Transmission 2016-2023- 6 SPEED AUTOMATICS COULD BE LOW ON FLUID DIRECTLY FROM FACTORY
Discussion in 'Technical Chat' started by gearcruncher, Dec 13, 2015.
Was your transmission low on fluid?
  1. fluid level is fine
    199 vote(s)
    29.5%
  2. fluid level was low
    319 vote(s)
    47.3%
  3. Truck was built in USA and had low fluid
    155 vote(s)
    23.0%
  4. Truck was built in Mexico and had low fluid
    199 vote(s)
    29.5%
Multiple votes are allowed.
  1. Mar 27, 2016 at 6:56 PM
    #301
    GuitarGuy91
    GuitarGuy91 Well-Known Member
    Stephen
    Glenville, NY
    16 TRD OffRoad Acc Cab (ordered)
    Tonight I got really annoyed with the transmission. Maybe it's partially the fault of the cruise control system. Anyway, lately when driving back to to my apartment from my dad's house, on an approx 10mi I stretch of highway, my truck has been deciding to frequent 5th gear more on spots it used to do fine in 6th. Any highway driving it seems to need 5th gear at any slight incline. Then tonight on my way home, on the smallest incline, it went to fifth, which annoyed me a lot, then dropped to 4th. No way this V6 doesn't have the balls to make the tiniest incline in 6th gear. I was furious that it dropped to 4th when it was by no means necessary.
    Tomorrow I'm calling the dealer and demanding they check the ATF. I didn't have complaints about the transmission earlier because I understood things need to break in and the transmission needs to learn. Seems the more I drive on highways (60+ mph) the more frustrated I'm getting with this truck.
  2. Mar 27, 2016 at 9:40 PM
    #302
    TSSbrian
    TSSbrian Active Member
    Brian
    2016 Black Tacoma TSS special edition
    Brand new, no mods but the splash screen on the stereo
    Same here.
  3. Mar 27, 2016 at 11:29 PM
    #303
    gearcruncher
    gearcruncher [OP] Well-Known Member
    Canadain bumper technician
    New edit to the first post
    Removing the battery terminals or clearing the memory makes sense for the guys who are low on fluid .
    The transmission was designed to learn the owners shift characteristics with the transmission full of fluid at the proper level .
    If you guys have low fluid , your transmission is going to work like crap and there is no possible way your transmission adaptive learning will adapt properly to your driving characteristics with low fluid . Your transmission will feel like a bag of sh^t .
    I can not stress enough how important it is to make sure your trans is filled correctly even if this means learning to check it yourself . Get your buddy to help you , get your wife to help you or suffer the consequences
    With this said , I am not positive the dealer is clearing the adaptive learning after they top off your fluid . Some dealers will , others will not .
    If you are taking your truck in for a low fluid issue , be sure to request the adaptive memory be cleared with the Techstream .
    For the members checking your fluid at home , pop the battery cables off for half an hour after you topped off the fluid .
    Old School likes this.
  4. Mar 28, 2016 at 5:13 AM
    #304
    beyer075
    beyer075 Rock Licker
    Northern Nevada
    2016 White TRDOR
    Had a thought last night since I'm not sure if the ATF oil drains from the air cooler once the truck is turned off, if it does, then would the next time the dealer checks the level at the service intervals would that amount of fluid be drained out causing it to be low again? Or should I just ask for them not to check the ATF since I know it's now full?
  5. Mar 28, 2016 at 5:17 AM
    #305
    gearcruncher
    Transmission pump needs to spin in order for fluid to move through the cooling system . There are also anti-drainback valves in place to prevent fluid from draining back to the transmission pan
  6. Mar 28, 2016 at 5:30 AM
    #306
    beyer075
    Northern Nevada
    2016 White TRDOR
    Perfect, thanks!
  7. Mar 28, 2016 at 9:38 AM
    #307
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    My dealer did reset the transmission ECU when they checked my transmission fluid this weekend. They did not specify a quantity it was low, but the report said they adjusted the level (not just "checked" the level) and the service advisor said they had to add some fluid. So I am sure it was more than just a few ml low.
  8. Mar 28, 2016 at 12:33 PM
    #308
    alexderaven
    alexderaven Well-Known Member
    Alex
    Albuquerque, NM
    2016 MGM Tacoma Limited 4x4 (sold)
    Reset the transmission today by disconnecting the battery. Feels much much better. Also added differential to the rear differential, was about 750 ml low.
    gearcruncher[OP] likes this.
  9. Mar 28, 2016 at 11:34 PM
    #309
    slapyoho
    slapyoho Member
    Dale
    2016 TRD Off Road black
    Nothing yet
    I will be picking up my 16 in a few weeks. I will be having everything checked before I pay a penny.
  10. Mar 29, 2016 at 9:25 AM
    #310
    Steelhorses
    Steelhorses New Member
    I just received word that my '16 would be delivered to the dealer 3/30, and I plan to pick it up 4/02. I ordered the truck 3 weeks ago and since reading this post have sent an email to the sales person requesting them to go through the transmission fluid level, drive shaft grease and U-Bolt re-torquing. The sales person printed and gave my email to the Service Manager, in turn the Service Manager did mention he knew about the low tranny fluid level and that they would go through everything. I too won't be signing off on anything if they haven't done what I asked. Seems to me they are on the ball though.
  11. Mar 29, 2016 at 9:31 AM
    #311
    Slipstream87
    Slipstream87 Well-Known Member
    Andrew
    2016 DCSB TRD Sport 4X4
    5100's w/ 285 KO2's, AFE CAI, MBRP Catback, BAMF Grill, remote start, oemaudioplus setup, sound deadened
    Had dealership top off fluid. Also told me they reflashed the truck to fix the erratic shifting. It definitely fixed the shifting, whether that was the atf or the reflash, I don't know, but I had to drive 500 miles on Sunday and yesterday. The first 200 my mileage would not go above 11 mpg. I think it had to complete a drive cycle because yesterday for the last 300 miles, I filled my tank and got better gas mileage than I ever have before. Sat at around 17.5 mpg when the trip was over, and it was all sorts of elevations and hills. Very happy with whichever combination of variables came into play.
  12. Mar 29, 2016 at 10:36 AM
    #312
    leduc4wd
    leduc4wd Well-Known Member
    Derek
    Kansas
    ‘23 DCSB TRD Off-Road / ‘17 Pro 4Runner
    So is the proper way to check the fluid is NOT to pin the thermostat? But when you fill it completely empty you pin the thermostat? I'm confused about this. I ask because I printed off the PDF for the 4x4 and I'm gonna bring to dealer when I go Friday
  13. Mar 29, 2016 at 12:37 PM
    #313
    gearcruncher
    We assume the cooling system was not filled at the factory .
    This means that there is a possibility that the thermostat has possibly never been opened to fill the air cooler with fluid.
    If you push the thermostat " IN " anytime your truck is running , your air cooler will fill and eliminate the need to pin the thermostat .
    I believe most dealers still pin the stat mind you .
  14. Mar 29, 2016 at 1:03 PM
    #314
    Heepspo
    Heepspo I wouldn't say I'm missin' it, Bob...
    Washington State
    2016 TRD OR DCSB, Prem & Tech w/JBL, Towing
    Fuel Vector D600 17" Wheels, Toyo 285/70-17 AT2 Tires, Tuff Country 52907 3" Leveling Lift, Full Katzkin Leather (Black with Platinum Stitching), SOS Concepts Streamline Front Bumper, 3M Scotchgard PPF, "no vtec 4me" BHLM, Husky X-act Contour Floor Liners, Cali Raised Faux Pro Grille, Predator Sliders, WeatherTech Mudflaps, UnderCover Ultra Flex Tonneau Cover, OEM Bed Mat, Headlight Revolution Supernova V.4 Headlights/High Beams & Carbide Canbus 2.0 Amber LED Front Turn Signal Bulbs, Salex Console Organizer, Rhino Seat Belt Extenders (removes annoying dinging), 15% Window Tint, JDM ASTAR 800 Reverse Lights, LED Interior Lighting Package, Stant Locking Gas Cap, Redline Tuning QuickLIFT PLUS Hood Struts, Gentex Compass Mirror w/Homelink, mesojdm Ultimate Turn Signals, Hondo Garage Un-Holey Dash Mount and AR15 Bolt Radio Knobs, CBoy808 Custom Bedside Decals and Flags, De-Badged Doors, Tailgate and Interior Visor Stickers.
    But how long does it take with it pinned for it to completely fill? I imagine if you just pushed it in and released it, it wouldn't be in long enough for the fluid to fill it up.
  15. Mar 29, 2016 at 1:06 PM
    #315
    gearcruncher
    push the stat in for 30 seconds . thats long enough to fill the air cooler
  16. Mar 29, 2016 at 3:02 PM
    #316
    leduc4wd
    Derek
    Kansas
    So should a guy push the thermostat "IN" while it's running before taking it in to be checked by dealer? If you should where is the thermostat?
  17. Mar 29, 2016 at 3:21 PM
    #317
    gearcruncher
    If you dont plan to check the fluid on your own , there is no sense in lowering your fluid level by pinning the thermostat .
    If you go back to page 11 of this post , one of our generous members posted pictures with locations of the thermostat .
    leduc4wd likes this.
  18. Mar 29, 2016 at 6:04 PM
    #318
    beyer075
    Northern Nevada
    2016 White TRDOR
    The thermostat is closer to the passenger side. Post 209 on page 11 like Gearcruncher said. Really pretty simple once you look at it. I was all confused till I finally got down there.
  19. Mar 31, 2016 at 4:00 AM
    #319
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    So how many people are actually getting an extended warranty out of having the dealer check their atf level?
  20. Mar 31, 2016 at 7:22 AM
    #320
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    Picked up my 2016 TRD-OR (with tow package) 4x4 AC yesterday.
    While I was there doing paperwork, I talked directly to the service manager and asked him to check the AT fluid level after explaining the issues I've been hearing about, as well as that I was familiar with the actual fluid check procedure. He was very accommodating and in an hour or so let me know that, to save some time (it was near the end of the day), they added 1 qt before proceeding with the official procedure (AT temperature check mode). He said that, at the most, they had to drain enough to indicate that it was around 1/2 to 3/4qt low.
    Great service. I haven't noticed any shifting issues, other than those that I suspect are the adaptive learning. No hesitation between P, D, R that I'm noticing.
    alf and gearcruncher[OP] like this.
