Transmission- 5 Speed automatic write up with pics for second gen 4 liter trucks
Discussion in 'Technical Chat' started by gearcruncher, Aug 7, 2013.
  1. Nov 16, 2018 at 8:51 AM
    #241
    gearcruncher
    gearcruncher [OP] Well-Known Member
    Canadain bumper technician
    lynyrd3 likes this.
  2. Nov 16, 2018 at 8:52 AM
    #242
    gearcruncher
    I may have the wiring manual here ....Hold on
  3. Nov 16, 2018 at 8:54 AM
    #243
    gearcruncher
    send me a private message with your e mail
  4. Nov 16, 2018 at 9:29 AM
    #244
    Oumler
    Oumler Active Member
    2004 4runnr
    Ya the links you send me i follow them and will recheck with those has follow
  5. Dec 4, 2018 at 7:07 PM
    #245
    albrow100
    albrow100 Member
    Alex
    Portland OR
    2005 Tacoma access cab
    My connector on the side of trans is full of atf. Has anyone seen that? I was checking it for corrosion today do to an intermittent shift issue.
    is this due to a leaking internal harness. or is a solenoid pushing fluid through a wire upinto the connector
  6. Dec 4, 2018 at 7:59 PM
    #246
    Oumler
    2004 4runnr
    I would clean the area and look in a few days if you see atf around that male connector....
    gearcruncher[OP] likes this.
  7. Dec 4, 2018 at 8:18 PM
    #247
    Locoluna825
    Locoluna825 Well-Known Member
    Garrett
    San Diego, CA
    2008 Tacoma TRD sport 2x4
    URD TCAI and MAf Calibrator, Lexus front GX470 big brake swap, TRD Baja Suspension, 3 leaf progressive AAL.
    that's most likely atf being pushed out from the the seal failing.
  8. Dec 5, 2018 at 1:01 PM
    #248
    gearcruncher
    I have seen these leak in the past . Its not uncommon . You can purchase a new internal harness but they are pricey .
    Check out the tsb
    https://www.scribd.com/document/18857706/T-SB-0277-09
  9. Dec 5, 2018 at 8:18 PM
    #249
    albrow100
    albrow100 Member
    Alex
    Portland OR
    thanks! im going to do the interal harness and zip kit at the same time and see how it goes
  10. Dec 5, 2018 at 8:27 PM
    #250
    Locoluna825
    Garrett
    San Diego, CA
    Anyone know where you can buy that internal harness. and external harness to the ecu?? I'm having difficulty finding one.
  11. Dec 6, 2018 at 1:09 AM
    #251
    gearcruncher
    Wrecking yard for external. Toyota dealership for internal
    You should be able to find the part numbers and prices for both harnesses below
    Here is a complete parts diagram with prices for your truck .I suggest downloading it all before it disappears . [​IMG]2013 Toyota Tacoma Pickup.pdf
    Dont quote me on this ,but the internal harness should be Part # 82125-60650
    Check here to be certain
    http://www.toyodiy.com/parts/
    If OEM doesnt work for you , Rostra makes aftermarket harnesses . I have used them in the past and they work well
    http://www.rostrapowertrain.com/typ...a&transmissiontypes=a750e-5-spd-rwd-2003-2016
    lynyrd3 and Locoluna825[QUOTED] like this.
  12. Dec 8, 2018 at 2:24 PM
    #252
    Locoluna825
    Garrett
    San Diego, CA
    thank you!
  13. Dec 9, 2018 at 1:10 PM
    #253
    albrow100
    albrow100 Member
    Alex
    Portland OR
    I used the rostra harness and installed the zip kit. both were easy if you have done any trans work before
    sonnax provided great instructions as long as you follow them exactly its easy
    it made it shift much sharper and feel more normal to me
    lynyrd3 likes this.
  14. Dec 10, 2018 at 8:30 AM
    #254
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    What is the ideal temperature for a transmission to run at? And specifically, are there any issues with it running at 125* in the winter?
    Since I added a larger cooler, in cool/cold weather, especially when not towing a trailer, the transmission does not heat up.
    I am wondering if I need to add a bypass valve to cut the cooler out of the circuit on cold days.
  15. Dec 12, 2018 at 8:32 PM
    #255
    gearcruncher
    Hi Scott .
    According to the FSM , your transmission is designed to operate perfectly at 176 degrees . If you are worried about overcooling , you can plumb your aftercooler before the coolant runs through the engine radiator . This way the oil in the cooling lines get the heat before it returns to the transmission pan.
    Depending on the aftercooler , some are already built with a bypass .
    If yours doesnt have a bypass , you can purchase one .
    An example https://www.amazon.ca/Derale-35020-...ocphy=1002401&hvtargid=pla-523471089291&psc=1
    Some transmission shops sell transmissions with an add on aftercooler and request you bypass the engine rad completely .
    As far as documentation for a transmission operating when its too cold ...Good luck with the search as I doubt you will find much other than initial start up in the morning . Heat is the killer that we need to constantly monitor
    FastEddy59 likes this.
  16. Dec 22, 2018 at 8:21 AM
    #256
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    800 mile trip yesterday. Trans temp stayed about 167F. Thats with 800-1000#s extra on the truck. Outside temp was about 60F for the entire trip.
    07 sport 4x4 likes this.
  17. Jan 7, 2019 at 5:53 AM
    #257
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    @gearcruncher Helluva thread man! Those first few posts are pure gold. Thanks for sending me here from another p0705 code thread.
    So far the cable lube from the dealer has held up flawlessly and hopefully it stays that way.
  18. Jan 7, 2019 at 8:07 AM
    #258
    daopi
    daopi Well-Known Member
    Daniel
    Vancouver, BC
    2012 TRD Offroad AC auto
    Bilstein 6112 (2nd notch) & 5160, Leer 100XQ canopy
    There is something which bugs me for long time and wanted to ask @gearcruncher:
    I have a 2012 Tacoma (106000km) and a 2010 Camry (170000km), both sealed transmission. The Taco has a minor shift roughness from 4 to 5. The Camry seems to have moods and some rougher changes all over. After reading all the postings here it seems that these transmissions have rather a design flaw and/or fluid quality issue.
    From your point of view, how reliable are these sealed transmissions comparing with other brands? Should we sell our Toyotas and get something else?
  19. Jan 8, 2019 at 6:00 AM
    #259
    gearcruncher
    I wouldnt sell them
    Toyota transmissions are made with alluminum inside and out and are very prominent to wear . Change the transmission fluid every year rather than what Toyota specifies as a recommended mileage and you wiill be good to go .
  20. Jan 8, 2019 at 7:52 PM
    #260
    daopi
    Daniel
    Vancouver, BC
    Simply drain and refill is enough? Should I add Lubegard every time?
