Transmission and lighting problem
Discussion in 'Garage / Workshop' started by fidrat54, May 5, 2013.
  1. May 5, 2013 at 7:32 PM
    fidrat54
    fidrat54 [OP] The Kid
    Jean-Sebastien
    Canada
    2011 Tacoma TRD 4X4 Automatic
    Lift kit 3,5" Tire size: 33 X 12,5 X 17
    I post this here, but if it's the wrong place, let me know !!!
    2011 Tacoma TRD 4X4 Automatic, Lift kit 3,5", I think I have some problems qith my transmission. When the truck shift betweeen 3 and 4, the truck give some little stroke and when he has finish is shifting, the little strokes stop. If I shift very fast, the problem doesn't appear... Another things, sometimes, I feel un rumble in the transmission, when I release the gas, they stop...
    Another things!, I don't have any control on my light, the headlight and back light are always open day and night... if I turn the button to open or close somethings, nothing happens...
  2. May 5, 2013 at 7:46 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  3. May 5, 2013 at 8:41 PM
    fidrat54
    Jean-Sebastien
    Canada
    I have not engage 4WD on pavement, it's not my first truck but it's my first tacoma. My transmission problem is when I ride on a normal road...
  4. May 5, 2013 at 8:51 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Your headlights are open and your transmission is a male that strokes itself, unless of course you shift quickly enough?
    I'm thoroughly confused.
  5. May 5, 2013 at 9:00 PM
    fidrat54
    Jean-Sebastien
    Canada
    I don't have any control on my headlights with the normal headlight control... Normally, if you want to turn off your headlight and run on daylight you are normally able to...
    For my transmission, when I accelerate slowly, I feel little stroke when the truck shift from 3 to 4 the truck shake a little bit. If I accelerate very fast, nothing happens... no problem...
    Solutions ?
  6. May 6, 2013 at 9:13 AM
    OffroadToy
    If i'm reading this correctly (and i'm probably not) your getting vibration in the drive-line from the lift... might need to look into getting the drive-line angles corrected.
    As far as the dash instrument panel lighting it's normal for it to be on during the day even with the headlights off... just not as bright.
  7. May 6, 2013 at 9:21 AM
    Manwithoutaplan
    ID
  8. May 6, 2013 at 9:35 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    ^^this is what i understood out of the OPs post...
  9. May 6, 2013 at 10:19 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Send a PM to OZ-T...he is also Canadian and can better assist you.
  10. May 6, 2013 at 12:07 PM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    :facepalm: :rofl:
  11. May 6, 2013 at 12:09 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    C'est un peu confus...
    Quelle est votre langue maternelle, c'est le français ?
    Veuillez poster votre problème d'information français et nous pouvons traduire. (
  12. May 6, 2013 at 6:31 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    sounds like the hydrolic shifting pin is getting stuck somehow.
    Ever any gear grinding? Metal or something in the way mabye.?
    As for the lights... maybe direct short. At least the run
