transmission acting up
Discussion in '1st Gen. Tacomas (1995-2004)' started by dylandercole, Nov 12, 2009.
  1. Nov 12, 2009 at 1:15 PM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    heres the skinny. I noticed this morning after work that my engine felt weird and didnt pinpoint it until I got on the freeway. This only happens in 4th and 5th gear (I have a 5 speed), Whenever I step on the gas not flooring it but giving it some juice, once my RPMs reach between 2500 and 3000 its like it slips out of gear and revs way up to 5000. I can smell something that smells like burning clutch whenever it happens. Its not sparatic its everytime I try to speed up in 4th and 5th. all the lower gears are fine and 4th and 5th are fine as long as I just cruise around 2k rpms... Please I need guidance.
  2. Nov 12, 2009 at 1:23 PM
    dylandercole
    Dylan
    c'mon Im impatient I need answers!
  3. Nov 12, 2009 at 1:33 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    manual?
  4. Nov 12, 2009 at 1:34 PM
    dylandercole
    Dylan
  5. Nov 12, 2009 at 1:36 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    c'mon!
  6. Nov 12, 2009 at 1:37 PM
    dylandercole
    Dylan
    what?
  7. Nov 12, 2009 at 1:37 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Does the stickshift pop out of gear, or do you just get the revs but the stick is still solidly engaged?
    On my old 93, there is a urethane or rubber ball at the base of the stickshift that disintegrates after about 100k miles. Mine would just "fall out" of 3rd gear, but I never smelled anything like you did. I don'tknow if this is the same for your truck, but if so, this is about a $14 part and an easy 1/2 hour job from inside the cab.
    I just bought aused 2001 Tacoma, so i am new to the truck, but I my guess is that they are the same up until 2nd gen.
    Good luck. That sucks.
  8. Nov 12, 2009 at 1:38 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    it sounds like your clutch,lower gears dont start slipping till it gets real bad.
  9. Nov 12, 2009 at 1:40 PM
    dylandercole
    Dylan
    no my stick stays put. its just that it revs way up. damn. Iv had a squeeking coming from my clutch for about a year now that people have said is probably the throw out bearing. does that have any importance to this issue?
  10. Nov 12, 2009 at 1:47 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    not gonna make it slip.
  11. Nov 12, 2009 at 1:48 PM
    dylandercole
    Dylan
    allright so pretty much I have to replace my entire clutch? Is that possible to do myself?
  12. Nov 12, 2009 at 1:58 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    yes,pull the trans.resurface the flywheel if needed,you will need a clutch line up shaft too,3 quarts 75w 90 gear oil
  13. Nov 12, 2009 at 2:13 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    gonna try it?
  14. Nov 12, 2009 at 2:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    jbob is right on this. Replace your clutch.
  15. Nov 12, 2009 at 2:44 PM
    dylandercole
    Dylan
    yea im going to try it. im a student and dont have the $$ to pay someone to do it. and everytime i do something myself I learn something new so why not. is there a good brand that anyone recomends?
  16. Nov 12, 2009 at 7:31 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    The same thing is happening on my truck too, but only in 4th gear. Does this really call for a new clutch:(?
  17. Nov 12, 2009 at 7:35 PM
    dylandercole
    Dylan
  18. Nov 12, 2009 at 7:59 PM
    dylandercole
    Dylan
    or should I just beg my parents for the money...... im really uncomfortable with both
