Transmission- 5 Speed automatic write up with pics for second gen 4 liter trucks
Discussion in 'Technical Chat' started by gearcruncher, Aug 7, 2013.
  1. Oct 3, 2017 at 2:41 PM
    #141
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Did you clean the screen shown here on the last page?
  2. Oct 3, 2017 at 4:03 PM
    #142
    Jeffy Bobby
    Jeffy Bobby Member
    Yes, everything was cleaned. Mine wasn't dirty tho.
    07 sport 4x4 likes this.
  3. Nov 23, 2017 at 8:55 PM
    #143
    stenyeart
    stenyeart Well-Known Member
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    3" Toytec Lift w/ AAL, TRD CAI, Leer 700 Series, Hypertech Speedo Calibrator, Locker Anytime Mod, LR UCA's, OEM Roof Rack, Satoshi grill with Devil Horns Emblem, USA Spec PA-15 Toy Ipod Integration, Redline Tuning Hood Struts and EZ Down Tailgate.
    So, I have a rumble strip which I feel is torque converter shudder. It happens only when the transmission is up to temperature and in Drive. (If I put the shifter in 4 in will not do it). It occurs when it locks up the torque converter in 3rd and 4th gear with rpms around 1,000. I did the brake switch test and the vibration continues and the rpms do not increase. I noticed on the first page it mentions what the possible cause is if the vibration goes away but mentions nothing if it continues. If I adjust throttle (more or less) the vibration will go away. It also vibrates in both 2wd and 4wd. I have flushed the transmission with new WS fluid and added Lubeguard. At this point I am thinking I need to go in and adjust the SLU solenoid, but I am unsure if I need the Sonnax Zip Kit, Transgo Shift Kit or Ratiotek Shift kit as well (or some combo of the three). Hoping I could get some advice from you guys on where to go. Also, props to all that have contributed to this thread as there is a ton of good info here.
    In the last 3,000 miles I have flushed the ATF, new spark plugs, cleaned MAF and Throttle body. Also, this past summer I replaced the carrier bearing on the driveshaft, replaced cv axles and replaced the driver side differential bearing with the bushing kit.
    2006 Tacoma Doublecab 4.0 A750
    95,000 miles
    3" Lift
    33" Tires
    Stock Gearing
  4. Nov 23, 2017 at 10:33 PM
    #144
    gearcruncher
    gearcruncher [OP] Well-Known Member
    Canadain bumper technician
    If you did the brake switch test and the vibration continues , chances are its not your torque converter lock up clutch causing the vibration . When you gently tap your brake pedal when you begin feeling the shudder , you are turning off the converter lock up clutch for a breif second . If you are doing the brake test correctly holding your right foot " steady on the gas " when you begin to feel the shudder and gently tap the brakes with your left foot and the vibration goes away , you have a converter lock up clutch shudder if the vibration comes back shortly after you tapped the brake pedal .
    This converter lock up clutch only comes on in 4th and 5th gear ...It doesnt come on in 3rd
    What rpms does this occur at 1000 ?
    Warm the vehicle up in the driveway , apply the emergency brake as well as your regular brakes , put the truck in drive and do a stall test at 1000 rpm feeling for the vibe .
    Allow the transmission to cool after you are finsihed by idling the truck .
    If you have a vibration in the driveway , you have an engine missfire under load at 1000 rpm
    There is more info here on how to perform a stall test
    Scroll to page 20 and perform a stalltest http://fjcruiser-club.com/docs/RM/A750E Automatic Transaxle.pdf
    Page 29 of this PDF explains the Flex lock up circuit
    http://www.toyotatundraforum.com/pdf/A750E.pdf
    Murphinator likes this.
  5. Nov 24, 2017 at 7:51 AM
    #145
    stenyeart
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    Did the stall test this morning and did not notice any vibration. Stall speed was about 2,450-2,500 rpm. I am going to try the brake test again later today to make sure I was doing it right. You mentioned that the converter lock up clutch only comes on in 4th and 5th, but in the article it mentioned that flex lock up occurs in 3rd as well. I think I have only tried the brake switch test with the vibration in 3rd gear. I will try it when it is in 4th gear and see what happens as the vibrations occur in both gears (only these two, 5th lockup has always been smooth with the exception of a slightly rough kick down to 4th).
  6. Jan 2, 2018 at 7:26 PM
    #146
    stenyeart
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    Sorry for the late reply, found out I was having two issues. I had a worn out u-joint in the rear driveshaft. Currently I have a shudder in 4th gear that appears to be lock up related because if I tap the brakes it goes away for a couple seconds and then it comes back. At this point I have flushed the transmission fluid with fresh Toyota WS fluid and tried the shudder fixx with little improvement. The shudder got a little better after 20-30 miles, but it is now 500 miles later and it is still there. Any thoughts on what I should try next?
  7. Jan 2, 2018 at 8:49 PM
    #147
    gearcruncher
    Well , the only thing you have remaining is replacing the SLU solenoid and giving it a couple turns in or compensating for the wear by replacing the wore out valving in the valve body with one of the kits .
    https://www.youtube.com/watch?v=FEQNP_4R5W8
    Spencedaddy likes this.
  8. Jan 2, 2018 at 9:35 PM
    #148
    stenyeart
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    Is it worth trying to adjust the current SLU or should I just plan on replacing it?
  9. Jan 12, 2018 at 7:55 AM
    #149
    gearcruncher
    Sorry for the late reply .
    Members are having some good success with the Ratio teck kit . I would suggest dropping the valve body and installing one of those .
    Your truck is 2006 with a lift kit so I am assuming there is going to be some considerable wear inside the trans.
    The higher pressures that come with kits will help your situation
    Spencedaddy and Kolunatic like this.
  10. Jan 12, 2018 at 7:57 AM
    #150
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Good to know sir :bowdown:
    I’ve been waiting to get in mine since I only have 66,703 miles
  11. Jan 12, 2018 at 8:06 AM
    #151
    stenyeart
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    So, I installed a Sonnax zip kit and the ratio Tek HD kit. The shifts are amazing now, but i am still getting the shudder. At this point I am looking at replacing the SLU and torque converter. When I dropped the pan I was surprised how clean the pan was. I did notice when looking up the part number for the OEM SLU that they updated the part number for some reason. Not sure if they made changes to the original part and obsoleted the old one or what. Also, my SLU did not have the adjustment screw on it. Looking at the new part number it does not appear to be adjustable either.
  12. Jan 12, 2018 at 8:13 AM
    #152
    gearcruncher
    You are correct about the converter coming on in 3rd gear as part of the flex lock up feature .
    The early Tundra,s didnt use third and thats where I was confused .
  13. Jan 12, 2018 at 8:22 AM
    #153
    gearcruncher
    ROSTRA has aftermarket solenoids . I have used this company in the past . You could always try one of these instead of an expensive factory SLU
    http://www.rostratransmission.com/transmission-solenoids-by-rostra-transmission.php
  14. Jan 12, 2018 at 8:53 AM
    #154
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
  15. Jan 12, 2018 at 8:57 AM
    #155
    gearcruncher
    mightytacoman[QUOTED] likes this.
  16. Jan 12, 2018 at 9:00 AM
    #156
    mightytacoman
    Kel
    4.5L 1grfe
    I have no converter shudder that I can sense when driving it. There is ever so slight of a shudder if i'm at a complete stop and give it as much juice as I can without spinning tires. I can't say if that shudder is in the transmission or elsewhere in the drivetrain. My believe is elsewhere though.
  17. Jan 12, 2018 at 5:24 PM
    #157
    gearcruncher
    For those of you who beleive Lubeguard is a snake oil , I suggest you take another look .
    Its, a fluid supplement that increases clamping force , longevity as well as durability . Its why I make the recomendation to use it during a transmission service as well as installing shift kits . This stuff wasnt available to the general public up until recently .It was only available to transmission shops and dealerships .
    Its a quality product that does exactly what it says . Dont beleive me ? call any transmission shop and ask !
    http://www.lubegard.com/~/C-110/Transmission
    This is not a transmission conditioner that swells the seals and eventually turns to acid .Once the usefull life of a transmission conditioner has depleted , it must be removed or it will destroy the rest of your transmission fluid .
    Lubeguard is a fluid supplement that remains in the fluid for a reason
    Here is what Lubeguard had to say .
    Thank you for contacting us!
    Lubegard products are fully compatible with Toyota WS ATF in the Aisin Seiki A750 transmission. We have had absolutely no issues whatsoever in these transmissions.
    We reached out to our contact at TransGo and we were told that there is no known issue with our products in this application.
    What Trans-go has to say
    My name is John Landry and I am the Sales and Marketing Manager for TransGo. I would like to start by giving you the background story regarding Steve Younger and TransGo. Steve Younger is the son of the deceased Gil Younger, but he has NO tie what-so-ever to TransGo. Steve has been running his own company as a competitor since the early 2000’s. Our two companies do not share information, ideas nor do we discuss other companies products.
    At TransGo, our staff is very considerate of the other companies in our Industry even our direct competitors. We do not belittle them or their products in anyway. Lubegard has been supplying high quality lubrication products and supplements in our Industry for decades now and many of our customers use their products on a daily basis, much like yourself.
  18. Mar 17, 2018 at 11:14 PM
    #158
    daopi
    daopi Well-Known Member
    Daniel
    Vancouver, BC
    2012 TRD Offroad AC auto
    Bilstein 6112 (2nd notch) & 5160, Leer 100XQ canopy
    Is it possible to get a worse transmission after oil change?
    I got as new my taco 6 years ago and always serviced at same Toyota dealrship. Couple weeks ago I did the service for 96kkm and I changed transmission oil, transfer case and both differentials. Also changed spark plugs. Truck was pretty ok before except ocasional small kicks maybe from driveshaft joints (lubrication could fix it) at lower speeds with light foot on accelerator.
    After oils change things started to go weird. The first drive I already felt that transmission kicks at higher speeds and once I felt a kick at 120km/h trying to lock...
    Weird thing is that slowly the kicks are going away, after two weeks almost gone. But why were these kicks in the first place?
    Thanks!
  19. Mar 18, 2018 at 2:05 PM
    #159
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Uh oh you didn't drain the trans fluid by mistake did you?
  20. Mar 18, 2018 at 4:41 PM
    #160
    gearcruncher
    We are going to remove kicks from your explanation . Thats a description used when playing soccer or football he he .
    Did you replace the transmission fluid or did the dealer do it for you ?
    Was the transmission pan removed when the fluid was changed or did you have a transmission flush performed without removing the transmission pan ?
    Do you have a code scanner ?
    Lets use " upshifting " in place of kicks
    When you feel the transmission upshift into 2 gear , 3rd gear , 4th or 5th gear , what gear are you feeling rough shifting ?
    Highway speeds ?
    These transmissions use a locking converter clutch that comes on to save you gas . There is a possibilty you are feeling the torque converter apply agressively . This is usually caused by improper fluid changes
    lynyrd3 likes this.
