Transmission 2016-2023- 6 SPEED AUTOMATICS COULD BE LOW ON FLUID DIRECTLY FROM FACTORY
Discussion in 'Technical Chat' started by gearcruncher, Dec 13, 2015.
Was your transmission low on fluid?
  1. fluid level is fine
    199 vote(s)
    29.5%
  2. fluid level was low
    319 vote(s)
    47.3%
  3. Truck was built in USA and had low fluid
    155 vote(s)
    23.0%
  4. Truck was built in Mexico and had low fluid
    198 vote(s)
    29.4%
Multiple votes are allowed.
  1. Feb 19, 2018 at 7:55 AM
    #1001
    petr321
    petr321 Well-Known Member
    Petr
    San Diego
    2018 DCSB OR
    Does anyone know if they fix the fill issue for the 18s
  2. Feb 20, 2018 at 12:23 AM
    #1002
    JDG2TACOMA
    JDG2TACOMA Member
    2015 Tacoma Sport
    I took my 2017 in today to get the TSB. it was hanging up at 3500 RPM IN 4th at hwy speeds. A "master" tech let the trans cool, hooked up his compter and manually checked the trans. I know because I watched him. He added some trans fluid during the check. When I checked out the tech stated that it didn't need an update and that he didn't add any trans fluid. Like I said, I watched him add fluid. I informed management of his lying and also called Toyota corporate to add this to my case. As of now it is not sticking in 4th. If he reset the system would it take time for symptoms to return, or did he update and add fluid? Not saying he did so he wouldn' have to do more diagnostics do to low fluid level?
    K-Bear likes this.
  3. Feb 20, 2018 at 4:55 AM
    #1003
    treimche
    treimche Well-Known Member
    Fargo, ND
    If the tech reset the ECU, it takes some time for the "AI" learning to do its thing. It will eventually go back to its bad habits. I too have the hang in 4th gear on the highway issue, and have just come to accept it. Most anything over 70mph, coupled with zero torque from this motor makes the downshift necessary in order to maintain speed. I think that aerodynamics play a big part above 70 mph on this Tacoma also.
  4. Feb 22, 2018 at 10:36 AM
    #1004
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    Thank you OP for this thread.
    Trans fluid was low by 1/2 a quart and was clunking into first. They re flashed and topped it off but it still clunks.
  5. Feb 23, 2018 at 11:57 AM
    #1005
    petr321
    Petr
    San Diego
    2018 DCSB OR
    Just checked my 18 and it was full. When then truck is cold I fill it clunk into 1 also but 5 min later it’s gone.
  6. Feb 27, 2018 at 7:21 AM
    #1006
    Abjamison
    Abjamison Active Member
    Bo
    18 TRD Sport
    Tailgate auto lock, bed mat, gate storage, bed cover
    When cold mine also clunks from 2nd to 1st. 18 TRD Sport. Im close to my 5k checkup and will see if the dealer will check the ATF at that point
  7. Feb 27, 2018 at 7:33 AM
    #1007
    petr321
    Petr
    San Diego
    2018 DCSB OR
    Do it ur self for $40. ELM 327 WiFi on Amazon for $20 and OBD fusion app in the App Store $10 and Toyota PIds in app purchase 10$ and ur done. If u do have the dealer check it transmission make sure they do the over flow plug at proper temp not just the computer check. It takes about 4 hours to do it if u give them ur truck when it’s hot. U can only do that check when the transmission fluid is 93-113 degrees. There is only a 20 degree window to do it. Then cross ur fingers they don’t strip ur threads or cross thread.
  8. Mar 9, 2018 at 11:11 AM
    #1008
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    I am just starting this process. Truck is at the local dealer right now and told them to check the tranny fluid level. Well see where this goes.
  9. Mar 11, 2018 at 10:32 AM
    #1009
    Abjamison
    Bo
    18 TRD Sport
    My only concern with doing it myself, I have nearly 5k miles already on the truck. If it is low there has to be damage. Does me checking it void any warranty or give the dealer any reason to not fix any damage if it is indeed low?
  10. Mar 11, 2018 at 10:41 AM
    #1010
    petr321
    Petr
    San Diego
    2018 DCSB OR
    No it will not and u will know for sure if they are not telling the truth. If u have touch up paint put some on the overflow bolt and u can also tell if the did the computer way only or if they did with them physically looking
  11. Mar 11, 2018 at 10:49 AM
    #1011
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    So dealer said mine was 3/4 of a quart low. I’m going to call corporate tomorrow Am.
  12. Mar 11, 2018 at 2:38 PM
    #1012
    99Mike
    99Mike Well-Known Member
    Fayetteville, NC
    2018 SR5 DCSB
    I am doing this just for peace of mind. My dealer is 50 miles away and don't want to wait till the 5000 mile service. Currently there is 1550 miles on the truck. Occasionally, I hear a clunk when it downshifts coming to a stop. I have 2 quarts of oil coming from Amazon and intend on checking this myself. I've already practiced putting it into temperature detection mode. Currently, I have no idea if it is low and only want to do this once. My plan is to put a quart in before putting it into detection mode and then remove the overflow plug. I only have 6 1/2 minutes to do this and figured pre-loading a quart would give me more time. Thoughts?
  13. Mar 17, 2018 at 6:19 PM
    #1013
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    write email to eco and tell him of this issue and call from corporate....then see what happens....3 qts low is not something to sneeze at
  14. Mar 18, 2018 at 7:22 AM
    #1014
    wisefool006
    wisefool006 Member
    America
    2016 MGM SR5 V6 AT
    2 quarts transmission fluid
    I had the same issue! Mine was reported to be 2 quarts low at 7,000 miles. They refused to consider it an issue, it is most certainly an issue. I called corporate and they didnt consider it an issue. They said if it was a problem then it would fail within the existing warranty and offered no warrenty extension. Ultimately, the transmission had to be replaced at ~15,000 miles because it was slipping bad and there was a lot of metal shavings in the fluid when I had them recheck it ~6 months later. Document everything, get your requests to the dealer in writing, try another dealer. They finally replaced mine no charge and provided me with a rental, but it was like pulling teeth. If you document 3 times where they cant fix the problem then you can start a file for lemon law and it will force them to address it or lemon law the truck. I hope it works out better for ya.
  15. Mar 23, 2018 at 8:57 AM
    #1015
    evoxtaco
    evoxtaco Well-Known Member
    Salinas, California
    2018 Tacoma Off Road
    King Lift, TC Upper Arms, MESO lights, SCS Wheels.
    Has anyone with a 2018 had any issues? I just picked one up yesterday. :annoyed:
  16. Mar 27, 2018 at 2:33 PM
    #1016
    K-Bear
    K-Bear Well-Known Member
    2017 Inferno DCSB TRD OR
    So just got my 2017 back from the dealer, decided to take it to a different dealer this time as the other one didn’t check the fluid the prior 2 times I took it in and asked. New dealership said the test drive my master tech was normal, I told them to check it anyways. When I picked it up service advisor said it was “within spec” but that in order to check that it was right they had to overfill the trans then let it drain to a certain point...leaves me wondering if it actually was low and they just didn’t tell me.
    EDIT: Forgot to mention this - they didn’t make me pay a dime, despite saying level was within spec. Advisor said he spoke with his manager to have them pay for it because of my trouble. Don’t know if that’s true or if they didn’t charge cause it was truly low...we will never know.
  17. Mar 27, 2018 at 4:41 PM
    #1017
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    What's their email?/ what's eco?
  18. Mar 27, 2018 at 5:12 PM
    #1018
    r1200gs4ok
    O. K.
    Irvine, Ca
  19. Mar 27, 2018 at 5:16 PM
    #1019
    nat103
    KY
    2017 DCSB OR
  20. Mar 27, 2018 at 5:17 PM
    #1020
    r1200gs4ok
    O. K.
    Irvine, Ca
