Transmission acting weird
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gooseman80, Mar 23, 2012.
  1. Mar 23, 2012 at 1:05 AM
    gooseman80
    gooseman80 [OP] Member
    Troy
    Spring, Tx
    Tacoma
    I currently own a 2006 Tacoma double cab. I was wondering if anyone has ever noticed something weird with the trans. Sometimes when I come to a complete stop, like at red light for example, after about 3 to 5 seconds you can feel a bump coming from the trans. This doesn't happen all the time, only sometimes, but it worries me regardless. Any ideals and thanks.
  2. Mar 23, 2012 at 1:25 AM
    TRDsport253
    TRDsport253 Well-Known Member
    Fife, Wa
    05 PreRunner TRDsport
    TRD Cold air TRD Cat-back
    My truck does the same thing. I wondering the same thing as you. Hope someone has an answer.
  3. Mar 23, 2012 at 10:46 AM
    ewa2fl
    ewa2fl Taco Jinx...
    Ed
    Wayne Co. 14516
    Tacoma DBLB V6 4x4
    Plati-Dip Badges & Removed a few, added D-rings in Bed, added recovery D-shackle, Added Front Recovery Hook, TRD Skid Plate-Rhinoed, added 2 mini tie downs, removed rear seat headrests.
    Mine too '08. Also it feels like when I let off the gas the engine/transmission starts braking on it's own? If I shift into N it stops??? HELP! Think I'm doing a tranny service real soon, just turned 50K.
  4. Mar 23, 2012 at 10:49 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    mine does that when i release the brake when im at at stoplight etc.. but its been doing that since day 7 so i figured it was relatively normal. but yea it does bring up some questions. oh well good luck guys i hope someone chimes in with useful info haha
  5. Mar 23, 2012 at 10:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It can be one of 2 things. First, the tranny doesnt shift into first gear, until the vehicle is stopped for a few seconds. Or, it could be Axel Wrap.
  6. Mar 23, 2012 at 11:06 AM
    over60
    over60 "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    My '06 has done that from the beginning.... I think it's just the tranny downshifting to first gear... Not to worry
  7. Mar 23, 2012 at 11:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ive done this, and it didnt help
  8. Mar 23, 2012 at 11:17 AM
    Krewblink
    Krewblink Well-Known Member
    Danny
    Long Beach
    05 toyo Prerunner
    Exhaust,Seat Covers, Intake
    My 05 does the same damn thing.... I had a professional toyota mechanic look at it and he said it was normal. so i just turn up the radio and ignore it now.
  9. Mar 23, 2012 at 11:37 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    My truck an 07 and sometime at a red light stop and go first gear sticks and then it'll shift. Do you think flushing the tranny and lining the slip yoke will help fix this
  10. Mar 23, 2012 at 12:00 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Weird...I've never experienced this problem but i have aal's, keep the zerks greased, and slowly come to a stop. Do you guys that are haveing this issue come up to a stop light/sign fairly fast before hitting the brake pedal?
  11. Mar 23, 2012 at 12:04 PM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    stuff and more stuff
    i noticed if you fully stop at a stop light/sign, it helps....
  12. Mar 23, 2012 at 12:35 PM
    soup1279
    soup1279 Member
    Anthony
    Pottstown, PA
    2018 TRD Off-Road MT Quicksand/Black
    I've noticed mine does this from time to time as well. I also noticed sometimes if I come to a stop and it does this little lurch thing that when I go to start again I'll also get a little bump/thud feeling like something is moving around that shouldn't be in the drive train. I've also noticed that it's doing it more now that the temperature is getting hotter
    My Tacoma is fairly new to me (owned it about a month, bought it "certified-used" so it has a decent warranty still)
    I've got an appointment Monday at the dealer to look at the rear leaf springs that are making the squeak noises as well as creaking noises all of a sudden. (You can see where someone sprayed them down with white lithium grease in the past) I have a list of things to bring up for them to look into, this problem is one of them.
  13. Mar 23, 2012 at 12:42 PM
    graywolf2011
    graywolf2011 Well-Known Member
    Orlando Florida
    11 Tacoma 4X4
    undercover hard toneau, stainless steel nfab step bars
    Ive had several tacos and most of them do that, it axle wrap, or more simply put "tension" in the driveline "relaxing" when you stop. It feels kinda like a small bump forward. Normal for the taco.:rolleyes:
  14. Mar 23, 2012 at 12:56 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I am inclined to agree with chris4X4 and graywolf2011, that what you are feeling is axle wrap as it tensions and relaxes. This is largely the result of weak rear leaf springs, something all Tacomas(first and second generation) are noted for.
  15. Mar 23, 2012 at 1:01 PM
    acmair
    acmair Well-Known Member
    Andrew
    '10 BSP PreRunner Dbl Cab Short Bed SR5
    Yeah mine does it to and I have under 8K miles on it....
    (im not sure its the same. does it sound as if you have a box or something in the bed that suddenly moves to the front of the bed and hits the cabin. That's how i feel it at least)
  16. Mar 23, 2012 at 1:07 PM
    OffroadToy
    4X4 Offroad
    do you have the a/c running when this happens by any chance?
  17. Mar 23, 2012 at 1:16 PM
    soup1279
    soup1279 Member
    Anthony
    Pottstown, PA
    nope. I hardly ever use AC.
  18. Mar 23, 2012 at 1:17 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Mine does it in the first 5-10 minutes of operation. Driving down the street at 30mph, it'll "clunk" .. usually when I let off the gas. I don't hear it .. I feel it. It'll happen maybe 1 or 2 times in that first 5-10 minutes, and then that's it.
  19. Mar 23, 2012 at 3:03 PM
    wolftree
    Rick
    Ohio
    On my 98 Tacoma, it felt like a small bump, with a barely audible thumping sound. It was the axle wrapping and unwrapping.
    You can probably see the axle move(rotate) if you do a power brake (hold brake down and accelerate while in gear) and let off the accelerator. Have someone watch the axle, while you operate throttle.
  20. Mar 23, 2012 at 3:30 PM
    wolftree
    Rick
    Ohio
    Beavis0076,
    Yes, it would seem that all of those vehicles have weak rear springs.
