Transmission 2016-2023- 6 SPEED AUTOMATICS COULD BE LOW ON FLUID DIRECTLY FROM FACTORY
Discussion in 'Technical Chat' started by gearcruncher, Dec 13, 2015.
Was your transmission low on fluid?
  1. fluid level is fine
    199 vote(s)
    29.5%
  2. fluid level was low
    319 vote(s)
    47.3%
  3. Truck was built in USA and had low fluid
    155 vote(s)
    23.0%
  4. Truck was built in Mexico and had low fluid
    199 vote(s)
    29.5%
Multiple votes are allowed.
  1. Dec 11, 2017 at 7:04 PM
    #981
    jclay
    jclay Well-Known Member
    As long as the Manufacturer relies on the dealership for inspection work, the results will never be good and the manufacturer could care less.. Same thing as a certified vehicle. More paperwork at the dealership with a bunch of boxes being checked. Technicians never ever do certified vehicle inspections, if they did they would starve to death for the pay they receive which is the same as PDI. Its a complete sham. The system is broken and techs are rewarded for falsifying documents in order to get to the profitable work.
    gearcruncher[OP] likes this.
  2. Dec 11, 2017 at 7:09 PM
    #982
    jclay
    After reading all of this, here are a couple of questions. What happened to the fill tube idea? Does the Taco tow package cooler work the same on a manual transmission?
  3. Dec 12, 2017 at 4:02 AM
    #983
    jclay
    Lmao and you let that go?
  4. Dec 13, 2017 at 6:45 AM
    #984
    Monday_Rex
    Monday_Rex Well-Known Member
    New to the site, thought I'd drop my first comment/question here.
    Being that the tow package is now standard on all V6 models, is it possible we could see a more normalized and proper AT fluid fill from factory? Maybe it makes sense now that there's just a standard volume to set to these filling machines for all V6 Taco's going through the line.
    In the end, one can only hope!
  5. Dec 18, 2017 at 5:30 PM
    #985
    CO_0321er
    CO_0321er Well-Known Member
    Just got my truck back from the dealer. Turns out i was 1/2 quart low. Not much, but they topped it off. Took 3 trips to a dealership, and then going to a different one to have it checked.
    Truck is a 17 and i purchased it in august of 17. Dealer told me only the 16s had this issue.
  6. Dec 19, 2017 at 1:47 PM
    #986
    Shermyota30
    Shermyota30 Well-Known Member
    Bay Area
    17 sport 2wd doublecab
    It was very hard to get dealer to check fluids manually but they did and it happen to be one quart low. After repeated calls to Toyota complaining about it they finally offered me the platinum warranty for free.
    Arrampico and Riding Dirty like this.
  7. Dec 19, 2017 at 3:32 PM
    #987
    Arrampico
    Arrampico Well-Known Member
    Dan
    2018 4Runner SR5
    2017 SR5 Silver DCSB 4x4 V6 (RIP - Traded-in for T4R)
    I'm going to call as well...any insight?
  8. Dec 19, 2017 at 3:43 PM
    #988
    CO_0321er
    As in Toyota Corporate? I may do the same
  9. Dec 19, 2017 at 3:57 PM
    #989
    Shermyota30
    Bay Area
    Just be persistent and don’t take no for an answer. Like I said it wasn’t easy and it was time consuming about 5-6 calls through a two month process.
  10. Dec 19, 2017 at 3:58 PM
    #990
    Shermyota30
    Bay Area
    Yes Toyota corporate. And yes you could do the same.
  11. Dec 20, 2017 at 7:42 PM
    #991
    Artvandelay
    Artvandelay Well-Known Member
    NY
    17 DCSBOR MGM
    I’m not close to a dealer so I called the service manager and set my appt up to get a few things checked/ taken care of all at once. He said great and understandable so it went in last Wed for...
    Tranny hanging in gear and clunk going into drive after reversing. (Asked them to check fluid manually to see if it was full and make sure it had most current update)
    The hood flutter. All the adhesive points on the bracing underneath were detached.
    Rear diff whine.
    Leaf spring squeak.
    And vibe from 10-30 mph. (Axle wrap?) Started with just ~400 miles on it.
    After a WEEK, today I was told that they only did the hood!! They said because my truck is lifted that the vibe is due to angles. I said that’s reasonable, no big deal...even though it was doing t before the lift, I’ll do axle shims and see what happens. Then I asked, what about the other 4 things, what about everything else? He tried to tell me that they didn’t bother with the diff because the whine could be caused by my lift, didn’t bother with the transmission because my lift and “bigger tires” could be causing it to shift erratically and clunk, and didn’t bother doing the leaf spring tsb either because they weren’t “Toyota leaves.” They’re trying to scumbag me when I have just an ome 2” and an add a leaf. I told him we’re not going this route and I needed to be treated fairly and that all of these are known issues, and all of them were happening before the lift which was put on just 200 miles ago. He said ok well give me one more day with it and I’ll see if I can get things going..I’m trying to remain calm, but I’m ready to get busy making them lose some business. This is all happening to my 2017 with just 1600 easy miles on it.
  12. Dec 21, 2017 at 5:36 AM
    #992
    treimche
    treimche Well-Known Member
    Fargo, ND
    I'm not on the dealership's side at all, but you have to look at it from their perspective too. Once you modify anything that could have the slightest chance of causing a problem, they are going to tell you exactly what they told you. The dealership is always going to try their hardest to not fix anything for free. Bigger tires are heavier and that will cause the truck to shift differently since these Tacomas have zero torque. Adding aftermarket leaf springs, then asking to fix a squeak in the stock springs is never going to fly with a dealership.
  13. Dec 21, 2017 at 5:44 AM
    #993
    Artvandelay
    NY
    17 DCSBOR MGM
    Understood and that rationale would be fine if these issues weren’t known problems across the board with these trucks, and if they didn’t start before the lift but they are, and they did. It’s absolutely ludicrous. They’ll be dealing with a situation they def don’t want to be dealing with if I don’t start getting treated fairly. That’s something I can guarantee.
  14. Dec 21, 2017 at 9:34 AM
    #994
    CO_0321er
    Just got off the phone with toyota corporate... Had my tranny fluid topped of a few days ago (only 1/2 quart low). Called Toyota corporate yesterday for the first time to address my concerns with having slightly low fluid for 7000 miles with all the weight i have. They told me they would call me back this morning. They did, and they are giving me an extended warranty. 100,000 mile power train and electronic warranty. Easiest fight I've had. I know some people are having a hard time with this issue, but my faith is restored in toyota. Keep fighting and pushing for the extended warranty. Its their fault after all that you bought a $35,000 truck that they forgot to build properly.
  15. Jan 1, 2018 at 11:14 PM
    #995
    1bad10tacoma
    1bad10tacoma Well-Known Member
    Mark
    Brewer Maine
    2025 dcsb Trd off-road
    tonneau,
    Downeast Toyota Brewer Maine
  16. Jan 2, 2018 at 5:52 PM
    #996
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Anybody in the Charlotte area have any luck with a dealer being able to properly check fluid level? Been through one dealer with no outcome
  17. Jan 4, 2018 at 9:52 AM
    #997
    Mslide
    Mslide Member
    2017 Tacoma TRD
    My issue is like everyone else I suspect the ATF is low in my 17 TRD OR that has 6 k on it. I have read up and plan to check the ATF myself since the dealer won't check or says they check but the overflow bolt paint hasn't been cracked. My questions is, with the tow package, I have read you need to pin open the thermostat before conducting the fluid check. Is this correct? If so, can someone explain or have a picture as to exactly where on the tranny it is located? Thanks in advance.
  18. Jan 5, 2018 at 5:47 AM
    #998
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    Post # 207 of this thread has pictures that I took.
  19. Jan 5, 2018 at 5:54 AM
    #999
    Mslide
    Mslide Member
    2017 Tacoma TRD
    @RichVT @Skydvrr Thank you Sir for you help. Getting at it this weekend. AC60E PDF procedure is for the 4x2 correct? I have 17 TRD OR 4x2.
  20. Feb 12, 2018 at 5:11 PM
    #1000
    HB_TRD_Taco
    HB_TRD_Taco New Member
    Huntington Beach
    2017 TRD Offroad Tacoma
    Dropped my 2017 trd offroad with tow package off at huntington beach toyota and they checked it for me with no hassle or charge. It did take all day but as expected and found that i was approx 1/3 quart low so not too bad but i will be contacting corporate soon
    ToyoTacoTurner likes this.
