Transmission and coolant fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ortacoma10, May 27, 2025.
  1. May 27, 2025 at 2:51 PM
    Ortacoma10
    Ortacoma10 [OP] Well-Known Member
    2010 Tacoma Trd Off-road 4x4
    What intervals you guys running on transmission and coolant changes? Seen 30-60k on trans and every 50k on coolant
  2. May 27, 2025 at 3:26 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    ATF - every 50-70 K if flushing, or every 30-40 K for drain/refill. OEM recommendation is flush every 60K under ‘special operating conditions’. Towing, off-roading, etc… I did a flush the first time to flush out the OEM fluid; now I do drain/refill with Maxlife.
    Coolant - every 50K after 100K. This is the book recommendation. Personally, I use universal long-life coolant and replace every 100K.
    Micbt25 likes this.
  3. May 27, 2025 at 5:05 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I've been every 30k for ATF (simple drain/fill). After the first drain, subsequent drains are mostly clean/bright red looking.
    For coolant I just drain/fill 1 gallon every other year or so. Keeps the additives in it fresh and a lot less hassle than a full drain and then trying to burp the air out.
    winkel and spitdog like this.
  4. May 27, 2025 at 5:09 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I just did my 1 gal. Replacement today. I don’t mess with those block drains either.
    winkel and 2015WhiteOR like this.
  5. May 27, 2025 at 5:40 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    ATF-Never, not once in the 50 years I've been driving.
    Coolant -I replaced the hoses and coolant in my Tacoma at 17 years and 240,000 miles.
    Four vehicles on the driveway with 700,000 combined miles, no issues. None of the others are old enough to need the coolant replaced.
    winkel likes this.
  6. May 27, 2025 at 5:42 PM
    Bishop84
    Bishop84 Well-Known Member
    Coolant is 100,000 miles 10 years for the first time.
    ATF is 60,000miles or 5 years.
  7. May 27, 2025 at 6:22 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    After doing full 12 qt auto trans fluid replacements at the recommended 60k and 120k interval mark. I will be extending my next 12qt fluid swap to 200k (80k on the fluid) with a transmission pan drop/clean/filter replacement. At which point depending on how the fluid looks coming out then I might extend to 300k (100k OCI) or go back to 60k intervals.
    Coolant, 5yrs 50k miles. any longer and you risk acidity levels rising and eating away the multi layer headgasket. TBH 3yrs 50k miles even with good long life coolant (Zerex red asian or oem) is more ideal... this is super cheap and easy insurance.
  8. May 27, 2025 at 6:34 PM
    2015WhiteOR
    Gainesville TX
    Curious if anyone here has switched to Zerex Asian instead of buying Toyota SLLC? Zerex appears to be at least half the price of OEM. I don't imagine there would be issues since coolant is coolant but curious anyway.
