transmission acting wierd?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RoyB, Oct 12, 2008.
  1. Oct 12, 2008 at 7:48 AM
    RoyB
    RoyB [OP] Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    Is this normal? When I am coasting it feels like the truck is in the wrong gear and using motor compression to slow the truck down....like more than any other vehicle I've ever driven. Seems kinda wierd and more noticeable the faster I go- only when my foot is off the gas and coasting though. There can't be that much drag.
  2. Oct 12, 2008 at 7:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Its normal. The auto tranny mimicks a manual tranny when coasting, and comming to a stop. :)
  3. Oct 12, 2008 at 7:53 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's normal...
    Mine does it. Not necessarily all the time but in certain situations you feel it more than others. Haven't figured out how - but I think if you use the brakes, prior to coasting...it does it more often.
  4. Oct 12, 2008 at 7:58 AM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    hm, kinda wierd. my srt magnum did an excellent job with their sensors. it would downshift if you were on the brakes or in a turn it would hold the gear. did awesome on the track.
  5. Oct 12, 2008 at 8:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your SRT Magnum is a different type of vehicle than the TAcoma. The Magnum is more sport oriented, while the Tacoma is a truck. Programming of the tranny will be different. :)
  6. Oct 12, 2008 at 8:08 AM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    I know ;) just never had a vehicle that slowed down this much without being on the brakes or being driven in a "spirited" manner :)
  7. Oct 12, 2008 at 8:22 AM
    Janster
    Jandy
    Lancaster, PA
    You don't need to drive the truck in a spirited manner... That's what the Vette is for!! ;) I can sooo relate!
    Each manufacturer has different programming for their transmissions and how they'll shift. The tacoma is the first auto I've driven that did it - atleast non of the other autos were as noticable.
  8. Oct 12, 2008 at 10:10 AM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Mine does this as well. In fact I changed the ATF fluid right after I got it to see if it would make a difference, but it didn't. So I just figured it was normal with this truck :)
