Transmission "Clank" noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dTed, Sep 21, 2016.
  1. Sep 21, 2016 at 8:18 AM
    dTed
    dTed [OP] Well-Known Member
    2013 DCLB SR5 4x4 MGM
    So I've had my Tacoma for about a month now and I've noticed this "clank" ever since I got it. It seems to only happen when I reverse out of my driveway/parking spot, then I drive forward and it'll get to about 15 mph. I'll let off the gas (for a stop sign) and there's a small clank. It doesn't seem like a big deal or a problem, I'm just curious what it is.
    Am I crazy?
    Toyko Joe and ChadsPride like this.
  2. Sep 21, 2016 at 8:22 AM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    Is it when you hit the brakes?
  3. Sep 21, 2016 at 8:25 AM
    dTed
    No, it seems to be when I let off the gas pedal
  4. Sep 21, 2016 at 8:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    Might be the tranny down shifting.
  5. Sep 21, 2016 at 9:18 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If you have driveline zerks on your 2013 grease them.
    Arailt and Toyko Joe like this.
  6. Sep 21, 2016 at 9:22 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    My 6speed does that. I also have some rattling from the transfer case area if I 'unbind' the drive line (i.e. press in the clutch pedal) and go slowly over a speed bump. Like that since new and the dealer as repeatedly said "it's normal"...
  7. Sep 21, 2016 at 9:27 AM
    rescuetaco526
    rescuetaco526 Well-Known Member
    W. Kentucky
    09 TRD Off Road pkg
    Diff Breather, Topper, airbag
    Could be the U joints. While you're greasing the zerks check for play in the drive shaft. Had one go out at 50k, made a clunk sounds from reverse to drive because of the a bad u joint and it taking up slack.
  8. Sep 21, 2016 at 11:53 AM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Automatic mine does it to dropping in to a higher gear3rd or 4th.You see it on a mild drive not getting into right?on it hard maybe u-joints.Let us know.
  9. Sep 21, 2016 at 12:36 PM
    dTed
    Yeah its and automatic, seems like I'm just into 3rd gear when it does it but I can't be sure if it's up or downshifting. I do have some grease zerks on the u-joints, so I'll try that. What kind of grease do you guys recommend? I've never done it before
    I didn't feel any play at all in the driveshaft, everything felt pretty sturdy
  10. Sep 21, 2016 at 3:36 PM
    Hot Tacoma Blown
    NewYork
    05 4×4 tacoma
    I use synthetic blue.It will say on tube what it covers.but try to see if it is slow speed then maybe 4th gear.If it does it when you are hitting the loud pedal I would check at your local tranny shop.But I don't believe their is a problem.Mine clucks at low speeds but when. I Release The Hounds Of Hell the supercharger screams like banshee and scares the locals back to their caves.Sorry of topic.Lets us know your investigation into it.
  11. Sep 22, 2016 at 4:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    FYI - Sometimes you won't feel play in the driveshaft with it in park and on the ground. The best way to check is with the axle off the ground and the truck in neutral. You can then spin the shaft and fell for wiggle at the joints. Chock the front wheels of course.
    gearcruncher likes this.
  12. Oct 3, 2016 at 3:59 PM
    dTed
    Just an update. I greased all the zerks on the driveshaft and it did not solve the noise.
    I've mostly stopped caring because I don't think its a real issue, but I do wish I could figure out what it was
  13. Oct 3, 2016 at 10:14 PM
    TxStVanWilder
    TxStVanWilder The Pale Horse
    Tx
    2013 TRD Sport
    i have what i feel like is driveline slack... not really a clunk, but when letting off the gas somewhat of a jerk/slack type feeling and when i get back on it the same feeling.... not at highway speeds or low speeds, but more just mid range around town from anywhere in the 30-50 range
