Transmission advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by ROSSILAND, May 14, 2024.
  1. May 14, 2024 at 11:40 AM
    ROSSILAND
    ROSSILAND [OP] Member
    04 Tacoma 300,000
    None
    I have a 2004 tacoma 4x4 6 cyl. I have 305000 miles. Never changed the transmission fluid. I dont work on my Tacoma, dont know how. I kept up on oil changes but idin't know i was suppose to get transmission fluid changed. At any rate the fluid is brown now. I do not have any issue with slipping. I was told it may start slipping if i mess with it now. So what should I do? Thank you
  2. May 14, 2024 at 11:44 AM
    Taxx
    Taxx Well-Known Member
    Changing the fluid now will NOT cause it to all of the sudden start slipping. A power flush done by a 3rd party that doesn't know what they are doing can stir up debris and cause issues. But just to drain and refill or have the dealer change it, won't cause it to slip. Just make sure the proper fluid is used.
    Gamehenge likes this.
  3. May 14, 2024 at 11:50 AM
    ROSSILAND
    04 Tacoma 300,000
    None
    Thank You
  4. May 14, 2024 at 11:55 AM
    Clearwater Bill
    Billy
    Largo Florida
  5. May 14, 2024 at 11:59 AM
    ROSSILAND
    04 Tacoma 300,000
    None
    So how often should I have had the fluid changed? What is the best to do now?
  6. May 14, 2024 at 11:59 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    It depends on fluid condition..you can change it and it may never move again...seen it many times
  7. May 14, 2024 at 12:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    Gearcruncher will pick up the tag above and chime in.
    gearcruncher likes this.
  8. May 14, 2024 at 12:07 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    OP what you have explained is no big deal.
    Your truck doesn’t slip so it’s just a matter of getting the old fluid out and new fluid in.
    On my Taco I dropped the transmission pan, cleaned it out, cleaned 3 magnet that are in there to attract small metal particles from normal wear, replaced the screen, re-installed the pan, and refilled the transmission. Then I did a drain and refill 2 more over about 6 months. This way all the fluid is replaced. Gearcruncher will probably recommend a quart of LubeGard. Listen to him.
    HondaGM and kwanjangnihm like this.
  9. May 14, 2024 at 12:09 PM
    Taxx
    Changed it how? Drain and refill?
    A flush, yes, bad things can happen. A drain and refill with appropriate fluid can't make a transmission stop working unless there is already an issue or debris gets past the filter and sticks a valve/solenoid.
  10. May 14, 2024 at 12:13 PM
    Taxx
    Look at manufacture recommendations. Every 100k isn't unheard of.
    Yes, just drain and refill. No flush. As Parkvisitor said, if you really want to get all of it out, drain it again after driving a bit and refill. You can also flush using the cooler lines and buckets and letting the transmission oil pump do the work. But that isn't necessary. A drain and refill is almost all that is ever recommended.
    Kleenax likes this.
  11. May 14, 2024 at 12:15 PM
    ROSSILAND
    04 Tacoma 300,000
    None
    Ok thank you all.
  12. May 14, 2024 at 5:16 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    All fluids when they get old they get laden with abrasive waste.
    It doesn't take much effort to save the seals in the tranny, differential, steering rack, master cylinder, ect...
    just need to be in the right mindset......map out your service intervals...
    Something as simple as rear axle seal job can set you back $1200 ~ $1500.....
    For a tranny....I'd do it at least every 60K.....
    with right tools you can do a partial 2 qt change in less than 15mins....
    maybe every 10K or so.....thats what I do.......hydraulic pump/long straw....
    Same with the differential.....they dont make those any more, destroy that and you've got a big problem...
    In these electronic trannys they don't use hydraulic pressure for shifting...
    but they dang sure have small little passages that can clog up....
    ROSSILAND[OP] likes this.
  13. May 14, 2024 at 6:54 PM
    gearcruncher
    Canadain bumper technician
    All your replies are on the right page .
    Most important is to remove the pan and clean the magnets , clean the filter or replace it with a new filter .
    Absolutely no flushes .
    When the pan is back on , fill the pan with new fluid and ofcourse with the A340 series transmission , add a 10 ounce bottle of Lubeguard in the black bottle .
    This only replaces half of your dirty fluid .
    At 300k , you have to do this using baby steps .
    You dont want to change all the fluid at once . Thats too hard on your transmission .
    A pan drop only gets half the dirty fluid out
    The fluid in your torque converter will get the chance to mix with the new fluid in the pan .
    Drive the truck for 6 months , then do a drain and fill by removing the pan drain plug .
    No need to drop the transmission pan this time .
