Transmission 2016-2023- 6 SPEED AUTOMATICS COULD BE LOW ON FLUID DIRECTLY FROM FACTORY
Discussion in 'Technical Chat' started by gearcruncher, Dec 13, 2015.
Was your transmission low on fluid?
  1. fluid level is fine
    199 vote(s)
    29.5%
  2. fluid level was low
    319 vote(s)
    47.3%
  3. Truck was built in USA and had low fluid
    155 vote(s)
    23.0%
  4. Truck was built in Mexico and had low fluid
    198 vote(s)
    29.4%
Multiple votes are allowed.
  1. Feb 8, 2016 at 6:30 PM
    #61
    gearcruncher
    gearcruncher [OP] Well-Known Member
    Canadain bumper technician
    For those of you who sent out a request to Tech Pak over the weekend for a filler tube modification , its Monday now and I have not received a reply in my email ?
    Keep hammering them with requests gents !!!!
    http://www.teckpak.com/contact.cfm
    If these guys dont bite on this , I am going to try a couple more companies
    Here is one I may try
    http://www.summitracing.com/int/parts/mrg-9765/overview/
    I continue to edit this post . If you read it earlier , go back to the first page as I continue to update the first page as new information comes in
  2. Feb 8, 2016 at 6:46 PM
    #62
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    No reply here either..!!
    gearcruncher[OP] likes this.
  3. Feb 9, 2016 at 12:26 PM
    #63
    josowski
    josowski Well-Known Member
    Justin
    '16 Tacoma TRD Off Road Crew Cab Long Bed
    Nothing yet... Bought it with TWO miles on it!!!
    On my transmission, the tech depressed a plunger on the external valve. He held the valve in by placing a pick in a small hole. I am not sure if this would be in the open or closed position.
    After he depressed the plunger, he then began the check and I was still low.
  4. Feb 10, 2016 at 5:41 AM
    #64
    gearcruncher
    OK , which one of you guys have the actual fill procedure for a 2016 ?
    Can you post it up so we can hack out any issues .
    In my mind , when the truck was at the factory , they didnt pin the thermostat .
    This would cause the truck to be low by 3/4 of a quart because the transmission cooler wouldn't be filled .
    Paint your overflow plug before you take your truck in . This way you can tell the dealer checked the fluid
    This was also a 2nd gen problem
    You can read about it here https://www.tacomaworld.com/threads...is-low-on-fluid-directly-from-factory.312718/
    Old School likes this.
  5. Feb 10, 2016 at 5:47 AM
    #65
    Old School
    Old School You are ignoring covfefe by this member.
    This seems to also be a 2nd gen issue with the under filled transmissions, mine was low 3/4 quart also!
    Had been having issues since early on, finally got the dealer to check and top off the trans.
    Seems like Toyota doesn't want to pay the dealer for this, unless a "real " issue is found!
  6. Feb 10, 2016 at 6:21 AM
    #66
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Manual tranny is one thing, and OK but to have to go thru all this just to chk fluid on automatic is just complete lame bullshit. Yeah, I read the EXCUSE........
    "An ATF filling procedure is used in order to improve the accuracy of the ATF level when the transmission is being repaired or replaced. As a result, the oil filler tube and the oil level gauge used in the conventional automatic transmission have been discontinued, eliminating the need to inspect the fluid level as a part of routine maintenance."
    Another way to put the responsibility on the consumer when it blows up unless you paid the dealershit money to "say" they checked it. So much asstarded nonsense.
  7. Feb 10, 2016 at 8:23 AM
    #67
    Old School
    In other words, corporate accountant figured company could save money by discontinuing the dipstick/and tube!
    :brianr: Toyota HQ!
  8. Feb 17, 2016 at 12:55 AM
    #68
    HPPH
    HPPH Well-Known Member
    HPPH
    2016 TRD Sport 4X4
    Thanks for this post...
    I got mine TRD Sport 4x4 in Oct 2015, and under 2000 miles in Nov 2015 the truck completely stop. In the dash I got the engine light on and oil pressure low. Took it to the dealer, after some diagnose (fuel injection) and been completely apart they put it back together and work fine again. Now Feb 2016 it happened again same as before, I got the engine light on and oil pressure low, plus A/F Fluid warning. was not able to drive. Took it to the dealer last week, and still awaiting from Toyota, to sent an specialist to the dealer.
  9. Feb 17, 2016 at 9:15 AM
    #69
    dingdangdoo
    dingdangdoo New Member
    2016 SR I4 4x2
    2016 SR 4cyl. Auto, no tow package; 800 miles on the clock. Dealership reported ATF was 1.5 qts low. EDIT: truck was built at the San Antonio plant.
  10. Feb 17, 2016 at 9:22 AM
    #70
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    I had mine checked yesterday, dealer told me the fluid levels were fine. :notsure:
  11. Feb 18, 2016 at 2:09 AM
    #71
    Kumunoy
    Kumunoy Well-Known Member
    Florida
    2016 TRD OR 4x4 DCSB
    Eric the Car guy has a pretty good thought process regarding warranty repairs, and when watching this video I thought of this thread and why it seems like the A/T fluid isn't getting checked.
    https://www.youtube.com/watch?v=wwfp0dyylqA
    P8tron likes this.
  12. Feb 18, 2016 at 3:40 PM
    #72
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    Has anyone disconnected their battery to reset the transmission?
    Im wondering if theres any initial shifting pattern that has to be done after? Or anything?
    zacinnc78 and Tacoma2GR like this.
  13. Feb 20, 2016 at 8:02 AM
    #73
    REB55
    REB55 Well-Known Member
    SE LA
    2011 SR5 Prerunner Access Cab
    Sold POS 2016 SR5 DCSB
    I finally checked my transmission today after making sure I read everything I could here on TW. Sure enough mine is definitely low - no overflow while in temperature range. I even let the transmission exceed the temperature range for several minutes after the "D" started blinking, then pulled the plug again. Still no overflow! Damn! So I'm debating whether I should go buy the fluid and a pump or bring to the dealer. I know I should bring it to the dealer to document the problem, but well, I think you guys know how I feel. I know I expected better from Toyota. At least they should admit they screwed up by posting a TSB by now for crying out loud. BTW, mine was built in San Antonio.
    Updated below on Feb 23rd.
  14. Feb 20, 2016 at 8:06 AM
    #74
    Old School
    gearcruncher[OP] and Kumunoy like this.
  15. Feb 20, 2016 at 8:22 AM
    #75
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Done
  16. Feb 20, 2016 at 8:43 AM
    #76
    Old School
    Thank you!
  17. Feb 21, 2016 at 10:10 AM
    #77
    mlm682577
    mlm682577 Well-Known Member
    Mark
    DFW, TX
    2016 Blazing Blue Tacoma TRD OR DCSB
    60+ mods and counting (mod-aholic)
    I checked my trans fluid level today. It was about 3/4 of a quart low. I put 1/2 quart in before I checked it based on recommendations in other posts and because I was experiencing the delay from R to D in the mornings. So, I was 95% sure it was low. I really did not want to use the jumper wire on the OBDII port so I purchased the UltraGauge only to find out that it IS NOT for 3rd gen Tacomas. Their sites states "2012+". The UG shows "err" for the trans temp. The UG rep said Toyota changed the codes for the 2016s. Anyway, I ended up using the jumper method. It worked just as described. Once it was in the proper temp range, I checked the fluid level....no drainage. I added the other 1/2 quart in but could not get the temp back down so I let it sit over night. Checked the fluid level first thing this morning and it was over serviced. I let it drain until there was only a "trickle" coming out. I took the truck for a test drive.....wow, what a difference. There was very little delay shifting from R to D. Also the shifting on the road seems more solid. In hindsight, I should have put an entire quart in before I started the process. It takes a long time for the fluid to cool back down and start the process over.
    taco 16 likes this.
  18. Feb 23, 2016 at 6:02 PM
    #78
    REB55
    SE LA
    Update from Feb 20th. I decided to buy a quart of WS fluid from the dealer and a pump from Harbor Freight. My story is very similar to the previous poster. Pumped in a half quart and checked. No overflow! Pumped in the rest of the quart and checked again even though the "D" was flashing. Plenty of overflow. Let it cool overnight and checked again. No overflow when D appeared but it started dripping before the D started flashing. I figured that is good. The total amount mine was low was 3/4 quart. After 2 days, of driving the delay from R to D has almost disappeared. Also, the shuddering I was having while accelerating through 4th gear seems to have diminished, although I can still feel it sometimes on a smooth road. I'll update later if things change, but as of now I'd say the issues I was having were related to the transmission being low on fluid.
    taco 16 and gearcruncher[OP] like this.
  19. Feb 24, 2016 at 2:56 PM
    #79
    sadmrhappy
    sadmrhappy <insert clever title>
    cylinder 0, head 0, sector 1
    2016 Inferno Tacoma DCSB TRD Sport 4x4
    Dealership checked mine and it was 3/4 quart low.
  20. Feb 25, 2016 at 6:08 AM
    #80
    Franklin
    Franklin You can't always get what you want
    Davey
    Tacoma
    I have an TRD OR AC with the tow package. Seems from other posts the biggest offender for low tranny fluid.
    450 miles on truck, trans. smooth all through gears up and down.
    ECT, Sport. Drive, all seems fine. Drive used to reach for higher gears when driving like grandma but got much better when not babying tranny and driving normal (for me). Tried highway-up down hills, also up down rolling hills at 40-50, around town with lights every half mile or so.
    Cold (below 30 degrees) reverse out of my driveway up steep hill, brake, then shift into D proceed downhill, smooth no issues. Tried up the hill too.
    This thread makes me paranoid. Seems to put out vibe all new owners should check no matter what. At least that is what I am getting.
    Do I need to check my transmission fluid?
