Transmission being replaced in 2021 TRD Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cdobsru, Nov 5, 2024.
  1. Nov 5, 2024 at 2:25 PM
    cdobsru
    cdobsru [OP] Member
    Collin
    2021 Green Tacoma Sport
    I finally have a verdict to an issue I have been dealing with since I bought my 2021 Tacoma Sport.
    I purchased it in April 2023. First owner had it for 1.5 years and put 7k miles on it. After a few months of ownership I noticed that the shifting seemed a bit odd and the ride uncomfortable. I did some research and found about the infamous Tacoma shudder and chalked it up to that.
    A year later I was just about fed up with how uncomfortable the drive had become. I did some more research and found out about the ECT and the OTT. I tried the ECT and was happier with the drive after that. The shifting felt much better but there was still a shudder when not shifting and bouncy ride. The same day I tried the ECT for the first time, the check engine light came on and the truck reported and issue with the 4WD system. I took it to the dealer and they determined the ECU was faulty and replaced it. They also found some corroded wires and replaced those. The truck seemed to drive better after that but maybe it was in my head.
    A few months after the ECU was replaced, I realized I had come to hate the modified exhaust that the original owner put on. The proportion of noise to power just wasn't there for me and I decided to have the muffler replaced with something closer to stock. I was much happier with the truck after this change.
    Weeks go by and the drive seemed to be getting worse. At about 40-50mph the truck shuddered and felt very bouncy. I thought the tires might have been out of balance so I took them to get balanced and rotated. When leaving the dealership I was disappointed to learn that this did not fix the uncomfortable ride.
    I took the truck back to the dealer and described the problem and asked for a vehicle tech to do a drive along with me. He felt the shudder that I was feeling and thought it could have been an issue with the torque converter. I left the truck with them for a day and they ran some tests and determined that the entire transmission needs to be replaced. They ordered the parts and hope to replace it next week. They did not give me any details on exactly how they determined the transmission was bad, or what was bad about it. Thankfully this is all covered under the power train warranty.
    Just sharing my experience because while I did find many topics about the Tacoma shudder, I did not find many about total transmission replacements. I feel slightly vindicated now because my intuition was that something was wrong with the truck and I just could not pinpoint it.
    tl;dr Bought a 2021 TRD Sport in April 2023 and it had a very uncomfortable drive. Toyota is replacing the transmission for me.
    WilliamJames likes this.
  2. Nov 5, 2024 at 2:28 PM
    cdobsru
    cdobsru [OP] Member
    Collin
    I forgot to mention, the truck has about 24k miles on it as of this posting. I plan on continuing to drive it until they get the parts in for the transmission replacement. I will update the status here after the replacement.
    SandyTaco4x4 likes this.
  3. Nov 5, 2024 at 2:41 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    That is odd with such low milage on the truck these transmissions are usually pretty bullet proof although they do have the typical gear hunting they are known for. Did the dealer comment on fluid level? They have been known to come from the factory with low transmission fluid.
  4. Nov 5, 2024 at 2:47 PM
    cdobsru
    cdobsru [OP] Member
    Collin
    The tech at the dealer did not comment on the fluid level, but it was a question I asked. The service tech I was dealing with was very helpful and attentive but did not have many of the details I was looking for. I wanted to know how and why they determined it needed to be replaced, but he did not have the answers. I need to get those details eventually otherwise I am going to be paranoid about this truck for as long as I own it.
  5. Nov 5, 2024 at 2:53 PM
    PaulyFromLA
    PaulyFromLA Well-Known Member
    Pauly
    1st gen tacomas
    Ones a camper, ones oem, ones a flatbed
    mines still good after adding lucas, a trans cooler, an inline filter and changing the fluid every 30k and its from 1997 original
  6. Nov 5, 2024 at 2:56 PM
    cdobsru
    cdobsru [OP] Member
    Collin
    Nice! That's the type of reliability I was hoping to get when I purchased this thing
  7. Nov 5, 2024 at 3:14 PM
    OLDTRAP
    OLDTRAP Well-Known Member
    2021 TRD OR
    Stock
    I understand the shifting issue. Mine sucks as well, as do all of them from what I gather.
    I am interested in what you mean by "uncomfortable ride?"
  8. Nov 5, 2024 at 3:19 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    more than likely, they have no F'n idea, they are replacing in hopes of correcting it,, which I doubt it will. Hopefully I am wrong on the latter.
  9. Nov 5, 2024 at 3:24 PM
    cdobsru
    cdobsru [OP] Member
    Collin
    To be honest it's hard to explain properly, but basically when I hit 40-50mph the truck would start to bounce and almost shake a little bit. It felt like there was some sort of resistance that was keeping me from going a constant speed. I could accelerate through it and it would go away at around 70mph. I felt this even when limiting the max gear to 4/5/6 in S-mode, with ECT on, and in cruise control.
  10. Nov 5, 2024 at 3:26 PM
    cdobsru
    cdobsru [OP] Member
    Collin
    That's what I am worried about too. I am definitely going to see the repair through and hope that it corrects it. I still may sell it on the other side of this though. I just don't know what I would change to. I'm not a fan of the Gen 4s and am worried about those issues. New Tundras are nice but are out of my price range and have their own issues. I will possibly consider Frontiers or Rangers. But I truly hope this fixes the issue and I can keep my Tacoma.
    WilliamJames and Chew[QUOTED] like this.
  11. Nov 5, 2024 at 3:51 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    OP, IMHO I would demand to know what they found wrong that warrants the entire transmission to be replaced. I think @Chew nailed it.
    shakerhood and Chew like this.
  12. Nov 5, 2024 at 4:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    It's easier to just R&R the whole unit rather than to remove, crack it open to replace the converter, then replace.
    And if they are convinced it's the trans. But unsure what, just change it rather than burn more diagnostic time
    Hopefully this solves your problem. I don't think I could have put up with that for 18k mi
    auskip07 likes this.
  13. Nov 5, 2024 at 5:29 PM
    cdobsru
    cdobsru [OP] Member
    Collin
    Good call. I'll push to get this information - thank you
    t0p_d0g[QUOTED] likes this.
  14. Nov 5, 2024 at 5:31 PM
    cdobsru
    cdobsru [OP] Member
    Collin
    Yeah that makes sense. Honestly, it has definitely been pretty annoying and definitely getting more annoying lately. But early on I kept reading about the Tacoma shudder and just chalked it up to that. I forgot to mention, but on the same day I had the vehicle tech drive with me I test drove another used Tacoma that was on the lot. That was very eye opening about how rough mine rode comparatively. I wish I did that sooner.
  15. Nov 5, 2024 at 8:07 PM
    I-Give-Up
    I-Give-Up Well-Known Member
    West Phoenix, AZ
    2023 Ice Cap Tacoma TRD
    Meso spare fuse holder. Aluminum gas cap holder. Genuine Toyota bed lights. Bed molle racks. Ammo case storage under hood. In-bed spare tire. Automatic underhood lights. Gooey glurp on frame.
    Some of the symptoms point to an out-of-balance drive shaft.
  16. Nov 5, 2024 at 9:56 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Toyota had torque converter shudder issues on different models due to software design.
    Required a software upgrade and , in some cases, a replacement of the torque converter
    There are a few folks here who had the same issues and none of solution helped them.
    OP mentioned the speed range where the issue happens. We had the shudder at the same speeds on 2016-2017 models with B03 ecu calibration. Was somewhat fixed on B04 with 2018 TSB.
    FIY, the issue is related to driving terrain, traffic and speed limits
  17. Nov 6, 2024 at 10:36 AM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    I've had the same issue with my 2021 since new. 40k miles later and every time I brought it up with the dealer they blamed tires, my AAL, etc. Glad your dealer was more proactive and I hope this fixes your problem
  18. Nov 6, 2024 at 10:40 AM
    cdobsru
    cdobsru [OP] Member
    Collin
    Sorry to hear you are having the same issue. Is my description of the shudder I was feeling consistent with what you feel when you drive yours?
    AZPhys13[QUOTED] likes this.
  19. Nov 6, 2024 at 11:57 AM
    AZPhys13
    Yeah, the truck gets jerky between 40-45 mph which is the speed limit on most of my commute. KDMax helped smooth it out to an extent but I've never been able to eliminate it.
  20. Nov 7, 2024 at 1:09 PM
    cdobsru
    cdobsru [OP] Member
    Collin
    I just heard from the dealer - they got the replacement transmission in stock. I'm shocked at how quickly they got it. They diagnosed the issue only 2 days ago...
    Anyway, I'm dropping it off tomorrow to get surgery.
    WilliamJames, 45Frank and Chew like this.
