Transmission 2016-2023- 6 SPEED AUTOMATICS COULD BE LOW ON FLUID DIRECTLY FROM FACTORY
Discussion in 'Technical Chat' started by gearcruncher, Dec 13, 2015.
Was your transmission low on fluid?
  1. fluid level is fine
    199 vote(s)
    29.5%
  2. fluid level was low
    319 vote(s)
    47.3%
  3. Truck was built in USA and had low fluid
    155 vote(s)
    23.0%
  4. Truck was built in Mexico and had low fluid
    199 vote(s)
    29.5%
Multiple votes are allowed.
  1. Sep 13, 2020 at 4:34 PM
    #1161
    Unab8dLy4m
    Unab8dLy4m Active Member
    Louisiana, USA
    2020 Super White Tacoma Utility Package
    Is this a known problem with the 2020s as well?
    cryptolyme likes this.
  2. Sep 16, 2020 at 1:33 PM
    #1162
    mallege
    mallege Well-Known Member
    George
    SW Idaho
    2019 Tacoma SR Gray SB Auto V6
    Extang tonneau cover, variable speed wiper stalk, hood struts, ScangaugeII.
    2019 SR V6 Baja, Mexico build here. I did have some gear hunting issues when towing a light boat (<1000lbs) up inclines and just learned to use sequential shifting to keep it in 4th or 5th gear. When I changed my rear differential fluid I found it to be 1 quart low.
    I wondered what other fluids might be low and read through this transmission post and others, then decided a transmission check was in order. Yesterday, I was only able to drain out 2 quarts (64 ounces) cold. Added 3 quarts (96 ounces) back in and ran the temp calibration check using my Scangauge II. At temp, I had 18 ounces come out, so it looks like my transmission was 14 ounces low.
    Going fishing tomorrow, so I will be able to see if I feel any difference when towing.
  3. Oct 12, 2020 at 5:47 PM
    #1163
    dave.h
    dave.h Well-Known Member
    SLC Utah
    2020 TRD Off Road DCLB
    @gearcruncher (or if anyone else might know) I’ve got a 2020 Trd off-road I bought new w 400 miles. I agree the dealers are not especially helpful— at 5000 mile maintenance they checked the box for all fluids verified and even verbally said they checked the transmission fluid level, later walking it back saying it was a sealed system....you know the drill. So, I bought a scan guage and have a constant reading, and the temps seem to be good range (mountain climbs not going over 192). Just wondering — if the temps stay good do you think that’s enough of a sign that the fluid level is good? Thanks so much- this thread is really helpful
  4. Dec 23, 2020 at 4:29 PM
    #1164
    Kalebscott
    Kalebscott Member
    Kaleb
    Orlando, FL
    2018 White SR 4x4
    6in rough country lift 33’s 4.88’s
    I have a 2018 SR on 33’s, OVTune and with 4.88’s. Was downshifting when braking and making each descent kinda jumpy - not a smooth deceleration. I decided to check my ATF level and it was about 3/4 of a quart low. I can happily report that since I added the fluid it downshifts perfectly and overall is a smoother shifting experience. I truly believe the low ATF was causing my rough downshifting. Check the fluid! Finally happy with the way my truck drives.
  5. Mar 23, 2021 at 11:14 AM
    #1165
    Matt8vt
    Matt8vt Well-Known Member
    Illinois
    2021 MGM TACOMA SR5 SB 4X4
    Method 305 16x8 in black with duratracs 265/75/16 Running boards SS3 fog lights Truxedo tonneau Carhartt seat covers
    @gearcruncher also wondering if there are reports for 2021's low on fluid. Sorry to nag!
  6. Mar 23, 2021 at 7:02 PM
    #1166
    gearcruncher
    gearcruncher [OP] Well-Known Member
    Canadain bumper technician
    I Dont own a 21 , therefore i rely on the members here at Tacoma World to post up the results of their new trucks . Less members are posting in this thread so I assume the issue has been addressed by Toyota . There was never a bulletin released for low on fluid and less members are complaining of low on fluid symptoms
    Matt8vt[QUOTED] likes this.
  7. Mar 23, 2021 at 8:31 PM
    #1167
    Matt8vt
    Illinois
    Thank you so much for the reply and all the work you laid out! I really appreciate your input. My transmission has seemed fine but I figured it couldnt hurt to ask. Thanks for doing your due diligence!
  8. Apr 12, 2021 at 2:01 PM
    #1168
    Elk Hunter1
    Elk Hunter1 New Member
    2020 Tacoma Off Road Pro
    Scan gauge
    After reading all the post re: transmission fluids being low. I checked mine. I bought the truck used with 4000 miles. We are planning on towing a small travel trailer for an extended trip next summer. Next week we are going to take a short trip 200 miles from the house to try the truck out. When I checked the fluid, there was no fluid coming from the overflow port. Put in over a half a quart thinking I had over filled the level and would adjust at the correct temp. Not good. Still no fluid at over flow at temp. of 109 degrees. Put in another half quart of fluid and repeated the process. Still no fluid coming from the overflow. Added another 1/2 quart and finally got a flow at temp at the over flow. Pretty scary thinking we were going 400 miles with a low level transmission. I plan on calling Toyota to at least get this issue with my truck on record.
    gearcruncher[OP] likes this.
  9. Apr 12, 2021 at 2:07 PM
    #1169
    gearcruncher
    Thank you for checking your fluid and updating this thread . I wish more new owners would do the same
  10. Apr 13, 2021 at 4:46 AM
    #1170
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Cheaping out on no dipstick to chk fluid level is such lame BS.
  11. Apr 17, 2021 at 10:00 PM
    #1171
    dave.h
    SLC Utah
    Wow that’s really low. After all this time I still haven’t checked mine but was assuming (perhaps incorrectly) so long as the scan guage temps were normal there was enough fluid and no risk. Thinking I should probably check it just to be safe.
  12. May 13, 2021 at 3:06 PM
    #1172
    coolyouth
    coolyouth Well-Known Member
    Very good information thanks a lot man.
  13. May 13, 2021 at 3:28 PM
    #1173
    coolyouth
    Are there any reports of the 2020 tacos with low trans oil problems?
  14. May 13, 2021 at 7:07 PM
    #1174
    gearcruncher
    I rely on you guys as members to update this post .
    I dont own a new truck so I rely on new members to update this thread .
    I do however follow a few threads with the 21 Tacoma . The fluid level is still hit and miss .
    Nowhere near the 2016,s mind you
  15. May 15, 2021 at 9:32 PM
    #1175
    Phil61s
    Phil61s Well-Known Member
    N PHX
    2021 Tacoma SR 4x4
  16. Oct 23, 2021 at 1:02 PM
    #1176
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    Mine was a full quart low, and looked like shit. Drained just what was in the pan, refilled with toyota atf and lubeguard, and it’s so much smoother now. Pretty ridiculous Toyota didn’t formally address this and from what I have heard they don’t even properly check the level if you ask them to (I don’t trust them anyways so moot point for me, but still). :crapstorm:
  17. Oct 23, 2021 at 1:14 PM
    #1177
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    mine feels low...going to check it as soon as i get some fluid.
  18. Nov 26, 2021 at 11:34 AM
    #1178
    cryptolyme
    Virginia
    i couldn't even find a thermostat when i checked mine
  19. Jan 19, 2022 at 1:28 PM
    #1179
    87TURD
    87TURD Member
    2016 Tacoma TRD OFF-ROAD
    About to Receive my new 2022. after a long battle of ailments with a 2016 TRD off road I've owned since new I'm more paranoid then ever. I already called the dealer ship and asked there procedures on PDI's and was basically laughed at. Unfortunately I need a vehicle, cant pick and choose dealerships right now. in New England you don't just walk into the store and buy a new Tacoma anymore. you get to play the game and wait or put 500 dollar deposits down... Always have owned a MT and this will be my first AT
    Any updates on 2022 fluid levels?
    Cheers,
    Chad
  20. Jan 24, 2022 at 7:29 AM
    #1180
    Nitro52
    Nitro52 Well-Known Member
    ct
    2022 SR/SX
    I asked about this in the comment section of this vid. And in his vids he seems to know what he's talking about.
    https://www.youtube.com/watch?v=nBBUQJKTaiM&lc=UgzvTeiBr04yOcEUTfB4AaABAg.9XHZg67fz3o9XHuB9P6JkY
    question - Great videos, my Tacoma SR is on order. I've read of several Tacomas that have come from the factory low on AT fluid. Some recommend having the dealer check it before taking delivery. Do you think this is a good idea? Thanks
    answer - Hi! You can. The ones that came low it was slightly low and unless you live in extreme cold weather it won’t be an issue.
    The dealers today around here almost seem to have an attitude of take it or leave it. I'm not sure if I even want to ask about the trans fluid.
