Transmission- 5 Speed automatic write up with pics for second gen 4 liter trucks
Discussion in 'Technical Chat' started by gearcruncher, Aug 7, 2013.
  1. Jan 5, 2014 at 12:27 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    gearcruncher,
    what fluid would you recommend?
  2. Jan 6, 2014 at 10:24 AM
    tacomajim
    tacomajim New Member
    jim
    so cal
    02 lifted 4x4 ext cab trd
    bilstien 5100s, lifted 3in, k@n air intake, gibson ex,front light bar,winch, diff drop,
    hey gearchrusher, have any ideas why flex plate has cracked twice did first one at 170,000 now making same noise as before,now at 220,000. don't want to change every 50,000 thanks
  3. Jan 6, 2014 at 10:32 AM
    !TacoTaco!
    !TacoTaco! TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
  4. Jan 7, 2014 at 5:04 AM
    gearcruncher
    gearcruncher [OP] Well-Known Member
    Canadain bumper technician
    Bell housing run-out . loose bellhousing bolts or any loose bolts for that matter .bad universal joints or lift kit installed without cancelling driveline angles , Missing dowel pins .
    The flywheel is the weakest link .
  5. Jan 18, 2014 at 1:56 AM
    Chandler L.
    Chandler L. Well-Known Member
    San luis obispo, CA
    2009 TRD Supercharged 4x4 Tacoma
    TRD cold air Intake, TRD supercharger, Doug Thorley headers & Y-pipe, URD Exhaust, Dynomax Muffler, King Coilovers & Total Chaos UCAs up front and King Resis. And AllPro Baja leafs out back, Rock sliders, 1/4" steel skid plate, 33" BFG KM2 MTs on Procomp rims, 6000k HID fog lights, CB radio
    So what fluid do you like instead of the WS? I'd much rather have a high quality synthetic like AMSoil or something of that sort.
  6. Jan 18, 2014 at 3:41 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Thanks for the reply, I too found that WS is not my number one choice, but then again, maybe my use of M1 ATF was not optimum either. Your last paragraph is how I considered the entire situation. PK
  7. Jan 30, 2014 at 6:38 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    Would this shift kit keep my transmission from doing really soft long (slipping? maybe) shift from 4th to 5th? Or would a fluid change help? I also feel like the lock up doesn't always engage either. The truck has 50k miles and about 15k of those with a supercharger.
  8. Feb 11, 2014 at 3:40 PM
    gearcruncher
    Do the fluid change when you do the kit . You are due for an oil change if you havnt already done it
    Yes , I would combine the Sonnax zip kit with the shift kit .
    http://www.ebay.com/itm/A750E-F-5-S...Parts_Accessories&hash=item2c7b007016&vxp=mtr
    https://s3.amazonaws.com/sonnax-dev/uploads/unit/valve_body_layout/249/VBL-Toyota-A750EF.pdf
  9. Feb 12, 2014 at 2:03 PM
    ls1 prerunner
    Andy
    El Paso, TX
    Where would I be able to purchase a Sonnax zip kit? I tried looking for online distributors and most of them said to give them a call, which I haven't done so yet.
  10. Feb 12, 2014 at 2:14 PM
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    Great info here!
  11. Feb 12, 2014 at 8:23 PM
    gearcruncher
    The Zip kit is fairly new to the market . If you have a trans shop in your town , I am sure they can get one for you .If you do find a zip kit on ebay ,or anywhere on line , post back with a price and a link if you dont mind .
    Sonnax has been around for a long time as an aftermarket transmission parts supplier . Thier products are outstanding .
    Both the Zip kit and the trans-go have great information and easy to follow instructions .
  12. May 30, 2014 at 2:09 AM
    gearcruncher
  13. Jun 25, 2014 at 6:10 PM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
  14. Aug 12, 2014 at 1:05 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
  15. Sep 26, 2014 at 6:48 AM
    #35
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
  16. Oct 13, 2014 at 10:33 AM
    #36
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Has anyone actually installed one of these kits?
    Thinking about the transgo. Transmission is shuttering between shifts and is shifting at too low of an RPM on average.
  17. Oct 20, 2014 at 2:44 PM
    #37
    pashka612
    pashka612 Member
    Pasha
    Atlanta, GA
    05 PreRunner TRD-offRoad
    I'm experiencing the same issue, gets hung up in 5th gear and will struggle even at 1300rpm instead of downshifting. I find myself downshifting manually often unless I'm going uphill, somehow transmission will be quicker to downshift then. I've done the drain/fill twice in the last 20k (1 year) but not much difference. I read someone having same issue with their 4th gen 4runner sealed transmission and they added 1 quart of Lukes Transmission Fix and after a couple of weeks the shifting got better for them. Not sure whats my next step to address this irresponsive at times transmission issue.
    Anyone else experiencing this on their 4.0L Auto?
  18. Oct 20, 2014 at 4:24 PM
    #38
    gearcruncher
    There is the 2012 flash TSB that delays the upshift to 5th gear and fixes a pinging engine . Its rather unfortunate that the TSB doesnt cover older models with the identical transmission . At this point in time , if your throttle body and mass air flow sensor are super clean and fresh spark plugs have been installed , I am afraid there isnt much you can do . Keep in mind that the ecm commands 5th gear at 1300 rpm . With this said ,installing the kit wont help much unless a flash is released by Toyota to compensate for the early application . A suggestion would be to leave the trans in 4th until the tsb becomes available for earlier models . I know a couple members who have the kit and they indicate it makes a huge improvement
    Santa Cruzin likes this.
  19. Oct 20, 2014 at 5:36 PM
    #39
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    Where is the info on this flash?
  20. Oct 20, 2014 at 8:56 PM
    #40
    gearcruncher
    4TH GEAR TO 5TH GEAR UPSHIFT . Reports at TRNI indicate the SLT solenoid has issues .
    http://www.moranbahweather.com/toyot.../m_05_1113.pdf
    The flash also fixes the clunk upshift to 5th gear , however this fix is only for 2012 and up Tacoma,s .
    Toyota has " NOT " released a much needed flash for the earlier Tacomas.
    [​IMG] T-SB-0044-14.pdf
    ONCE again , the Zip kit will seal the hydraulic integrity of the valve body but it will not change the computer controlled shift strategy of the computer in your truck .The Zip kit fixes a crappy designed spool valve in the valve body .This fixes only the valve body issue which is half of the problem .
    5th gear is commanded too early by the ecm , not the valve body
