Transmission check help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rb1, May 19, 2016.
  1. May 20, 2016 at 3:27 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
  2. May 21, 2016 at 4:16 PM
    Rb1
    Rb1 [OP] Well-Known Member
    Ron
    Kent Wa
    2016 tacoma trd offroad dc
    Just got it done! Big thanks to wyant! Had to be the clearest instructions I've seen. If I could add anything, toggle fairly quickly between N and D to start the check. I had to try 3 times before I got it. Also a little surprised how long it drains before it started dripping. Took around 4 to 5 minutes. But my son was watching the dash the whole time and the D never started blinking. For me, it was a 1/4 quart low. Not much, thats probably why it shifts pretty good, and better by the day. My truck has 800 mi. on it and has the tow package. Made in baja on april 22. If your on the fence about doing it yourself. Do it! Then you'll know it was done right. Thanks again to everyone who gave input.
    Maineiak07 likes this.
  3. May 21, 2016 at 7:03 PM
    Element
    Element Well-Known Member
    Mass
    2016 Limted Trade for 2017 F 150 Lariat 3.5 Twin Tubro
    When I did my transmission check with the pin 4 and 13 jump. I also used a temp gun, right at 95 degrees the D come on the dash. The warm up time is a little long. You will have plenty of time to added fluid in need to before it hit 113.
  4. May 22, 2016 at 12:11 AM
    Tucktuck8
    Tucktuck8 Well-Known Member
    2016 White DCLB
    Anyone have the torque specs for the fill and drain plug on hand?
  5. May 22, 2016 at 8:29 AM
    glider_guider
    glider_guider Well-Known Member
    2016 Red Tacoma TRD OR 4x4
  6. May 22, 2016 at 11:01 AM
    wyant
    wyant Well-Known Member
    Wyant
    2016 TRD off road DCLB
    I had the exact same experience, 1/4 qt low and about 5 minutes to get it to drip. I think it takes some time for the fluid to work through the components from the time it is pumped, the service instructions say to pump slowly to prevent it from splashing. The dealer did claim they checked the fluid and was low before I took delivery... I just had to be sure. Build date was April 12 in Baja.
  7. May 22, 2016 at 5:29 PM
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    So you were pumping in fluid as you were performing the test? I don't understand what you mean by it took 5 minutes for fluid to drip.
  8. May 22, 2016 at 5:39 PM
    Rb1
    Ron
    Kent Wa
    Its drizzels out for about 4 to 5 minutes after you pump for a while. Its like your pumping for a minute and nothing is coming out, and all of the sudden its coming out in a slow thin stream. Instructions say wait until it goes from a stream to a fast drip. Then put the check plug back in. You're now done.
    mustangwilly likes this.
