Transmission and differencial oil change help
Discussion in 'Performance and Tuning' started by renval, Mar 6, 2014.
  1. Mar 6, 2014 at 5:03 PM
    renval
    renval [OP] Well-Known Member
    Hi guys! I have 2006 TRD off road 4x4 manual transmission with 85k miles, I check on the back of the rear differencial and I saw this
    I went to the dealer and they gave me this
    The left one is for the transmission and the one on the right is for the front and rear differencial, the guy gave me 4qt for both differencial and 12qt for the transmission! Is that correct? I thought I need only 2qts to flush the transmission.
  2. Mar 7, 2014 at 5:45 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Wrong fluid for manual. You were given the fluid for the auto.
  3. Mar 7, 2014 at 7:36 AM
    renval
    thank you Lurkin! what they gave 12qts, i have seen people using 2 qts only.:notsure:
  4. Mar 7, 2014 at 10:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Holy smokes. That parts guys was pretty :rasta:
  5. Mar 7, 2014 at 10:30 AM
    MQQSE
    MQQSE Chief Pal Guy, GOB
    Rob
    Palmer, AK
    2015 RAM 1500 Laramie Crew Cab 5.7 Hemi 8 Spd
    I IDENTIFY AS a 40yo 2nd Gen Tacoma Owner
    This^^^^
    :laugh: ya' think? :facepalm:
