blue
    Azusa, CA
    I'm sure they're good for awhile, they say you should change them out every time but I doubt that's necessary. Probably good to do it every few changes though just to be safe.
  5. Oct 1, 2016 at 3:34 PM
    Mush Mouse
    mush
    2013 SR5
    this truck I got now used with 49k miles none of the 30k mile maintainence was done so those were in good shape except the 3 crush washers rear2,front 1 I replaced. the oil pan I replaced with new have done at least 4-5 oil changes with the old gasket,got plenty in reserve tho for the oil. the auto pan I used new one.
  6. Oct 1, 2016 at 3:34 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Same here...but no towing, so 75-90 all the way around.
  7. Oct 3, 2016 at 8:43 AM
    tgear.shead
    tgear.shead Well-Known Member
    Manual and automatic have the SAME transfer case. No difference.
  8. Oct 3, 2016 at 8:49 AM
    tgear.shead
    Yes there are. The 2-4 shifter is synchronized. The high-low is NOT.
    gearcruncher likes this.
  9. Oct 3, 2016 at 8:52 AM
    tgear.shead
    Are you absolutely certain that you changed the oil in the transfer case and not the transmission itself? You won't be able to feel ANY difference in "shift quality" by changing the transfer case oil, since the transfer case shift is activated by a servo motor.
    eon_blue likes this.
  10. Oct 3, 2016 at 8:59 AM
    eon_blue
    Azusa, CA
    He's got an automatic so I sure hope he didn't put the Redline MT90 in it lol.
    But yeah, it's probably just placebo...changing the tcase fluid is good for the tcase but you aren't going to feel any difference. Not like you will if your transmission needs new fluid.
  11. Oct 3, 2016 at 9:01 AM
    tgear.shead
    Actually, he has a manual, his DAD has an automatic, and seems that he wanted OP to do a transfer case oil change on that one as well. Hope OP gets back here before he goes and messes up his dad's truck.
  12. Oct 3, 2016 at 9:04 AM
    eon_blue
    Azusa, CA
    Ah my bad, that's what I get for only reading what was quoted above.
  13. Oct 3, 2016 at 9:17 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You can use GL5 75W90 in all four boxes if so desired (front diff, manual transmission, T-case, rear diff).
    GL4 damaging synchros appears to be prehistoric information. Toyota has allowed GL5 in the manual transmission since the first Tacoma in 1996. It says so right in the owner's manual.
    1996: http://www.toyota.com/t3Portal/document/om/OM35704U/xhtml/OM35704U_OM0023.html?locale=en
    2007: http://www.toyota.com/t3Portal/document/om-s/OM35869U/xhtml/OM35869U.html?locale=en
    Of course with the manual transmission, tactile feel is important, and MT-90 will be better in that aspect.
    On the other hand, since MT-90 is formulated specifically for transmissions, using it in a diff, especially one with mechanical limited-slip, may not work well. If your dad's truck is a TRD Sport, don't use MT-90 in the rear diff. ;)
  14. Oct 3, 2016 at 9:19 AM
    eon_blue
    Azusa, CA
    FWIW I use Valvoline 75w90 SYNpower synthetic gear oil in my diffs, great stuff
  15. Oct 3, 2016 at 12:06 PM
    #35
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    The shafts are turning at the same speed which is why you can engage/disengage 4Hi while moving (note recommendation to be moving in a straight line with no wheel slip) but there is no brass sychro ring in the transfer case.
  16. Oct 4, 2016 at 7:01 AM
    #36
    tgear.shead
    You are making a fool of yourself by trying to press this point, since you are quite incorrect.
    Check the FSM on page TF-11.
    Next time, I suggest you read the FSM in advance of saying foolish things.
  17. Oct 6, 2016 at 1:33 PM
    #37
    gearcruncher
    Canadain bumper technician
  18. Oct 6, 2016 at 2:07 PM
    #38
    cosmicfires
    David
    Everett, WA
    gearcruncher[QUOTED] likes this.
  19. Oct 6, 2016 at 6:16 PM
    #39
    HumanityForPresident01 [OP] Let 'er eat
    Trevor
    2006 Dark Blue Tacoma V6 SR5 EXT Cab TRD Off Road
    2.5" rancho 9000xl lift with UCA's, custom rock sliders, custom rear tube bumper, road armor front bumper, k&n air intake, winch, lights etc.
    Before I changed the rear diff, I could feel a loss of power at 4k rpms, after changing there's no loss. Must have been pretty degraded to resist fast movement of the drive shaft.
  20. Oct 6, 2016 at 6:20 PM
    #40
    Trevor
    So why are you the only one saying red line in the AT isn't a good idea. Why did others say it's ok, not everyone can be correct...
