Transmission and Differential fluid change on 140k
Discussion in '1st Gen. Tacomas (1995-2004)' started by achon125, Aug 31, 2012.
  1. Aug 31, 2012 at 7:16 PM
    achon125
    achon125 [OP] New Member
    2000 SR5 V6
    stock
    I am about to do a tune up on my dads 2000 tacoma and I have a feeling he has never changed his transmission or differential fluids. Would you guys recommend changing the transmission and differential fluids on a car with 140K+ miles on it?
  2. Aug 31, 2012 at 7:22 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Yes. ASAP.
  3. Aug 31, 2012 at 8:10 PM
    achon125
    2000 SR5 V6
    stock
    Ok. For the transmission fluid, its just Dextron III right? and what weight oils do you guys use for the front and rear differentials? and also transfer case?
  4. Aug 31, 2012 at 8:11 PM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    since yours is an auto tranny you probably don't want to have the transmission flushed, just drain old and fill with new.
    with trannys over 100k and no changes flushing can cause issues
  5. Aug 31, 2012 at 8:52 PM
    achon125
    2000 SR5 V6
    stock
    How much will drain just from the transmission plug? about 3 quarts? and whats of ATF are popular on this site?
  6. Aug 31, 2012 at 8:55 PM
    achon125
    2000 SR5 V6
    stock
  7. Aug 31, 2012 at 10:23 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Check the dipstick.
    The 2000 may take Dex-III, Toyota T-IV, or Toyota WS (WS is unlikely on the 2000.
    If it's Toyota T-IV, buy it at the dealer.
    If it's Dex-III, Mobil-1 is the best you can get OTC.
    2nd Gen will dump about 4 quarts from the pan... I'd buy 5 to be safe.
  8. Aug 31, 2012 at 10:24 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not sure on the transfer case.
    Mobil-1 75w90 will be fine for the 75w90 or 80w90 applications.
  9. Sep 1, 2012 at 12:11 PM
    CUtacomaTIGER
    San Diego
    if you've got your owner manual, it has all the specs with the type of fluid and amounts in then back. the attached doc has fluid level to add for auto tranny for just a drain and fill
    if not here is mine,
  10. Sep 1, 2012 at 5:08 PM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
