Transmission "Clicks"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blake, Oct 18, 2010.
  1. Oct 18, 2010 at 9:36 AM
    Blake
    Blake [OP] Well-Known Member
    Knoxville, TN
    2010 Doublecab TRD Offroad Supercharged
    OME Heavy Kit TRD Supercharger Borla Catback Exhaust
    Every once in a while, when shifting from reverse to drive on a hill, I will notice the transmission makes a quick "clicking" type sound. I simply put the truck in neutral, make sure the brake is depressed firmly, then shift into drive with no problem.
    I drive very conservatively, and don't think I shift the truck too abruptly when in a parking lot...which is where this mostly happens. Perhaps it is that the truck is slightly rolling, and it's simply a safety feature on the newer models...which I never noticed on my 01 Taco.
    Anyone have any thoughts or insight into this one? Thanks.
  2. Oct 18, 2010 at 12:06 PM
    Blake
    Knoxville, TN
    Nobody?
  3. Oct 18, 2010 at 5:55 PM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    i think its a new safety feature. my friend has to come to a complete stop when reversing to go into drive in his FIT.
  4. Oct 18, 2010 at 5:57 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Probably your brakes.
  5. Oct 18, 2010 at 6:15 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Yep....Thats what it was on mine. The front pads get about half way worn they start to click when you put it in reverse. Weird...but it was.
  6. Oct 18, 2010 at 6:23 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    It sounds silly but are you sure you're completely stopped when you shift into drive?
  7. Oct 18, 2010 at 6:46 PM
    Blake
    Knoxville, TN
    That's the thing...not all the way...a super slow roll...but moving nonetheless.
  8. Oct 18, 2010 at 6:50 PM
    TACOMA TRD
    Tom
    PA
    How many miles?
  9. Oct 18, 2010 at 6:51 PM
    Blake
    Knoxville, TN
    Just turned 20k.
  10. Oct 19, 2010 at 4:41 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    It's probably the ABS system engaging into standby.
  11. Oct 19, 2010 at 9:15 AM
    tacobox
    Even from a slow roll it can cause the trans to make a noise or a click. I'd try to be conscious to make sure you're at a complete stop before shifting into drive and see if it continues. Your truck is so new, I don't think it would have any issues. I've have had a couple customers come in complaining about a noise when shifting into drive (in a couple different kinds of vehicles) and that was the only thing we could conclude.
  12. Oct 19, 2010 at 2:21 PM
    TACOMA TRD
    Tom
    PA
    Its possible that your brakes are half way down. Put it in drive then shift to neutral and stop, the back up with out touching brakes....see if it clicks.
  13. Oct 19, 2010 at 4:37 PM
    hopkins
    hopkins Member
    NS Canada
    05 TRD DC LB
    Jack Rabbit Tonneau Cover 18" BFG A/T on KMC Addicts XD Series TRD Cat Back Grillcraft upper with TRD Emblem
    Having your brakes serviced may resolve the noise, sounds to me like brake pads moving in the holders.
  14. Oct 19, 2010 at 5:13 PM
    808TRDTaco10
    808TRDTaco10 Taco addict
    Justin
    Big Island, Hawaii
    '98 T4R, '08 RC, '10 AC, & '18 DCSB
    Mine makes a similar noise after a cold start-up, right after I put it into drive and start going. I'm guessing that it has something to do with the ABS though. It doesn't really bother me, as long as something isn't about to break.
  15. Oct 19, 2010 at 9:47 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    My front brakes make a similar click when I go front forward to reverse or vice versa .
