Transmission check fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dinasour73, Nov 9, 2023.
  1. Nov 9, 2023 at 1:52 AM
    Dinasour73
    Dinasour73 [OP] Active Member
    Rickard
    2020 Tacoma Barcelona Red
    None
    How do I add/ck transmission fluid on 6 spd auto teans.
    2020 4 cyl engine?
    Hint I can drive in S mode and reduce transmission changing but mpg reduced due to increase tork
  2. Nov 9, 2023 at 2:43 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Search function, stickies.
  3. Nov 9, 2023 at 3:16 AM
    PTSDTherapy
    22 SR5 DCSB
    This is not true. Check the stickies and search for transmission fluid check. 2020 or 2022 and on doesn’t need to short the pins in the connector.
  4. Nov 9, 2023 at 3:23 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    No dipstick …wasn’t aware there is a complicated way of checking it .
  5. Nov 9, 2023 at 4:47 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    It's not that complicated and why post if you don't know the answer. no need to confuse people.
    Murd3rd likes this.
  6. Nov 9, 2023 at 4:59 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    No need for a dipstick. In extremely rare cases, many years ago, SOME trucks came off the assembly line underfilled. Unless you find a puddle of transmission fluid under your truck it is full.
    It is normal for the transmission to change gears often. Especially with a lower powered engine, it needs lower gears to make up for the lack of engine power. Driving in S mode just keeps it in lower gears longer and will not allow it to shift to 6th gear. No different than staying in lower gears longer with a manual and staying out of OD.
    You have to choose between power or economy.
  7. Nov 9, 2023 at 5:00 AM
    fourfourone
    There have been many posts about 3rd gens coming slightly low from the factory.
    faawrenchbndr likes this.
  8. Nov 9, 2023 at 11:52 AM
    PTSDTherapy
    22 SR5 DCSB
    The few posts or many you may find on here pale in comparison to how many are sold each year. If every Tacoma that was slightly low from the factory grenaded it would be on the news.
    And before someone calls bullshit on that statement saying my transmission was a 8 ozs low, transmission dipsticks have a low and a full mark as well. So it’s not as precise as most people think.
  9. Nov 9, 2023 at 11:56 AM
    PTSDTherapy
    22 SR5 DCSB
    Never told you to check the dipstick… stickies… ie sticky threads at the top of the forums. The answer is there or if you search what I indicated. Do a little work yourself… then ask if you don’t understand.
    Phlogiston and RIX TUX like this.
  10. Nov 9, 2023 at 12:19 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Complete BS
    RIX TUX likes this.
  11. Nov 9, 2023 at 12:20 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    coopnugz likes this.
  12. Nov 9, 2023 at 12:24 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    what?
  13. Nov 9, 2023 at 12:27 PM
    RIX TUX
    did you ck the owners manual?
    Phlogiston likes this.
  14. Nov 9, 2023 at 12:31 PM
    coopnugz
    coopnugz Well-Known Member
    Cooper
    2022 Black Trail
  15. Nov 9, 2023 at 1:14 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    thanks …..forgot that was a 2018 model video
    coopnugz[QUOTED] likes this.
  16. Nov 9, 2023 at 3:33 PM
    PTSDTherapy
    22 SR5 DCSB
    Yep same as what I said.did you find it yet or just waiting for someone to do it for you? Someone already gave you the link. Do you understand how to do it?
  17. Nov 9, 2023 at 6:45 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    I call bulls*%t:). Transmissions now are different from not that many years ago and fill levels are more important now than before. It isn't as critical to be within a couple ounces like some on here are so anal about. As far as how many of them come low from the factory we can never know. Only people like us on here do the work ourselves. 99% of Taco owners don't know jack about their trucks so we will never know if they have trannys low on fluid.I know when I did a full fluid exchange I found mine to be almost a quart low and having the proper amount in made a difference.
  18. Nov 9, 2023 at 6:56 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    My truck doesn't have a transmission.
  19. Nov 10, 2023 at 10:39 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    You have the Flintstone-Rubble drive?
  20. Nov 10, 2023 at 11:03 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Rubber band conversion.
    faawrenchbndr[QUOTED] likes this.
