Transmission booboo
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mtb_mafioso, Aug 26, 2019.
  1. Aug 26, 2019 at 1:32 PM
    Mtb_mafioso
    Mtb_mafioso [OP] Well-Known Member
    story time:
    I went on some chill trails with my 1st Gen 99Taco PreRunner 2WD (it does not have a rear locking diff) I ended up getting stuck and the only way out was in reverse. I managed to get out after about an hr of trying.
    Once I left the mountain I noticed a lovely smell of burnt transmission. I pulled over Added some fluid and put it in reverse, the sounds my lovely truck made sent a chill down my spine, made a lump in the throat and dread that made me nauseous. I got to a parts store. Bought more fluid added it and put it in reverse and it worked fine (on flat ground without me pushing the gas)
    I got home no issues. The truck felt fine. Once I got home I tried to back it into my garage (a small hill) and it made the same terrible sounds that nightmares are made of.
    As I wiped the puke from my mouth I noticed that same smell.
    It was at this moment I realized I f**ked up.
    I found a Japanese transmission with low miles for $700 or should I get it rebuilt. I need answers!!!!
    Thanks people
  2. Aug 26, 2019 at 1:35 PM
    eon_blue
    Azusa, CA
    I don't really know much about auto transmissions but are you sure you don't want to have a shop diagnose it first before you commit to a new trans (or a rebuild)?
    If yours is indeed toast, I would think a $700 used transmission would be a lot cheaper than getting yours rebuilt. Something tells me a rebuild is going to cost a lot more than that.
  3. Aug 26, 2019 at 1:37 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    why are you adding fluid?
    Mtb_mafioso[OP] and rnish like this.
  4. Aug 26, 2019 at 1:38 PM
    eon_blue
    Azusa, CA
    At the very least I would drain yours and see what it looks like when it comes out...but yeah you shouldn't be adding fluid if it isn't low. Overfilling it isn't going to help any
    Mtb_mafioso[OP] likes this.
  5. Aug 26, 2019 at 1:45 PM
    Mtb_mafioso
    It was low already, and like an idiot I didn’t add more before I left.
  6. Aug 26, 2019 at 1:52 PM
    wheeliest
    Json
    TMPE AZ
    I know there is a particular way to check transmission fluid level.. are you checking it the way the manual states?
  7. Aug 26, 2019 at 1:54 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If you pull the dipstick, how does it smell?
  8. Aug 26, 2019 at 1:58 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Pretty sure a new/rebuilt trans for a 99 should be less than $700. There are people who have done entire pre-runner 4x4 swaps for just over a grand.
    But I would definitely take it to a specialist before committing to a new trans. Even if you pay them $100 for a diagnostic, that'll easily pay for itself if it turns out to be a simple(ish) fix.
    Kwikvette and Mtb_mafioso[OP] like this.
  9. Aug 26, 2019 at 2:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I suggest either draining the fluid and removing the transmission pan, or simply draining the fluid.
    Super easy to do and the stuff from Toyota is just over $4/qt.
  10. Aug 26, 2019 at 4:41 PM
    Mtb_mafioso
    Message me
    Running Board Man likes this.
