Transmission acting up?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ncyrider, Jun 27, 2020.
  1. Jun 27, 2020 at 6:37 PM
    ncyrider
    ncyrider [OP] Active Member
    Was backing out of a flat driveway earlier and my 2017 SR5 (v6 auto.) Felt like it was accelerating a bit on its own it's reverse. Like it wanted to reverse 15+ mph with no throttle. Then while driving off, the shift from 1st to 2nd gear was rough and it made a bit of a loud clunk noise. After that everything was fine. But I know my truck has done this in reverse a few times before, not as bad though. Is this something that I should be concerned about, or check something?
  2. Jun 27, 2020 at 7:36 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Ever had the fluid level checked? Some 16 and 17’s came low from the factory.
    12TRDTacoma and Shellshock like this.
  3. Jun 28, 2020 at 5:39 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Don't know about the bad clunk, but was the engine up to temp, or cold ....it will idle higher rpm at times till warmed up enough.
  4. Jun 28, 2020 at 5:50 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This, give a few seconds to idle down
  5. Jun 28, 2020 at 6:14 AM
    Jcran2
    Jcran2 Well-Known Member
    Middle Georgia
    2016 MGM Tacoma TRD Sport
    Bed Mat, Soft Bed Cover, Weathertech Mats, LEDs throughout interior, 1" Bora Wheel Spacers, OEM Bed Light Kit, OEM Mudguards, Window Tint, Center Console Organizer, Glove Box Organizer
    My 16 still shifts erratic at times but have come to expect it.
    kahanabob likes this.
  6. Jun 28, 2020 at 6:16 AM
    Shellshock
    Iowa
    ^this
    do a drain and fill
  7. Jul 1, 2020 at 4:52 PM
    ncyrider
    I'm at 38,000 miles, is my truck due for this anyways? Is there a filter to change as well? I have no idea if the previous owner changed trans fluid before, I bought the truck at 32k miles. Last noob question ...is there a specific auto. Trans. Fluid that seems to be the best, or "go to" stuff for this truck?
  8. Jul 1, 2020 at 6:14 PM
    Shellshock
    Iowa
    My 16 was low from the factory. Even a fraction of a quart makes a noticeable difference in these trucks.
    you don’t need to worry about a filter. There’s instructions for the whole process in the DIY sticky. I’ve used amsoil personally.
  9. Jul 2, 2020 at 5:57 AM
    zoo truck
    None
    I use run amsoil atf in my tundra...it ended up causing lazy shifting points. Had to have it flushed. After that only mobile 1 atf synthetic.
  10. Jul 2, 2020 at 7:20 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yep. Check fluid level as mentioned.
  11. Feb 10, 2021 at 7:30 AM
    ncyrider
    Will be doing a drain and refill very soon.
    But yesterday, while going through a drive-thru, my truck was "acting up" way more than what I've noticed any other time. In drive while on the brake pedal, allowing it to creep forward, the engine was revving on its own (not high revs, maybe 2k rpm? Not sure), causing the truck to want to surge forward. It would do this every 3-8 seconds, but only if I was letting it creep forward from what I remember. and if I let any more pressure off the brake and wasn't careful, it could have caused the truck to drive right into a curb or structure in that drive thru.
    As mentioned in my first post , it does this in reverse sometimes too. Not in etc-power mode any of these times. Is this normal for 3rs gen Tacomas to do this, or is there something going on? Does it have anything to do with the tune/would the OV tune fix this issue?
  12. Feb 10, 2021 at 8:00 AM
    slvrtaco11
    slvrtaco11 Well-Known Member
    SF bay area
    2018 TRD OFF ROAD AC
    tint, oem bed mat, CVC tune
    My 2018 has been doing this from day one. I got in contact with the dealer. They test drove it and said yes it does this but we have NO remedy. This is how Toyota designed it so they tell me. I call BS!! They now have it documented. Good luck!
  13. Feb 10, 2021 at 8:52 AM
    zoo truck
    None
    My 2020 sounds the same as what you have , but only if the engine is not up to the correct temp. Otherwise after a minute or so all is normal like any other automatic vehicle.
