transformer and skid plates
Discussion in '2nd Gen. Tacomas (2005-2015)' started by waller24, Feb 6, 2010.
  1. Feb 6, 2010 at 1:33 PM
    waller24
    waller24 [OP] Well-Known Member
    Alabama
    2007 Tacoma DC TRD 4x4 impulse red
    usa spec iphone adapter pa15, 1.5 coil lift, warn transformer, warn 8000 winch, UWS black short bed tool box, Grey weather tech mats, mounted streamlight stinger xt, rbc 4x4 light Alignment cam .15 .16 cast 2.24 2.5
    couple of questions here. Just ordered taco. It has the TRD alum skid plate on it but I cant remember if the origianl skid plate is behind it or not.
    So if I took it off would there still be the Black OEM skid?
    Im wanting to install a black warn transformer and think that the silver skid on a dark red truck is a little much but if I did keep it on there, would the warn transformer fit in the tow hook holes that are open in the TRD alum skid plate?
    Thanks
  2. Feb 6, 2010 at 3:18 PM
    waller24
    Alabama
    anyone?
  3. Feb 6, 2010 at 3:31 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    There is no black skid plate underneather. just the TRD one
  4. Feb 6, 2010 at 4:24 PM
    waller24
    Alabama
    so would it look like your truck underneath if i took it off or would you be able to see the front axle?
  5. Feb 6, 2010 at 4:28 PM
    rmb_crew
    you can see the front axle. Mine is the normal black OEM one.
  6. Feb 6, 2010 at 4:52 PM
    waller24
    Alabama
    ok, i was confused because alot of people were saying theyre supposed to mount over the stock oem. What would the stock black piece cost if its not on there?
  7. Feb 6, 2010 at 5:12 PM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    If your truck was purchased with the TRD OR package then there is a black skid plate that is installed from the factory. The TRD "accessory" skid plate mounts over the top of that. If you did not get the OR package then you will only have the "accessory" skid plate.
  8. Feb 6, 2010 at 5:20 PM
    waller24
    Alabama
    whats the OR? it was purchased as the TRD OFFroad package and has the TRD alum skid from factory
  9. Feb 6, 2010 at 5:22 PM
    waller24
    Alabama
    oh ok, or is off road, yeah thats what i thought but some people are saying no its not on there if it comes from factory and that some people didnt have it on when they had the alum skid. But the factory instructions are to bolt it over so it would make sense for it to have it.
  10. Feb 6, 2010 at 5:24 PM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
    if it does not have it, i would trade you my black stock one for your trd skid plate, plus come cash.
  11. Feb 6, 2010 at 5:30 PM
    npsranger
    npsranger Member
    Mountains
    09 TRD Sport
    ARE Truck Cap, Yakima Roof Racks, dropped the running boards, Avid Off-Road Bull Bar, KC Lights, BedRug, K&N Filter, LEDs in Center Console.
    Oddly enough, I have both the black factory skid, and the TRD Skid over it... but I have the '09 Sport Style. I bought the truck new from dealer, maybe I got lucky!
    Poke your head under the truck, unbolt the gray TRD Skid (should have only 4 bolts), it's maybe all of 5 minutes to do. As you unbolt it, the black factory skid will drop down with it. On the front of it there will be two hanger style hooks that hook to the cross member of the frame, the 4 bolts that you will loosen include 2 that go through the middle of the gray and black skid, and the last two are all of the way underneath the truck. Hope this helps.
  12. Feb 6, 2010 at 5:38 PM
    rmb_crew
    cool i learned something new also...
  13. Feb 6, 2010 at 5:41 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    if you want ill trade up for the trd skidplate and you can have the black one off mine
  14. Feb 6, 2010 at 5:42 PM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    My 05 TRD OR also came with both skid plates.
  15. Feb 6, 2010 at 5:53 PM
    waller24
    Alabama
    Ok that's good to know
  16. Feb 6, 2010 at 6:29 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    My 09 OR didn't have the trd skid plate. Should it have?
  17. Feb 7, 2010 at 7:07 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Some misinformation in this thread.
    First of all what some are referring to as a TRD Skidplate is the silver Toyota Accessory plate that can be purchased from the accessory catalog. This silver plate mounts over the black STOCK plate that from my understanding all models of Tacoma's have, 2wd and 4wd, TRD Sport and Off Road (not sure about 5 lugs).
    The TRD Off Road package has an additional skid plate underneath the engine that semi protects the engine block and oil pan.
    In summary, all Tacoma's have one front mounted skid plate that sweeps upward from underneath the radiator and bolts on near the tow hooks. The TRD Off Road has a second skid plate that mounts rearward of the front standard plate and semi protects the engine block and oil pan.
  18. Feb 7, 2010 at 7:08 AM
    Fortech
    CANADA
    No, its an accessory. The silver accessory plate do not come from the factory - it is an accessory added by the dealership that is added into the price, whether you know it or not, regardless of model or trim level.
  19. Feb 7, 2010 at 7:26 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    ^^ This is incorrect. All 6 lug trucks (SR5 and TRD packages) have the black steel skid plate. If you choose to buy the TRD Aluminum Skid plate its placed over the black steel skid plate. So, if you buy the aluminum skid plate you will have both.
  20. Feb 7, 2010 at 7:31 AM
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    That's not odd. I got the Aluminum skid plate a week after getting the Tacoma.
    The dealership agreed to install it as part of purchasing the vehicle. They initially took the black skid plate off... but when I got home I read over the installation instructions, and it clearely stated "DO NOT REMOVE THE FRONT SKID PLATE." So I took it back to have it reinstalled.
    If you are missing the black skid plate under your aluminum one, ask for it back!
