Transmission 2016-2023- 6 SPEED AUTOMATICS COULD BE LOW ON FLUID DIRECTLY FROM FACTORY
Discussion in 'Technical Chat' started by gearcruncher, Dec 13, 2015.
Was your transmission low on fluid?
  1. fluid level is fine
    199 vote(s)
    29.5%
  2. fluid level was low
    319 vote(s)
    47.3%
  3. Truck was built in USA and had low fluid
    155 vote(s)
    23.0%
  4. Truck was built in Mexico and had low fluid
    199 vote(s)
    29.5%
Multiple votes are allowed.
  1. Mar 17, 2016 at 6:32 PM
    #241
    puredrive
    puredrive Member
    02 PreRunner
    got word from the service writer - 1/2 qt low. They also called the regional manager to let them know that the truck was low on fluid, could be all BS. but at least he acknowledge that I was right and that they have documented the incident for warranty purposes. The truck does have the extended warranty and will still call Toyota Care just do cover all bases.
    I am not sure if it the truck was made in TX or Mexico..didn't even know that Toyotas were being made south of the border. :confused:
  2. Mar 17, 2016 at 8:43 PM
    #242
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Called mine to make an appointment and they want me to do a ride around with the tech tomorrow. I have the shifting issue when the truck sits for a while doesn't even matter about the temp I live in Hawaii. R-D seems to rev high then bam go after delay.
  3. Mar 18, 2016 at 10:50 AM
    #243
    Leonard Smalls
    Leonard Smalls Well-Known Member
    2016 Magnetic Gray Metallic TRD Sport 4X4
    Mine still does the R-D thing. Called Toyota corporate and opened a case. They told me that the dealership that sold me the truck should have inspected it and made sure the fluid levels were correct. Waiting to hear from the dealership's service manager.
  4. Mar 18, 2016 at 11:14 AM
    #244
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    They aren't given enough time to check fluids when prepping vehicle...I am at dealer now waiting to watch them show me mine is correct. If it is I have to pay for the procedure!
  5. Mar 18, 2016 at 11:30 AM
    #245
    Leonard Smalls
    Sigh. I understand the time crunch with regard to the inspection but that is no excuse. I told the corporate rep that I talked to that Toyota itself is to blame for allowing trucks to leave the factory with incorrect fluid levels.
    I am going to pursue an extended warranty on the transmission at very least. I am concerned about what wear and tear and/or damage could have been done driving 1200 miles with one quart of fluid missing.
    Gutt Pile and gearcruncher[OP] like this.
  6. Mar 18, 2016 at 12:39 PM
    #246
    eseckinger
    eseckinger Well-Known Member
    Eric
    2018 TRD Sport
    Had my fluid topped off by the dealership that said it was a quart low. Still getting the metallic clunk and still having erratic shifting and delays from reverse to drive. Just opened another case.
    gearcruncher[OP] likes this.
  7. Mar 18, 2016 at 1:17 PM
    #247
    SidZer0
    SidZer0 Well-Known Member
    NE FL
    2019 Cavalry Blue TRD Sport 4x4
    16×8 FNW / Konig Countersteer Type X 265/75/16 KO2's
    Here you go, 1.5 qt. low...issues resolved. Truck drives completely different and is noticeably more responsive.
    My buddy who's the service mgr. contacted his district service mgr. and let him know as well as emailing him the screenshots of the initial fluid level. He's assuming there will be a TSB issued at some point.
    83F8D1F6-A2E8-4581-AE44-3868910B9C1C_zps_c0702d33e75b4bd89a44f582411ae2282c0b4a5c.jpg
  8. Mar 18, 2016 at 2:30 PM
    #248
    tombiosis
    T
    Ottawa Canada
    Just documented my fiasco in another thread. Had to offer to pay for the fluid check if it was fine...after waiting 5 hours at dealer I got to witness the plug pull...not a drop came out! Have called toyota canada...they are getting back to me...
    Took mech for a test drive and he said the clunking and shudder when slowing down was "normal" and he declined when I asked him to drive the truck. Also told me not to "believe everything I read on the internet..."
    Then I had to pay 67 bucks for a tire rotation that I never requested...
  9. Mar 18, 2016 at 5:26 PM
    #249
    beyer075
    beyer075 Rock Licker
    Northern Nevada
    2016 White TRDOR
    Had mine checked by the master tech and they reported it was fine but I wont be happy till I do it myself. A few questions though.
    The thermostat does need to be pinned down right? Do this before going through the temp check process?
    Does the truck need to be running after is hits it's proper temp? How long do I have from 93* to 113*? Should the drain and fill plugs both be out when I start the process (assuming nothing comes out in the first place) so I can start filling right away, or just make them finger tight so I can take them out quickly?
    Why is the Techstream considered not accurate?
    Thanks!
  10. Mar 18, 2016 at 6:04 PM
    #250
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    Please forgive my ignorance. I have a laser infrared thermostat that is accurate to +/- 1/10 degree. Rather than doing the OBD jump. Can I just aim the laser infrared at the bottom of the transmission pan until I get a temp between 93 and 113 degrees. I wouldn't think there would be too much difference in the ambient temperature of the pan and the fluid temperature. Am I way off base on this?
  11. Mar 18, 2016 at 6:05 PM
    #251
    El Duderino
    Jeremy
    HI->PNW
    I'm at my dealership now they did the u joints and they took a few pumps each and I have been waiting for the truck to cool so they can check the trains fluid. By the way the ordered me new rear passenger window moldings.
  12. Mar 18, 2016 at 6:16 PM
    #252
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  13. Mar 18, 2016 at 6:28 PM
    #253
    beyer075
    Northern Nevada
    2016 White TRDOR
    Thanks for the quick reply! In regards to the Techstream I misread a post by Gearcruncher in another thread. Thank you for the help!
  14. Mar 18, 2016 at 6:29 PM
    #254
    splitbolt
    NW Arkansas
    https://www.tacomaworld.com/threads...luid-level-check.410615/page-11#post-11913639
  15. Mar 18, 2016 at 6:35 PM
    #255
    Blazingbluesport
    The OC!
  16. Mar 18, 2016 at 6:46 PM
    #256
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Don't forget to "pin" the the thermostat.....
  17. Mar 18, 2016 at 6:50 PM
    #257
    splitbolt
    NW Arkansas
    Same procedure; you still have to to all the jumper-BS.
  18. Mar 18, 2016 at 8:33 PM
    #258
    Blazingbluesport
    The OC!
    Ugh I must be making this harder than it is. I have now officially read all the posts and the AC60F ATF adjustment document. I will be using the OBD jumper method. But will see what the temp is on the infrared at the appropriate time. I get the point that it could take longer for the temp to transfer to the pan and the pan would heat up slower.
  19. Mar 19, 2016 at 4:49 AM
    #259
    gearcruncher
    gearcruncher [OP] Well-Known Member
    Canadain bumper technician
    Clunking and shudders are normal ? Yup , he obviously works for Toyota lol .
    I trust you guys as members of Tacoma World with your 67 votes for low fluid as of march 19/2016 over a technician that says clunking and shudders are normal on a brand new truck .
    If I lived near you , I would be more than happy to drop by the dealership where he works and poor a quart of WS transmission fluid down that technicians throat and watch him clunk and shudder .
    jclay, BizzyBone, over60 and 2 others like this.
  20. Mar 19, 2016 at 1:04 PM
    #260
    over60
    Muskoka, Ontario
    Good one Cruncher..!!:bananadance:
