Transmission Adaptive Learning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Frank_Zuccarini, Aug 23, 2017.
  1. Aug 27, 2017 at 10:04 AM
    #41
    Clearwater Bill
    Billy
    Largo Florida
    I have an '04 Highlander with 120k and a 'smart' transaxle that still shifts awful 1-2 in town with a specific throttle application. Harder or softer makes it shift better, but you are not driving better. In my book it's learned nothing.
    The good news is it has gotten the same MPG since new. It's flawless on cruise under most any conditions, including the Smokies, that I've had it in.
    That said, I've never heard anyone with any gen or motor/trans combo of Tacoma who liked their cruise control behavior. Even in flat Fl. mine is notably different than the Highlander.
    So apparently not all Toyotas are created equal.
    hiPSI likes this.
  2. Aug 27, 2017 at 10:31 AM
    #42
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    My wife has a new 2017 Highlander. 8 speed and same engine as my Tacoma. Flawless shifting but I think I could take her in the 1/4 mile lol.
    Most important? My truck has a soul. Her Highlander has nothing. Just perfect. Boring. My truck bounces a bit a jiggles a bit and I gotta shift and I could hit something if I'm not careful and I can go over the center line without being told and I can merge over on somebody if I forget to check the mirrors and i have to turn the knob to have headlights and the right temperature. Soul to soulless.
  3. Aug 27, 2017 at 7:13 PM
    #43
    gearcruncher
    Canadain bumper technician
    Disconnecting the battery clears the short term memory and that should be good enough to start the re-learn procedure over . The only way to clear long term is with a scanner from Toyota or the aftermarket hacked Tis software , but I dont recommend doing this because if you have any warranty issues , the first thing a technician will do is perform a scan of long term memory .
    Clearing short term memory will work fine . From there , put the pedal to the metal
    treimche[QUOTED] likes this.
  4. Aug 27, 2017 at 8:59 PM
    #44
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    i may be dumb, but what does that do by touching them together
  5. Aug 28, 2017 at 6:53 AM
    #45
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Its a shocking experience.
  6. Aug 28, 2017 at 6:53 AM
    #46
    Dirty Harry
    Andrew
    SW Florida
    :bananadead:
    edyuen888 and gilligoon[QUOTED] like this.
  7. Aug 28, 2017 at 8:13 AM
    #47
    gearcruncher
    Disconnecting the battery , then touching the terminals together is suppose to rapidly discharge any capacitors and clear short term memory . Touching the cables together when the battery is disconnected should save you the 30 minutes that you would normally wait for the capacitors to discharge on their own .
    With this said , I personally use a scanner to clear short term memory on my own vehicles
    edyuen888, gilligoon and over60 like this.
  8. Aug 28, 2017 at 8:48 AM
    #48
    Ed Crankshaft
    Ed Crankshaft Well-Known Member
    2016 Black Tacoma TRD 4X4 DCSB
    It's the same with my Tacoma. On the slightest incline at highway speeds, the transmission will often downshift to 4th and the tachometer indicates 3,500 RPM. It shifts back and forth between 5th and 6th gear frequently.
    I often travel without using the cruise control, have fewer shifts and get better gas mileage.
    edyuen888 likes this.
  9. Nov 21, 2018 at 7:58 AM
    #49
    edyuen888
    edyuen888 Well-Known Member
    18’ Cement DCLB
    OV tuned, 5100’s, airbags, k02s.
    Hey guys anyone on here have a difinitive answer as to the mileage it take to finish it’s learning? 100,1000,10000? Asking for a friend ...
    tia
  10. Nov 21, 2018 at 11:15 AM
    #50
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    The learning phase will probably end when the transmission fails, or it reaches its end of life cycle.
    The learning includes or is tuned to drive-train wear and tear adjustments. That is why you don't want to disconnect the vehicle battery without a memory save tool that saves all that data that keeps the vehicle running like new.
    :thumbsup:
  11. Apr 17, 2022 at 11:54 AM
    #51
    geovegas71
    geovegas71 New Member
    George
    Toyota thinks this helps MPG?!?!?!?! what a joke! It feels like I'm dragging a trailer around with me on the HWY. I let off the gas and it feels like I'm driving with the parking brake on because it slows down so fast. It feels like I'm driving around in too low a gear all the time. It reminds me of my 70 chevy with the 4:10 rear gears.
