Transmission (Auto) Fill Plug Stuck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MountainLionResources, Dec 29, 2017.
  1. Dec 29, 2017 at 4:53 PM
    MountainLionResources [OP] Member
    Kagat
    2013 Black Tacoma v6 Double Cab Long Bed Base Model Auto Tow Package
    3 in body lift, Tri folder bed cover, window tint, custom seat covers, custom windshield cover
    2013 Taco Auto Trany fill plug is stuck. The last person to wrench on it must have begun stripping the 24 mm hex bolt head. My attempt to loosen it with a 24 mm socket just slips. A 23 mm socket is still too small to fit onto the fill plug. This fill plug is up in the truck so reaching a hammer or torch up to the fill plug would be tricky, but perhaps doable. Does anyone have experience using a chisel or other techniques to unstuck the transmission fill plug? Is there parts that can be taken off the truck to get better access to the fill plug? What type of chisel would I need? After this a new transmission fill plug will be needed. Do ya'll have a link or parts #? -Thanks ladies & gentlemen.
  2. Dec 29, 2017 at 5:47 PM
    gearcruncher
    Canadain bumper technician
  3. Dec 29, 2017 at 10:33 PM
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    You can take off the Y pipe and bend the catalytic converter heat shield out of the way to get a little better access. The heat shield is the most pain when accessing that area.
    Also, what about an extractor socket? You can try a 24mm or try the 23mm if you're at that point.
    https://www.jbtoolsales.com/irwin-5...MIgtb4qo6x2AIVB7XACh0ZUwIsEAQYASABEgK1YvD_BwE
    I'd watch adding a lot of heat if you went that route, there's an o-ring on the plug.
    Good luck, I hate stuck stuff!
  4. Dec 29, 2017 at 10:43 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Buy a new drain plug and gasket first. Buy the biggest Vise-Grips you can. Drive around in low gear to warm up the transmission (if you have not already drained it). Let the exhaust cool to a safe level. Apply some penetrating oil. Grab the plug firmly with the Vise Grips, and tap on the handles to loosen.
  5. Dec 30, 2017 at 12:28 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Most sockets are beveled; grind it down to give you an extra mm of contact surface area. I did this to an extra 15/16" socket I had lying about; it also fits the fill plug on our Lexus. Plus, 15/16ths is 23.8125 mm.
    fixer5000, Muddinfun and IronPeak like this.
  6. Jan 18, 2018 at 4:15 PM
    Kagat
    From this parts list I'm unsure which part # is a fill plug for my
    '13 v6 5At 4x4 Taco Base double cab.
    http://www.toyodiy.com/parts/p_U_201109_TOYOTA_TACOMA_GRN245L-CRADKA_3503.2.html?hl=35106A
    My best guesses are the
    PLUG, AUTOMATIC TRANSMISSION CASE (90341-A0001),
    PLUG (FOR AUTOMATIC TRANSMISSION OIL PAN)(90341-10021),
    PLUG (FOR AUTOMATIC TRANSMISSION CASE) (90341-14011), or
    PLUG SUB-ASSY, DRAIN (ATM) (90341-10011).
    The dealership recommended I get the last option- a drain plug because they suspect it has the same threads & same o-ring as the fill plug.
    Thank you for all of your input so far. Will know more after I climb under her again with a replacement plug for the stripped fill plug.
